Water Pump Keeps Running
12-18-2005, 15:29
I seem to have a water pump that keeps running. I have the two pump
system with the bathroom switch that lets you select pump A or pump B
or both. When I select pump B or both A & B the system continues to
run. Is there a pressure switch that could have gone south and if so
can anyone tell me what it looks like and maybe where it might be
located. If not a pressure switch could it be some other gold plated
wangflanger part.
Rob 94 wlwb
12-18-2005, 16:15
Rob
Make certain your fresh water fill switch hasn't been accidently switched to
fill, this will cause your pump to run on.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge PT41
12-18-2005, 16:23
Thanks Fred. I've made that mistake before all right. No it's not the fill
switch. Only the one pump runs on while the other works properly.
Rob, Sue & Merlin
94 WLWB
Quoting Fred Hulse :
> Rob
> Fred & Jeanne Hulse
> Morristown Arizona
> YAHOO! GROUPS LINKS
> Visit your group "WanderlodgeForum" on the web.
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
12-18-2005, 16:53
Hi Rob,
The pressure switch is located on the end of the pump - has two wires
going to it, one from power and the other to the pump motor. The switch
is available separately from most RV suppliers.
George Lowry
'95 WBDA 4203
Spearfish, SD.
>wangflanger part.
>Rob 94 wlwb
>Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.1/206 - Release Date: 12/16/2005
12-18-2005, 23:59
Thanks George I'm going to try and adjust that pressure switch and will let you
know if I'm successful.
Rob, Sue & Merlin
94 WLWB
Quoting George Lowry :
> Hi Rob,
> George Lowry
> '95 WBDA 4203
> Spearfish, SD.
> >wangflanger part.
> >Rob 94 wlwb
> >Yahoo! Groups Links
> SPONSORED LINKS
> Recreational vehicles
> Wanderlodge
> Automotive maintenance
> Recreational vehicle dealer
> Used recreational vehicles
> Automotive radiators
> YAHOO! GROUPS LINKS
12-19-2005, 15:18
Failure of the Sporlan fill valve AND/OR failure of the hot water tank drain
valve will also cause this symtom. I faught this for months before I found that
both were defective. However, this was on a one pump system. So may not apply
to a 2 pump system as in the newer BB's.
Dick Hayden '87 PT 38 - Lk Stevens, WA
Sent: Sunday, December 18, 2005 8:15 PM
Subject: Re: [WanderlodgeForum] Water Pump Keeps Running
Rob
Fred & Jeanne Hulse
Morristown Arizona
YAHOO! GROUPS LINKS
a.. Visit your group
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web
WanderlodgeForum-unsubscribe@yahoogroups.com @yahoogroups.com?subject=Unsubscribe>
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service<http://docs.yahoo.com/info/terms/>.
12-21-2005, 10:38
Problem seems to be solved. I had some air in the line and when I openned a
drain valve it expelled air and the pump immediately shut off. It cycles
correctly now. Thanks to all for your help.
Rob, Sue & Merlin
94 WLWB
