WHOOPS!! KRYLON ACCIDENTALLY SPRAYED ON COACH
03-14-2006, 12:09
Howdy, Y'all.
Jack accidentally got Kyrlon Fusion for Plastic spray paint on the Bird. [X-(] [X-(] [X-(] I won't even go into HOW that happened. [X-(] Removal instructions of this product as listed on the Krylon web site call for laquer thinner. Of course, a caution is noted and mentioned as the thinner might not only remove the Krylon but also all paints below it. [X-(] Does anyone have an idea as to how to remove this stuff without ruining the paint underneath? Part of the wheel well fender(?) looks like it has white measles. [ ![]() Regards, Liz [X-(] [X-(] Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
03-14-2006, 13:17
I was going to suggest a polishing compound used very sparingly, but
it sounds like you are already getting a chemical reaction. If that's true, you may be asking for help from a paint shop to sand and repaint with base paint and top coat. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Y'all. > > Jack accidentally got Kyrlon Fusion for Plastic spray paint on the Bird. > [X-(] [X-(] [X-(] I won't even go into HOW that happened. [X-(] > Removal instructions of this product as listed on the Krylon web site > call for laquer thinner. Of course, a caution is noted and mentioned as > the thinner might not only remove the Krylon but also all paints below > it. [X-(] Does anyone have an idea as to how to remove this stuff > without ruining the paint underneath? Part of the wheel well fender(?) > looks like it has white measles. [ ![]() > > Regards, > Liz [X-(] [X-(] > > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > > > > > > > > [Non-text portions of this message have been removed] > |
03-14-2006, 13:45
first question how big are the measles
If it were me iwould dab the the spots with thinners applied witha q-tip with a rag at the ready top immediately wipe the thinners away Iwould only dampen the qtip NOT sopping or dripping wet try and soften the krylon only then gently try to pick it off using a toothpick do not dig at it Try it on area or spot or measle that is hopefully in a spot that is not to noticeable down near the bottom of the wheel well or fender You could also try wiping on with a damp rag and wiping off with a dry clean rag but you will have to be quick to break the krylon without melting the clear it can be done. It should be removed before krylon cures completely If unsure about all of this take to a paint shop 1. hang head in embarassement 2. ask the paint guy for help. 3.You may be surprised it may only cost you a case of beer remember always use spray cans standing with back to coach in no wind conditions or use neighbours coach for back splash Good luck in your task Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Y'all. > > Jack accidentally got Kyrlon Fusion for Plastic spray paint on the Bird. > [X-(] [X-(] [X-(] I won't even go into HOW that happened. [X-(] > Removal instructions of this product as listed on the Krylon web site > call for laquer thinner. Of course, a caution is noted and mentioned as > the thinner might not only remove the Krylon but also all paints below > it. [X-(] Does anyone have an idea as to how to remove this stuff > without ruining the paint underneath? Part of the wheel well fender(?) > looks like it has white measles. [ ![]() > > Regards, > Liz [X-(] [X-(] > > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > > > > > > > > [Non-text portions of this message have been removed] > |
03-14-2006, 13:51
If it's just over spray, you can try "auto detailing clay bar".Works
great on tar, sap, and over spray. Robert Britton 87FC Tres Pinos Ca. --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Y'all. > > Jack accidentally got Kyrlon Fusion for Plastic spray paint on the Bird. > [X-(] [X-(] [X-(] I won't even go into HOW that happened. [X-(] > Removal instructions of this product as listed on the Krylon web site > call for laquer thinner. Of course, a caution is noted and mentioned as > the thinner might not only remove the Krylon but also all paints below > it. [X-(] Does anyone have an idea as to how to remove this stuff > without ruining the paint underneath? Part of the wheel well fender (?) > looks like it has white measles. [ ![]() > > Regards, > Liz [X-(] [X-(] > > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > > > > > > > > [Non-text portions of this message have been removed] > |
03-14-2006, 15:24
--- In WanderlodgeForum@yahoogroups.com, "Robert Britton"
> > If it's just over spray, you can try "auto detailing clay bar".Works > great on tar, sap, and over spray. > > Robert Britton > 87FC > Tres Pinos Ca. > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > > > > Howdy, Y'all. > > > > Jack accidentally got Kyrlon Fusion for Plastic spray paint on the > Bird. > > [X-(] [X-(] [X-(] I won't even go into HOW that happened. > [X-(] > > Removal instructions of this product as listed on the Krylon web > site > > call for laquer thinner. Of course, a caution is noted and > mentioned as > > the thinner might not only remove the Krylon but also all paints > below > > it. [X-(] Does anyone have an idea as to how to remove this stuff > > without ruining the paint underneath? Part of the wheel well fender > (?) > > looks like it has white measles. [ ![]() > > > > Regards, > > Liz [X-(] [X-(] > > > > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 Wanderlodge WB40 > > Homesick Texans in SE. FL I don't know what happen but I would try the Butal Alcohol thinner before I would try the Lacquer thinner. Jon Bremerton > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
03-14-2006, 16:35
I don't know if it will work in your particular case but I have removed graffiti
spray paint on a chevy (was sprayed the night before) with DriWash n'Guard. It is a waterless car wash and it truly has to be seen to be believed. All you do is shake it, pump the bottle, spray it on, wipe it in a curcular motion and then lightly buff it. It cleans polishes and protects in that simple application! It is available from Independent distributors or directly from the company in las vegas. call 1-800-820-6893 and ask for a 16 oz bottle of Ultra-ion ( with a pump applicator) you will need pin#173077. Keep in mind that the longer the paint is on the more difficult it is to remove. But if Your vehicle had been cleaned with DriWash before the paint overspray......hmmm. Jim & Barb King Wanderlodge Wannabees Heyburn, Id email jking@... [Non-text portions of this message have been removed] |
03-14-2006, 17:18
Great stuff Jim, as a matter of fact I think Ron Marabito, a
moderator on this forum is a distributor for that product. I am sure he will chime in here. It is always good to support the forum members after all they freely give so much information from years of experience. Unlike myself, who is opinionated! Scott B 86FC SC --- In WanderlodgeForum@yahoogroups.com, "Jim King" > > I don't know if it will work in your particular case but I have removed graffiti spray paint on a chevy (was sprayed the night before) with DriWash n'Guard. It is a waterless car wash and it truly has to be seen to be believed. All you do is shake it, pump the bottle, spray it on, wipe it in a curcular motion and then lightly buff it. It cleans polishes and protects in that simple application! It is available from Independent distributors or directly from the company in las vegas. call 1-800-820-6893 and ask for a 16 oz bottle of Ultra-ion ( with a pump applicator) you will need pin#173077. > Keep in mind that the longer the paint is on the more difficult it is to remove. But if Your vehicle had been cleaned with DriWash before the paint overspray......hmmm. > Jim & Barb King > Wanderlodge Wannabees > Heyburn, Id > > email jking@... > > [Non-text portions of this message have been removed] > |
03-15-2006, 01:24
Hi Liz (shame on painter Jack) LOL we've all goofed!
A few months back I reported on replacement of the 3M plastic front material designed to protect the paint. In that endeavor I was stunned/shocked that the rather harsh and "hot" product, Xylene, was successful in removing the adhesive residue without damaging the coach paint - provided one didn't grind on it nor leave it on for an hour or so. With that experience, I became brave enough to use Xylene to remove a "nickle-sized" spray paint spot from a car fender. For some unknown origin and time, fine-spray (mist) paint on the coach, rubbing compound seemed to work well. John Suter --- Jack and Liz Pearce > Howdy, Y'all. > > Jack accidentally got Kyrlon Fusion for Plastic > spray paint on the Bird. > [X-(] [X-(] [X-(] I won't even go into HOW > that happened. [X-(] > Removal instructions of this product as listed on > the Krylon web site > call for laquer thinner. Of course, a caution is > noted and mentioned as > the thinner might not only remove the Krylon but > also all paints below > it. [X-(] Does anyone have an idea as to how to > remove this stuff > without ruining the paint underneath? Part of the > wheel well fender(?) > looks like it has white measles. [ ![]() > > Regards, > Liz [X-(] [X-(] > > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > > > > > > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-15-2006, 02:00
Scott:
I've not had occasion to use Dri-Wash in that application, but could attest to the fact that had it been applied before hand, the chore would have been much easier. I could send a sample to Jack but he needs to get that stuff off now and not later. Longer it stays in place, the harder it will be. Actually, Oxygone, another product might do a better job in this case. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Scott" > > Great stuff Jim, as a matter of fact I think Ron Marabito, a > moderator on this forum is a distributor for that product. I am sure > he will chime in here. It is always good to support the forum members > after all they freely give so much information from years of > experience. Unlike myself, who is opinionated! > > Scott B > 86FC > SC > --- In WanderlodgeForum@yahoogroups.com, "Jim King" > > > > I don't know if it will work in your particular case but I have > removed graffiti spray paint on a chevy (was sprayed the night > before) with DriWash n'Guard. It is a waterless car wash and it truly > has to be seen to be believed. All you do is shake it, pump the > bottle, spray it on, wipe it in a curcular motion and then lightly > buff it. It cleans polishes and protects in that simple application! > It is available from Independent distributors or directly from the > company in las vegas. call 1-800-820-6893 and ask for a 16 oz > bottle of Ultra-ion ( with a pump applicator) you will need > pin#173077. > > Keep in mind that the longer the paint is on the more difficult > it is to remove. But if Your vehicle had been cleaned with DriWash > before the paint overspray......hmmm. > > Jim & Barb King > > Wanderlodge Wannabees > > Heyburn, Id > > > > email jking@ > > > > [Non-text portions of this message have been removed] > > > |
03-15-2006, 02:30
John, great info as usual. Being in the marine business we frequently
use Acetone, to remove overspray, tape residue etc. If the coach is painted with imron (as mine is) then I do not think serious/permanent damage to the finish would occur. After all MOST yachts, and many boats are painted with either imron or awlgrip. I agree both chemicals are somewhat harsh and caution should be used. Although if some care is excersized either one should work. I am sure either product can easily be purchased in any paint dept of the major home improvement stores. Scott B 86FC35 "RUBY" Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > > Hi Liz (shame on painter Jack) LOL we've all goofed! > > A few months back I reported on replacement of the > 3M plastic front material designed to protect the > paint. In that endeavor I was stunned/shocked that > the rather harsh and "hot" product, Xylene, was > successful in removing the adhesive residue without > damaging the coach paint - provided one didn't grind > on it nor leave it on for an hour or so. With that > experience, I became brave enough to use Xylene to > remove a "nickle-sized" spray paint spot from a car > fender. For some unknown origin and time, fine-spray > (mist) paint on the coach, rubbing compound seemed to > work well. > > John Suter > > > --- Jack and Liz Pearce > > > Howdy, Y'all. > > > > Jack accidentally got Kyrlon Fusion for Plastic > > spray paint on the Bird. > > [X-(] [X-(] [X-(] I won't even go into HOW > > that happened. [X-(] > > Removal instructions of this product as listed on > > the Krylon web site > > call for laquer thinner. Of course, a caution is > > noted and mentioned as > > the thinner might not only remove the Krylon but > > also all paints below > > it. [X-(] Does anyone have an idea as to how to > > remove this stuff > > without ruining the paint underneath? Part of the > > wheel well fender(?) > > looks like it has white measles. [ ![]() > > > > Regards, > > Liz [X-(] [X-(] > > > > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 Wanderlodge WB40 > > Homesick Texans in SE. FL > > > > > > > > > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
