					Neutral safty switch
					11-12-2011, 08:24
Post: #31
					Glad you found the easy fix.  If you helps, don't think you are the only one
			that has had this happen. I would guess it has happened to close to all BB owners - some of us more than once! 8-( Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "wlb52@..." > > It was the AT switch it got flipped to the right. I looked for it and didn't see it till now flipped it to the left and it turned o er and started right up. Dam now I have to put it all back together. Thanks everyone for there help. BILL > > Connected by DROID on Verizon Wireless > > -----Original message----- > From: Don Bradner > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, Nov 7, 2011 01:00:55 GMT+00:00 > Subject: Re: [WanderlodgeForum] Neutral safty switch > > AT is anti-theft. Simple way to make sure the coach can't be started, but a b**** when you don't know it got switched! > > On 11/6/2011 at 7:52 PM wlb52@... wrote: > > >What is the at switch. I will go out and see if I can find it > > Connected > >by DROID on Verizon Wireless > > -----Original message----- > From: Ralph > > > To: Wanderlodge Forum > > > Sent: Mon, Nov 7, 2011 00:13:24 > >GMT+00:00 > Subject: Re: [WanderlodgeForum] Neutral safty switch > > Rarely. > >Ahh let's try one more thing quickly. Sit in the drivers seat. On the > >lower up dash, find a switch labeled AT. Be sure it is switched to the > >left. If right then switch it and start > Safe travels, > > Ralph & Charolette Fullenwider > '84 FC35 > >"Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original > >Message----- > From: "wlb52@..." > Sender: > >WanderlodgeForum@yahoogroups.com > Date: Sun, 6 Nov 2011 19:01:59 > To: > > > Reply-To: > >WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Neutral > >safty switch > > I try flipping the toggle switch from front to back four or > >five times and it didn't start. I'm trying to find the key for the back > >start spot. Do you think it could be the front key switch > > Connected by > >DROID on Verizon Wireless > > -----Original message----- > From: Wayne Kotila > > > To: "WanderlodgeForum@yahoogroups.com" > > > Sent: Sun, Nov 6, 2011 23:41:31 > >GMT+00:00 > Subject: Re: [WanderlodgeForum] Neutral safty switch > > On my > >former coach (1985 PT40) I had your same symptoms a few times caused by > >two different things. The switch for remote start back in the engine > >compartment apparently had bad contact points, it would act > >up��occasionaly and If I flipped it from front to rear and back a��few > >times the coach would��then start. I replaced the switch after this > >happened a couple of times and that eliminated that problem. Another time > >I had the exact same symptoms, hit the key,��it did not crank the engine > >over and the starter made no noise. That time it turned out to be a jammed > >(stuck starter), the starter was pulled and the drive gear on the starter > >was easily freed up and the starter put back on, it never got stuck > >again. > �� > Good Luck > Wayne > >Kotila > 96PT42���� > > > ________________________________ > From: > >"wlb52@..." > To: > >WanderlodgeForum@yahoogroups.com > Sent: Saturday, November 5, 2011 7:06 > >PM > Subject: Re: [WanderlodgeForum] Neutral safty switch > > > �� > Got to the > >neutral salty switch cut the two wires put them together and no start. > >Anyone no of anything it could be short of the starter. It dose not make a > >sound so I think its not the starter.�� Thanks.���� Bill > > Connected by > >DROID on Verizon Wireless > > -----Original message----- > > From: Ralph > > > >To: Wanderlodge Forum > > > >Sent: Fri, Nov 4, 2011 20:18:46 > >GMT+00:00 > >Subject: Re: [WanderlodgeForum] Neutral safty > >switch > > > >Attached the bottom of the shifter mechanism > >Safe travels, > >Ralph Charolette Fullenwider > >'84 FC35 "Ruff Diamond" > >Duncan, > >Oklahoma > >Sent via BlackBerry by AT&T > > > >-----Original Message----- > >From: > >"William B" > >Sender: WanderlodgeForum@yahoogroups.com > >Date: Fri, 04 Nov > >2011 19:30:51 > >To: > >Reply-To: WanderlodgeForum@yahoogroups.com > >Subject: > >[WanderlodgeForum] Neutral safty switch > > > >I have a 1985 pt 40 that > >started one day and the next day I get no sound out of the starter. I > >think it may be the neutral safty switch but I can not find it. I looked > >on the trans and I didn't see dose anyone know where it would be > >located > > > > > > > >------------------------------------ > > > >Yahoo! Groups > >Links > > > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups > >Links > > > >*> To visit your group on the web, go > >to: > >http://groups.yahoo.com/group/WanderlodgeForum/ > > > >*> Your email > >settings: > >Individual Email | Traditional > > > >*> To change settings online > >go to: > >http://groups.yahoo.com/group/WanderlodgeForum/join > >(Yahoo! ID > >required) > > > >*> To change settings via > >email: > >WanderlodgeForum-digest@yahoogroups.com > > > >WanderlodgeForum-fullfeatured@yahoogroups.com > > > >*> To unsubscribe from > >this group, send an email > >to: > >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >*> Your use of Yahoo! > >Groups is subject to: > >http://docs.yahoo.com/info/terms/ > > > > > > > > > > ------------------------------------ > > Yahoo! Groups Links >  |
					11-12-2011, 08:27
Post: #32
					Uh, that should be "if it helps"  - if I could type!  LOL
			Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Glad you found the easy fix. If you helps, don't think you are the only one that has had this happen. I would guess it has happened to close to all BB owners - some of us more than once! 8-( > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "wlb52@" > > > > It was the AT switch it got flipped to the right. I looked for it and didn't see it till now flipped it to the left and it turned o er and started right up. Dam now I have to put it all back together. Thanks everyone for there help. BILL > > > > Connected by DROID on Verizon Wireless > > > > -----Original message----- > > From: Don Bradner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Mon, Nov 7, 2011 01:00:55 GMT+00:00 > > Subject: Re: [WanderlodgeForum] Neutral safty switch > > > > AT is anti-theft. Simple way to make sure the coach can't be started, but a b**** when you don't know it got switched! > > > > On 11/6/2011 at 7:52 PM wlb52@ wrote: > > > > >What is the at switch. I will go out and see if I can find it > > > > Connected > > >by DROID on Verizon Wireless > > > > -----Original message----- > > From: Ralph > > > > > To: Wanderlodge Forum > > > > > Sent: Mon, Nov 7, 2011 00:13:24 > > >GMT+00:00 > > Subject: Re: [WanderlodgeForum] Neutral safty switch > > > > Rarely. > > >Ahh let's try one more thing quickly. Sit in the drivers seat. On the > > >lower up dash, find a switch labeled AT. Be sure it is switched to the > > >left. If right then switch it and start > > Safe travels, > > > Ralph & Charolette Fullenwider > > '84 FC35 > > >"Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original > > >Message----- > > From: "wlb52@" > > Sender: > > >WanderlodgeForum@yahoogroups.com > > Date: Sun, 6 Nov 2011 19:01:59 > > To: > > > > > Reply-To: > > >WanderlodgeForum@yahoogroups.com > > Subject: Re: [WanderlodgeForum] Neutral > > >safty switch > > > > I try flipping the toggle switch from front to back four or > > >five times and it didn't start. I'm trying to find the key for the back > > >start spot. Do you think it could be the front key switch > > > > Connected by > > >DROID on Verizon Wireless > > > > -----Original message----- > > From: Wayne Kotila > > > > > To: "WanderlodgeForum@yahoogroups.com" > > > > > Sent: Sun, Nov 6, 2011 23:41:31 > > >GMT+00:00 > > Subject: Re: [WanderlodgeForum] Neutral safty switch > > > > On my > > >former coach (1985 PT40) I had your same symptoms a few times caused by > > >two different things. The switch for remote start back in the engine > > >compartment apparently had bad contact points, it would act > > >up��occasionaly and If I flipped it from front to rear and back a��few > > >times the coach would��then start. I replaced the switch after this > > >happened a couple of times and that eliminated that problem. Another time > > >I had the exact same symptoms, hit the key,��it did not crank the engine > > >over and the starter made no noise. That time it turned out to be a jammed > > >(stuck starter), the starter was pulled and the drive gear on the starter > > >was easily freed up and the starter put back on, it never got stuck > > >again. > > �� > > Good Luck > > Wayne > > >Kotila > > 96PT42���� > > > > > > ________________________________ > > From: > > >"wlb52@" > > To: > > >WanderlodgeForum@yahoogroups.com > > Sent: Saturday, November 5, 2011 7:06 > > >PM > > Subject: Re: [WanderlodgeForum] Neutral safty switch > > > > > > �� > > Got to the > > >neutral salty switch cut the two wires put them together and no start. > > >Anyone no of anything it could be short of the starter. It dose not make a > > >sound so I think its not the starter.�� Thanks.���� Bill > > > > Connected by > > >DROID on Verizon Wireless > > > > -----Original message----- > > > > From: Ralph > > > > > >To: Wanderlodge Forum > > > > > >Sent: Fri, Nov 4, 2011 20:18:46 > > >GMT+00:00 > > >Subject: Re: [WanderlodgeForum] Neutral safty > > >switch > > > > > >Attached the bottom of the shifter mechanism > > >Safe travels, > > >Ralph Charolette Fullenwider > > >'84 FC35 "Ruff Diamond" > > >Duncan, > > >Oklahoma > > >Sent via BlackBerry by AT&T > > > > > >-----Original Message----- > > >From: > > >"William B" > > >Sender: WanderlodgeForum@yahoogroups.com > > >Date: Fri, 04 Nov > > >2011 19:30:51 > > >To: > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >Subject: > > >[WanderlodgeForum] Neutral safty switch > > > > > >I have a 1985 pt 40 that > > >started one day and the next day I get no sound out of the starter. I > > >think it may be the neutral safty switch but I can not find it. I looked > > >on the trans and I didn't see dose anyone know where it would be > > >located > > > > > > > > > > > >------------------------------------ > > > > > >Yahoo! Groups > > >Links > > > > > > > > > > > > > > > > > >------------------------------------ > > > > > >Yahoo! Groups > > >Links > > > > > >*> To visit your group on the web, go > > >to: > > >http://groups.yahoo.com/group/WanderlodgeForum/ > > > > > >*> Your email > > >settings: > > >Individual Email | Traditional > > > > > >*> To change settings online > > >go to: > > >http://groups.yahoo.com/group/WanderlodgeForum/join > > >(Yahoo! ID > > >required) > > > > > >*> To change settings via > > >email: > > >WanderlodgeForum-digest@yahoogroups.com > > > > > >WanderlodgeForum-fullfeatured@yahoogroups.com > > > > > >*> To unsubscribe from > > >this group, send an email > > >to: > > >WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > >*> Your use of Yahoo! > > >Groups is subject to: > > >http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > >  |
					11-12-2011, 08:40
Post: #33
				 I can't believe I didn't see it.
Connected by DROID on Verizon Wireless -----Original message-----
