Sluggish 8V92
11-08-2012, 10:26
Sluggish 8V92
Any chance your transmission is starting off in 2nd instead of 1st?
Scott P. |
11-08-2012, 10:27
Sluggish 8V92
Hi, Just a thought. What you are describing sounds like a turbo waste gate issue. I would take it into a Detroit engine shop and have them diagnose the engine.
Paul Williams 88XXV 40 Wanderlodge 8V92 84,750 mi -----Original Message-----
From: Ernie Ekberg To: WanderlodgeForum Sent: Thu, Nov 8, 2012 10:12 am Subject: Re: [WanderlodgeForum] Sluggish 8V92 hope you have a ggod stay. I was driving thru last week on my way to a quick look see on a job in San A
88 PT40 Wanderlodge
Weatherford, Texas
817-475-3991
To: "WanderlodgeForum@yahoogroups.com" Sent: Thursday, November 8, 2012 6:57 AM Subject: RE: [WanderlodgeForum] Sluggish 8V92 Ernie
We are at Sunset Point.
Steve
From: "WanderlodgeForum@yahoogroups.com" [mailto: "WanderlodgeForum@yahoogroups.com" ] On Behalf Of Ernie Ekberg
Sent: Wednesday, November 07, 2012 6:51 PM To: "WanderlodgeForum@yahoogroups.com" Subject: Re: [WanderlodgeForum] Sluggish 8V92 Steve- are
you in Marble Falls ? I looked at the river cg and didn't see anything but white trailers Ernie Ekberg
88 PT40
Wanderlodge Weatherford, Texas
817-475-3991
To: "WanderlodgeForum@yahoogroups.com" Sent: Wednesday, November 7, 2012 6:47 PM Subject: RE: [WanderlodgeForum] Sluggish 8V92 Jerry
What temperature is
cold? Mine does not like temps much under 50 to start smoothly. I would also start with the filters then to the valve adjustment. Had a valve adjustment done on mine two years ago, lots of difference. Steve Quandt
1993 PT-40
Iron Mountain, MI
From: "WanderlodgeForum@yahoogroups.com" [mailto: "WanderlodgeForum@yahoogroups.com" ] On Behalf Of Jerry
Sent: Wednesday, November 07, 2012 1:44 PM To: "WanderlodgeForum@yahoogroups.com" Subject: [WanderlodgeForum] Sluggish 8V92 I have a
"1991 Bluebird Wanderlodge WB40" with a silver "8V92". Lately it has become painfully slow at accelerating from a dead stop. It is getting to the point of being unsafe to attempt to merge into traffic. Once you get it rolling down the highway, it isn't so bad...I have no problems maintaining 70mph. Turbo boost will show a bit over 20 for a max, but when accelerating from a stop, boost is less then 10, and the rpm's just don't want to rev up. When it is first started, when cold, it does not sound as smooth as I thought it used to.....almost like it has a slight mis. Seems to smooth out once it is warm. Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel and air filters have been recently serviced, but I have no knowledge of any past maintenance history.....so I don't know if there are other issues that need to be looked at....ie: valve settings, fuel injectors, etc. Has anyone else had this issue, or have any ideas at what I may need to check to help resolve this problem? Thanks, Jerry |
11-08-2012, 17:14
Sluggish 8V92
Scott,
That is interesting that you mention the transmission....it is something I have suspicioned because that is how it seems when starting from a stop. Is there any way to verify this? Would pushing "1" guarantee that it is indeed in first gear? This has the allison 5 speed, not sure on the model, I think its something like a 745 or 755. Paul, We have an appointment to have it checked out Monday. Finally found a tech in this area willing to work/check a 8V92. I will let you all know what they find. Thanks, Jerry --- In WanderlodgeForum@yahoogroups.com, "Jerry" > > I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". > > Lately it has become painfully slow at accelerating from a dead stop. It is getting to the point of being unsafe to attempt to merge into traffic. > > Once you get it rolling down the highway, it isn't so bad...I have no problems maintaining 70mph. > > Turbo boost will show a bit over 20 for a max, but when accelerating from a stop, boost is less then 10, and the rpm's just don't want to rev up. > > When it is first started, when cold, it does not sound as smooth as I thought it used to.....almost like it has a slight mis. Seems to smooth out once it is warm. > > Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel and air filters have been recently serviced, but I have no knowledge of any past maintenance history.....so I don't know if there are other issues that need to be looked at....ie: valve settings, fuel injectors, etc. > > Has anyone else had this issue, or have any ideas at what I may need to check to help resolve this problem? > > Thanks, Jerry > |
11-08-2012, 17:31
Sluggish 8V92
How about starting at zero mph and go slowly to 50 mph counting how times it shifts, and watch the tach for small drops in RPM's
From: Jerry To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 8, 2012 9:14 PM Subject: [WanderlodgeForum] Re: Sluggish 8V92 Scott,
That is interesting that you mention the transmission....it is something I have suspicioned because that is how it seems when starting from a stop. Is there any way to verify this? Would pushing "1" guarantee that it is indeed in first gear? This has the allison 5 speed, not sure on the model, I think its something like a 745 or 755. Paul, We have an appointment to have it checked out Monday. Finally found a tech in this area willing to work/check a 8V92. I will let you all know what they find. Thanks, Jerry --- In "WanderlodgeForum%40yahoogroups.com", "Jerry" > > I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". > > Lately it has become painfully slow at accelerating from a dead stop. It is getting to the point of being unsafe to attempt to merge into traffic. > > Once you get it rolling down the highway, it isn't so bad...I have no problems maintaining 70mph. > > Turbo boost will show a bit over 20 for a max, but when accelerating from a stop, boost is less then 10, and the rpm's just don't want to rev up. > > When it is first started, when cold, it does not sound as smooth as I thought it used to.....almost like it has a slight mis. Seems to smooth out once it is warm. > > Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel and air filters have been recently serviced, but I have no knowledge of any past maintenance history.....so I don't know if there are other issues that need to be looked at....ie: valve settings, fuel injectors, etc. > > Has anyone else had this issue, or have any ideas at what I may need to check to help resolve this problem? > > Thanks, Jerry > |
11-09-2012, 08:17
Sluggish 8V92
The HT755 is a 5-speed, but has 6 apparent/effective gears in terms of rpm
changing. When flooring mine from a stop, the gear shifts occur approximately at: 0mph 1st gear 18mph 2nd gear unlocked 27mph 2nd gear locked 36mph 3rd gear 45mph 4th gear 60mph 5th gear Upshifts occur at 2100rpm and drop to 1670rpm Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 11/8/2012 at 9:31 PM Julian Cane wrote: >How about starting at zero mph and go slowly to 50 mph counting how times >it shifts, and watch the tach for small drops in RPM's > > > > > >________________________________ > From: Jerry >To: WanderlodgeForum@yahoogroups.com >Sent: Thursday, November 8, 2012 9:14 PM >Subject: [WanderlodgeForum] Re: Sluggish 8V92 > > >ÃÂ >Scott, > >That is interesting that you mention the transmission....it is something I >have suspicioned because that is how it seems when starting from a stop. > >Is there any way to verify this? Would pushing "1" guarantee that it is >indeed in first gear? This has the allison 5 speed, not sure on the >model, I think its something like a 745 or 755. > >Paul, > >We have an appointment to have it checked out Monday. Finally found a >tech in this area willing to work/check a 8V92. > >I will let you all know what they find. > >Thanks, Jerry > >--- In WanderlodgeForum@yahoogroups.com, "Jerry" >> >> I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". >> >> Lately it has become painfully slow at accelerating from a dead stop. >It is getting to the point of being unsafe to attempt to merge into >traffic. >> >> Once you get it rolling down the highway, it isn't so bad...I have no >problems maintaining 70mph. >> >> Turbo boost will show a bit over 20 for a max, but when accelerating >from a stop, boost is less then 10, and the rpm's just don't want to rev >up. >> >> When it is first started, when cold, it does not sound as smooth as I >thought it used to.....almost like it has a slight mis. Seems to smooth >out once it is warm. >> >> Bought it used with 160,000 miles, it now has a bit over 200,000 miles. >The fuel and air filters have been recently serviced, but I have no >knowledge of any past maintenance history.....so I don't know if there are >other issues that need to be looked at....ie: valve settings, fuel >injectors, etc. >> >> Has anyone else had this issue, or have any ideas at what I may need to >check to help resolve this problem? >> >> Thanks, Jerry >> |
11-09-2012, 11:28
Sluggish 8V92
Don, you have 5 speed? I have 4 speeds- and at 1500 rpm, I'm doing 55. Ernie Ekberg 88 PT40 Wanderlodge Weatherford, Texas 817-475-3991 From: Don Bradner
To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 9, 2012 2:17 PM Subject: Re: [WanderlodgeForum] Re: Sluggish 8V92 The HT755 is a 5-speed, but has 6 apparent/effective gears in terms of rpm changing. When flooring mine from a stop, the gear shifts occur approximately at: 0mph 1st gear 18mph 2nd gear unlocked 27mph 2nd gear locked 36mph 3rd gear 45mph 4th gear 60mph 5th gear Upshifts occur at 2100rpm and drop to 1670rpm Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 11/8/2012 at 9:31 PM Julian Cane wrote: >How about starting at zero mph and go slowly to 50 mph counting how times >it shifts, and watch the tach for small drops in RPM's > > > > > >________________________________ > From: Jerry <"grldst@yahoo.com"> >To: "WanderlodgeForum@yahoogroups.com" >Sent: Thursday, November 8, 2012 9:14 PM >Subject: [WanderlodgeForum] Re: Sluggish 8V92 > > > >Scott, > >That is interesting that you mention the transmission....it is something I >have suspicioned because that is how it seems when starting from a stop. > >Is there any way to verify this? Would pushing "1" guarantee that it is >indeed in first gear? This has the allison 5 speed, not sure on the >model, I think its something like a 745 or 755. > >Paul, > >We have an appointment to have it checked out Monday. Finally found a >tech in this area willing to work/check a 8V92. > >I will let you all know what they find. > >Thanks, Jerry > >--- In "WanderlodgeForum@yahoogroups.com", "Jerry" >> >> I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". >> >> Lately it has become painfully slow at accelerating from a dead stop. >It is getting to the point of being unsafe to attempt to merge into >traffic. >> >> Once you get it rolling down the highway, it isn't so bad...I have no >problems maintaining 70mph. >> >> Turbo boost will show a bit over 20 for a max, but when accelerating >from a stop, boost is less then 10, and the rpm's just don't want to rev >up. >> >> When it is first started, when cold, it does not sound as smooth as I >thought it used to.....almost like it has a slight mis. Seems to smooth >out once it is warm. >> >> Bought it used with 160,000 miles, it now has a bit over 200,000 miles. >The fuel and air filters have been recently serviced, but I have no >knowledge of any past maintenance history.....so I don't know if there are >other issues that need to be looked at....ie: valve settings, fuel >injectors, etc. >> >> Has anyone else had this issue, or have any ideas at what I may need to >check to help resolve this problem? >> >> Thanks, Jerry >> ------------------------------------ Yahoo! Groups Links <*> To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ <*> Your email settings: Individual Email | Traditional <*> To change settings online go to: http://groups.yahoo.com/group/WanderlodgeForum/join (Yahoo! ID required) <*> To change settings via email: "WanderlodgeForum-digest@yahoogroups.com" "WanderlodgeForum-fullfeatured@yahoogroups.com" <*> To unsubscribe from this group, send an email to: "WanderlodgeForum-unsubscribe@yahoogroups.com" <*> Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/ |
11-09-2012, 11:37
Sluggish 8V92
Yes, I have the HT755. They started using it in 89 or 90.
On 11/9/2012 at 3:28 PM Ernie Ekberg wrote: >Don, you have 5 speed? I have 4 speeds- and at 1500 rpm, I'm doing 55. > > > >Ernie Ekberg >88 PT40 Wanderlodge >Weatherford, Texas >817-475-3991 >http://www.ernieekbergflooring.net/ > > >________________________________ > From: Don Bradner >To: WanderlodgeForum@yahoogroups.com >Sent: Friday, November 9, 2012 2:17 PM >Subject: Re: [WanderlodgeForum] Re: Sluggish 8V92 > >The HT755 is a 5-speed, but has 6 apparent/effective gears in terms of rpm >changing. When flooring mine from a stop, the gear shifts occur >approximately at: > >0mph 1st gear >18mph 2nd gear unlocked >27mph 2nd gear locked >36mph 3rd gear >45mph 4th gear >60mph 5th gear > >Upshifts occur at 2100rpm and drop to 1670rpm > >Don Bradner >90 PT40 "Blue Thunder" >My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >On 11/8/2012 at 9:31 PM Julian Cane wrote: > >>How about starting at zero mph and go slowly to 50 mph counting how times >>it shifts, and watch the tach for small drops in RPM's >> >> >> >> >> >>________________________________ >> From: Jerry >>To: WanderlodgeForum@yahoogroups.com >>Sent: Thursday, November 8, 2012 9:14 PM >>Subject: [WanderlodgeForum] Re: Sluggish 8V92 >> >> >> >>Scott, >> >>That is interesting that you mention the transmission....it is something I >>have suspicioned because that is how it seems when starting from a stop. >> >>Is there any way to verify this? Would pushing "1" guarantee that it is >>indeed in first gear? This has the allison 5 speed, not sure on the >>model, I think its something like a 745 or 755. >> >>Paul, >> >>We have an appointment to have it checked out Monday. Finally found a >>tech in this area willing to work/check a 8V92. >> >>I will let you all know what they find. >> >>Thanks, Jerry >> >>--- In WanderlodgeForum@yahoogroups.com, "Jerry" >>> >>> I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". >>> >>> Lately it has become painfully slow at accelerating from a dead stop. >>It is getting to the point of being unsafe to attempt to merge into >>traffic. >>> >>> Once you get it rolling down the highway, it isn't so bad...I have no >>problems maintaining 70mph. >>> >>> Turbo boost will show a bit over 20 for a max, but when accelerating >>from a stop, boost is less then 10, and the rpm's just don't want to rev >>up. >>> >>> When it is first started, when cold, it does not sound as smooth as I >>thought it used to.....almost like it has a slight mis. Seems to smooth >>out once it is warm. >>> >>> Bought it used with 160,000 miles, it now has a bit over 200,000 miles. >>The fuel and air filters have been recently serviced, but I have no >>knowledge of any past maintenance history.....so I don't know if there are >>other issues that need to be looked at....ie: valve settings, fuel >>injectors, etc. >>> >>> Has anyone else had this issue, or have any ideas at what I may need to >>check to help resolve this problem? >>> >>> Thanks, Jerry >>> > > > > > >------------------------------------ > >Yahoo! Groups Links > > > >  http://docs.yahoo.com/info/terms/ |
11-12-2012, 09:57
Sluggish 8V92
Interesting post Don. I remembered it as I fired mine up this weekend to go
fill up with propane. Normally, I don't pay much attention to where the shift points are, as long as they do shift, and I usually light foot it off the start until I get rolling. Anyway, as I turned a corner to get on IH-10 for a bit, I felt the 2nd gear lock up shift and remembering your post, I then floored it to merge in with traffic. My 3/4/5 shift results were very crisp and almost identical to yours in mpg (35/45/60) but my max rpms and rpm drop off point were both higher than yours. Not exactly sure what that implies, but it was interesting to make the comparison. FWIW, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The HT755 is a 5-speed, but has 6 apparent/effective gears in terms of rpm changing. When flooring mine from a stop, the gear shifts occur approximately at: > > 0mph 1st gear > 18mph 2nd gear unlocked > 27mph 2nd gear locked > 36mph 3rd gear > 45mph 4th gear > 60mph 5th gear > > Upshifts occur at 2100rpm and drop to 1670rpm > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 11/8/2012 at 9:31 PM Julian Cane wrote: > > >How about starting at zero mph and go slowly to 50 mph counting how times > >it shifts, and watch the tach for small drops in RPM's > > > > > > > > > > > >________________________________ > > From: Jerry > >To: WanderlodgeForum@yahoogroups.com > >Sent: Thursday, November 8, 2012 9:14 PM > >Subject: [WanderlodgeForum] Re: Sluggish 8V92 > > > > > >ÃÂ > >Scott, > > > >That is interesting that you mention the transmission....it is something I > >have suspicioned because that is how it seems when starting from a stop. > > > >Is there any way to verify this? Would pushing "1" guarantee that it is > >indeed in first gear? This has the allison 5 speed, not sure on the > >model, I think its something like a 745 or 755. > > > >Paul, > > > >We have an appointment to have it checked out Monday. Finally found a > >tech in this area willing to work/check a 8V92. > > > >I will let you all know what they find. > > > >Thanks, Jerry > > > >--- In WanderlodgeForum@yahoogroups.com, "Jerry" > >> > >> I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". > >> > >> Lately it has become painfully slow at accelerating from a dead stop. > >It is getting to the point of being unsafe to attempt to merge into > >traffic. > >> > >> Once you get it rolling down the highway, it isn't so bad...I have no > >problems maintaining 70mph. > >> > >> Turbo boost will show a bit over 20 for a max, but when accelerating > >from a stop, boost is less then 10, and the rpm's just don't want to rev > >up. > >> > >> When it is first started, when cold, it does not sound as smooth as I > >thought it used to.....almost like it has a slight mis. Seems to smooth > >out once it is warm. > >> > >> Bought it used with 160,000 miles, it now has a bit over 200,000 miles. > >The fuel and air filters have been recently serviced, but I have no > >knowledge of any past maintenance history.....so I don't know if there are > >other issues that need to be looked at....ie: valve settings, fuel > >injectors, etc. > >> > >> Has anyone else had this issue, or have any ideas at what I may need to > >check to help resolve this problem? > >> > >> Thanks, Jerry > >> > |
11-12-2012, 12:24
Sluggish 8V92
Ahem, someone seems to have put the 'g' key right next to the 'h' key on my
keyboard, so my mpg should clearly have been mph in that post. Even in my dreams, I don't get double digit mpg on the Bird. ;^( Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Interesting post Don. I remembered it as I fired mine up this weekend to go fill up with propane. Normally, I don't pay much attention to where the shift points are, as long as they do shift, and I usually light foot it off the start until I get rolling. Anyway, as I turned a corner to get on IH-10 for a bit, I felt the 2nd gear lock up shift and remembering your post, I then floored it to merge in with traffic. My 3/4/5 shift results were very crisp and almost identical to yours in mpg (35/45/60) but my max rpms and rpm drop off point were both higher than yours. Not exactly sure what that implies, but it was interesting to make the comparison. > > FWIW, > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > The HT755 is a 5-speed, but has 6 apparent/effective gears in terms of rpm changing. When flooring mine from a stop, the gear shifts occur approximately at: > > > > 0mph 1st gear > > 18mph 2nd gear unlocked > > 27mph 2nd gear locked > > 36mph 3rd gear > > 45mph 4th gear > > 60mph 5th gear > > > > Upshifts occur at 2100rpm and drop to 1670rpm > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > > > On 11/8/2012 at 9:31 PM Julian Cane wrote: > > > > >How about starting at zero mph and go slowly to 50 mph counting how times > > >it shifts, and watch the tach for small drops in RPM's > > > > > > > > > > > > > > > > > >________________________________ > > > From: Jerry > > >To: WanderlodgeForum@yahoogroups.com > > >Sent: Thursday, November 8, 2012 9:14 PM > > >Subject: [WanderlodgeForum] Re: Sluggish 8V92 > > > > > > > > >ÃÂ > > >Scott, > > > > > >That is interesting that you mention the transmission....it is something I > > >have suspicioned because that is how it seems when starting from a stop. > > > > > >Is there any way to verify this? Would pushing "1" guarantee that it is > > >indeed in first gear? This has the allison 5 speed, not sure on the > > >model, I think its something like a 745 or 755. > > > > > >Paul, > > > > > >We have an appointment to have it checked out Monday. Finally found a > > >tech in this area willing to work/check a 8V92. > > > > > >I will let you all know what they find. > > > > > >Thanks, Jerry > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Jerry" > > >> > > >> I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". > > >> > > >> Lately it has become painfully slow at accelerating from a dead stop. > > >It is getting to the point of being unsafe to attempt to merge into > > >traffic. > > >> > > >> Once you get it rolling down the highway, it isn't so bad...I have no > > >problems maintaining 70mph. > > >> > > >> Turbo boost will show a bit over 20 for a max, but when accelerating > > >from a stop, boost is less then 10, and the rpm's just don't want to rev > > >up. > > >> > > >> When it is first started, when cold, it does not sound as smooth as I > > >thought it used to.....almost like it has a slight mis. Seems to smooth > > >out once it is warm. > > >> > > >> Bought it used with 160,000 miles, it now has a bit over 200,000 miles. > > >The fuel and air filters have been recently serviced, but I have no > > >knowledge of any past maintenance history.....so I don't know if there are > > >other issues that need to be looked at....ie: valve settings, fuel > > >injectors, etc. > > >> > > >> Has anyone else had this issue, or have any ideas at what I may need to > > >check to help resolve this problem? > > >> > > >> Thanks, Jerry > > >> > > > |
11-13-2012, 14:35
Sluggish 8V92
UPDATE; Tech called today and said he found the number 6 injector is bad.
Basically it is running on 7 cylinders. We also have a slight leak on one of the exhaust tubes that goes to the turbo. --- In WanderlodgeForum@yahoogroups.com, "Jerry" > > I have a "1991 Bluebird Wanderlodge WB40" with a silver "8V92". > > Lately it has become painfully slow at accelerating from a dead stop. It is getting to the point of being unsafe to attempt to merge into traffic. > > Once you get it rolling down the highway, it isn't so bad...I have no problems maintaining 70mph. > > Turbo boost will show a bit over 20 for a max, but when accelerating from a stop, boost is less then 10, and the rpm's just don't want to rev up. > > When it is first started, when cold, it does not sound as smooth as I thought it used to.....almost like it has a slight mis. Seems to smooth out once it is warm. > > Bought it used with 160,000 miles, it now has a bit over 200,000 miles. The fuel and air filters have been recently serviced, but I have no knowledge of any past maintenance history.....so I don't know if there are other issues that need to be looked at....ie: valve settings, fuel injectors, etc. > > Has anyone else had this issue, or have any ideas at what I may need to check to help resolve this problem? > > Thanks, Jerry > |
