Maybe our motorhomes are getting a little heavy...
05-09-2018, 17:53
(This post was last modified: 05-09-2018 17:56 by davidbrady.)
Published on May 3, 2018, KRTV, Montana's News Leader:
05-09-2018, 19:39
RE: Maybe our motorhomes are getting a little heavy...
I just came back from a trip there in montana. The state has had way too much moisture and parking lots are mushy
05-09-2018, 22:21
(This post was last modified: 05-09-2018 22:23 by Arcticdude.)
Those new P50's are grossing at 63,000 if I recall correctly. Sad that a new one has to go through that. And I really hope that wasn't the MacKillop's changing brands! That is to say that I would understand if they did, but would really hate for this to be their maiden voyage in the new rig!
05-10-2018, 09:15
is Ross buying a Newell?
05-10-2018, 12:43
NO ! 63,000 GVWR ! where is that legal ? 44,600 on the rear
Note that it is now legal to have 24,000 on one axle If I could....PREVOST ! Burned once.... not again! Ross MacKillop Wiarton Ontario 2006 450 Lxi |
05-10-2018, 18:32
(05-10-2018 12:43)dentmac Wrote: If I could....PREVOST ! Attaboy Ross! Here's the GAWR specs for the P50: Gross vehicle-weight rating 63,300 lbs. Gross axle-weight rating, front 20,000 lbs. Gross axle-weight rating, drive 28,600 lbs. Gross axle-weight rating, tag 16,000 lbs. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
05-10-2018, 22:40
Don’t those axle weight ratings add up to 64,400?
In any event, those owners aren’t going to be on the Ohio Turnpike with that drive axle fully loaded. LOL Coincidentally, I looked at a Newell built stacker on Wednesday. It was also rediculously heavy. Mike Bulriss 2001 LXi 43' DS Millennium Edition San Antonio, TX |
05-11-2018, 00:05
The discrepancy can be due to the Drive:Tag ratio. Usually 60:40 (or 65:35 if you are trying to lighten the front end ) ( a BB trick
![]() May not be true , but sounds good Eh! Ross MacKillop Wiarton Ontario 2006 450 Lxi |
