Drivers mirror position
01-03-2006, 15:45
I am installing a set of Velvac 2030 mirrors on my coach and have a
question regarding positioning the drivers side mirror. The instructions state "with driver in drivers seat and viewing thru windshield locate mirror assembly as far forward as possible..." This is how the stock drivers mirror was adjusted and I tried this position with the new mirror and it did work but it looked awful. The mirror arm stuck straight out from the front of the coach. Looking at the ads for various high-end coaches in the new FMCA magazine, I see the mirror being adjusted so it is visible out the side window and sits almost perpendicular to the side of the coach. The only notable exception was the "Ferrari", the bright red 450LXi. Does it make any difference which way it is adjusted or is it just a coach-builders preference? Any pros or cons? Thanks, TJ Hannink Winter Park, FL 1981 FC-33SB |
01-03-2006, 19:09
Tim,
FWIW, I'll relate our daughter's experience when driving a Blue Bird school bus. An oncoming truck on a narrow road smashed the mirror and sent broken glass through the open side window. True, it was a west coast style mirror but the farther the mirror protrudes toward the opposing lane the greater the chance you have of clipping the mirror. The problem would be more pronounced on a later model wide-body coach. Looks aside, it would seem to me that overall safety would be enhanced with the mirror closer to the coach and forward with the proviso that the windshield pillar doesn't obstruct you view. Jim Owens 77 FC33SB (Gas) Lake of the Ozarks, MO --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > > I am installing a set of Velvac 2030 mirrors on my coach and have a > question regarding positioning the drivers side mirror. The > instructions state "with driver in drivers seat and viewing thru > windshield locate mirror assembly as far forward as possible..." > > This is how the stock drivers mirror was adjusted and I tried this > position with the new mirror and it did work but it looked awful. > The mirror arm stuck straight out from the front of the coach. > > Looking at the ads for various high-end coaches in the new FMCA > magazine, I see the mirror being adjusted so it is visible out the > side window and sits almost perpendicular to the side of the coach. > The only notable exception was the "Ferrari", the bright red 450LXi. > > Does it make any difference which way it is adjusted or is it just a > coach-builders preference? Any pros or cons? > > Thanks, > > TJ Hannink > Winter Park, FL > 1981 FC-33SB > |
