jacking up the bus
09-08-2010, 02:50
jacking up the bus
Does any one know where the jacking points on the rear of the bus? Might
have to remove the tranny and the levelers do not jack up high enough.
Joe
1984 pt 40
____________________________________________________________
Mortgage Rates Hit 3.25%
If you owe under $729k you probably qualify for Obama's Refi Program
http://thirdpartyoffers.juno.com/TGL3141...6925m06vuc
09-08-2010, 03:00
jacking up the bus
Anywhere along the lower frame member. The HWH jack points where they attach to
the frame or near those points should be good.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
-----Original Message-----
Sender: WanderlodgeForum@yahoogroups.com
Date: Wed, 8 Sep 2010 09:50:28
To:
Reply-To: WanderlodgeForum@yahoogroups.com
subject:[WanderlodgeForum] jacking up the bus
Joe
1984 pt 40
Yahoo! Groups Links
09-08-2010, 03:14
jacking up the bus
One other area to look at after a decision of where your going to jack the
frame. With the suspension inflated, measure the distance between the top of the
lower frame and bottom of the upper frame the cut Oak blocks to fit in between
the frames. This will safely keep the extra 4 inches from the ride height in
place, after you dump the suspension with the blocks in place
Duncan, Oklahoma
To:
Joe
1984 pt 40
Yahoo! Groups Links
09-08-2010, 04:03
jacking up the bus
Just a word of caution, if you lift the rear wheels off the ground the
Coach will roll if the front tires are not fully blocked to prevent the roll.
Safe travels,
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
>Joe
>1984 pt 40
