Front upper dash TV
11-07-2005, 12:44
Front upper dash TV
we will probably leave on the 2nd. Don't know the exact time, yet. Ernie in
weatherford
-----Original Message-----
Sent: Mon, 07 Nov 2005 20:47:48 -0000
Subject: [WanderlodgeForum] Re: Front upper dash TV
Ernie, Glad you made it back home ok. Are you going to make it to
the rally? What day are you leaving if you are? We are leaving on
the 1st of December.Tell Brenda hi for us.
Best Regards,
Rick & Terri Mcintire
86PT38 Patillo,Tx
- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote:
> Ed, you are close by. You going to the Boerne rally? Ernie-83pt40
in Weatherford
> From: ED GARDELS
> Sent: Mon, 07 Nov 2005 18:11:33 -0000
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss"
<mbulriss@y...>
> > Hi Ed,
> > It would help if you would sign your posts and indicate what
model
> you
> > have so that we can response more accurately. For instance, if
you
> > are talking about the backup monitor/TV in an 83 PT, the answer
is
> > that the monitor is connected to the upper dash housing by four
> screws
> > around the front of the monitor. Disconnect high power cable
> lift
> > out. So, what model are you talking about? And, is it the
> TV/backup
> > monitor or a separate TV?
> > Thanks,
> SORRY about not signing, I noticed my mistake as soon as I sent it.
> (89sp) and I guess its probably the OVERHEAD dash. Imnew at this
as
> Ive only had my bb for a few months(2 trips). Dont know much about
> it, I readthe forum and trial and error.see msg 6340 for
> signing.Thanks for the reply.
> ED GARDELS 89SP
> ARLINGTON, TEXAS
> > Mike Bulriss
> > 83 PT40 "Stagecoach" - For Sale - with Financing!
> > 91 PT40 "Texas Minivan"
> > San Antonio, TX
> > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
> > wrote:
> > > Is the TV connected(screwed)to the plywood base it sits on? I
am
> > > trying to replace it. Have already took off metal strap over
tv.
> Also
> > > does the tv come out the rear with base attached, or through
> front?
> Yahoo! Groups Links
Yahoo! Groups Links
11-07-2005, 14:28
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> --- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly
> recommend it. made a metal frame etc.
> recommend a 24 in LCD with the speaker ON the bottom..It will
fit..u
> can get a 24 inch for what I paid for 20 Inch....
> regards,
> Hank Hannigan
> 90SP36
Hank-- thanks for the input.I finnaly got the original out
today.There is 19.5 inches between the doors. How would a 24" fit?
Don said he put in a 20" also. Might go shopping tommorrow.
thanks
Ed Gardels 89sp
Arlington,Tx
am
tv.
> > Also
> > front?
> > Forgot to mention its a 89sp.
11-07-2005, 14:29
Front upper dash TV
fit..u
> regards,
> Hank Hannigan
> 90SP36
thanks
Ed Gardels 89sp
Arlington,Tx
am
tv.
> > Also
> > front?
11-07-2005, 15:34
Front upper dash TV
Ed:
Some owners have modified the overhead slightly and put in larger flat
screens. The installs look good too.
Safe travels,
>fit..u
> > regards,
> > Hank Hannigan
> > 90SP36
> thanks
> Ed Gardels 89sp
> Arlington,Tx
11-07-2005, 16:50
Front upper dash TV
---ED: I am away from BIRD right now but I figured a 24 would fit IF
I found one with speaker on bottom........thought more than 20
inches door to door.
maybe the 90 is different.
later,
Hank
90SP36
In Hawaii
> fit..u
> > regards,
> > Hank Hannigan
> > 90SP36
> thanks
> Ed Gardels 89sp
> Arlington,Tx
I
> am
> tv.
> > > Also
> the
> > > front?
11-07-2005, 20:10
Front upper dash TV
Hank I had to settle for the 20'' between the door of my 89 SP 36. It was
just a little under if I remember right. The 20" Sharp just fit & got the
doors open & the speakers were not on the side& it was not the wide screen.
Don
89 SP 36'
Butler, PA
11-08-2005, 18:24
Front upper dash TV
---DON:
I put in a 20 inch ZENITH with speakers on each SIDE.....the 90 SP
must have different width between doors
Regards,
Hank
90SP36
36. It was
got the
wide screen.
> Don
> 89 SP 36'
> Butler, PA
User(s) browsing this thread: 12 Guest(s)
