Trojan Batteries And Chargers
02-04-2006, 08:07
Hello, Fred. According to the Trojan Web Site the dimentions are
identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an inch taller with the same footprint. I do not know what a Blue Point filler is. Sounds interesting though. I fill my batteries with a baster and an eye droper. I get the job done eventually, with minimum spilliage and believe I can do the same with the taller T-145's in my '78 FC. I still have not priced the T-145's, but they are a nice jump in AH's, at 12VDC you can add a useable 70 AH's !! -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote: > > I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > battery filler just fits. > > How do you top off your batteries with the added height of the T 145s, > have you found a lower profile battery filler? > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > Hi James I have four T-145's in my house compartment up front & > they work good for me. I have had them in for two years. Just make > sure you have the room for the higher batteries in the compartment. > They are in a 89 SP 36'. I had T-105's in my 79 FC that worked good also. > > Don 89 SP 36' > > Butler, PA in Zephyrhills FL right now > > > > -----Original Message----- > > From: orbitalsolutions > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > > > > > I just finished looking at the Trojan Web Site. There are three models > > that I want to talk about -- T-105, T-125, T-145. > > > > > > > > These are all identical in dimensions with the only exception being that > > the T-145 is slightly less than an inch taller. > > > > > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. > > > > > > > > The only other difference is their weight -- T-105 = 60lbs, T- 125 = > > 66lbs, T-145 = 72lbs. > > > > > > > > Seems like the heavier models have larger plates and should have > > greater durability, I suppose, more Amp Hours for sure. So I am > > wondering why everyone uses the T-105's? Is there a problem with using > > the higher reated models? > > > > > > > > If any one has any input on a new charge/converter to replace the > > original I would appreciate it. the original charger/converter works > > fine but I have been told that it will boil the batteries. In fact, the > > previous owner of my bus has a timer in line with the charger to prevent > > it from running full time when the bus is "pluged in." This actually > > works fine but I'm assuming that it is a one stage charger and was > > wondering if it would make sense to replace it with a modern 3 stage > > job. |
02-04-2006, 08:46
James, My 145's cost $397.50 for four with .06/% sales tax in PA two years ago
& i water mine with a Baster also. Want to install a fill system later on. Don 89 SP 36' Butler, PA In Zephyrhills FL right now -----Original Message----- From: orbitalsolutions To: WanderlodgeForum@yahoogroups.com Sent: Sat, 04 Feb 2006 20:07:41 -0000 Subject: [WanderlodgeForum] Re: Trojan Batteries And Chargers Hello, Fred. According to the Trojan Web Site the dimentions are identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an inch taller with the same footprint. I do not know what a Blue Point filler is. Sounds interesting though. I fill my batteries with a baster and an eye droper. I get the job done eventually, with minimum spilliage and believe I can do the same with the taller T-145's in my '78 FC. I still have not priced the T-145's, but they are a nice jump in AH's, at 12VDC you can add a useable 70 AH's !! -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote: > > I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > battery filler just fits. > > How do you top off your batteries with the added height of the T 145s, > have you found a lower profile battery filler? > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > Hi James I have four T-145's in my house compartment up front & > they work good for me. I have had them in for two years. Just make > sure you have the room for the higher batteries in the compartment. > They are in a 89 SP 36'. I had T-105's in my 79 FC that worked good also. > > Don 89 SP 36' > > Butler, PA in Zephyrhills FL right now > > > > -----Original Message----- > > From: orbitalsolutions > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > > > > > I just finished looking at the Trojan Web Site. There are three models > > that I want to talk about -- T-105, T-125, T-145. > > > > > > > > These are all identical in dimensions with the only exception being that > > the T-145 is slightly less than an inch taller. > > > > > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. > > > > > > > > The only other difference is their weight -- T-105 = 60lbs, T- 125 = > > 66lbs, T-145 = 72lbs. > > > > > > > > Seems like the heavier models have larger plates and should have > > greater durability, I suppose, more Amp Hours for sure. So I am > > wondering why everyone uses the T-105's? Is there a problem with using > > the higher reated models? > > > > > > > > If any one has any input on a new charge/converter to replace the > > original I would appreciate it. the original charger/converter works > > fine but I have been told that it will boil the batteries. In fact, the > > previous owner of my bus has a timer in line with the charger to prevent > > it from running full time when the bus is "pluged in." This actually > > works fine but I'm assuming that it is a one stage charger and was > > wondering if it would make sense to replace it with a modern 3 stage > > job. Yahoo! Groups Links [Non-text portions of this message have been removed] |
02-04-2006, 10:07
Why not install a single point battery watering system
Stephen 77 fc 35 http://www.capeinnovation.com --- In WanderlodgeForum@yahoogroups.com, "fred89sp" > > I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > battery filler just fits. > > How do you top off your batteries with the added height of the T 145s, > have you found a lower profile battery filler? > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > Hi James I have four T-145's in my house compartment up front & > they work good for me. I have had them in for two years. Just make > sure you have the room for the higher batteries in the compartment. > They are in a 89 SP 36'. I had T-105's in my 79 FC that worked good also. > > Don 89 SP 36' > > Butler, PA in Zephyrhills FL right now > > > > -----Original Message----- > > From: orbitalsolutions > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > > > > > I just finished looking at the Trojan Web Site. There are three models > > that I want to talk about -- T-105, T-125, T-145. > > > > > > > > These are all identical in dimensions with the only exception being that > > the T-145 is slightly less than an inch taller. > > > > > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. > > > > > > > > The only other difference is their weight -- T-105 = 60lbs, T-125 = > > 66lbs, T-145 = 72lbs. > > > > > > > > Seems like the heavier models have larger plates and should have > > greater durability, I suppose, more Amp Hours for sure. So I am > > wondering why everyone uses the T-105's? Is there a problem with using > > the higher reated models? > > > > > > > > If any one has any input on a new charge/converter to replace the > > original I would appreciate it. the original charger/converter works > > fine but I have been told that it will boil the batteries. In fact, the > > previous owner of my bus has a timer in line with the charger to prevent > > it from running full time when the bus is "pluged in." This actually > > works fine but I'm assuming that it is a one stage charger and was > > wondering if it would make sense to replace it with a modern 3 stage > > job. > > > > > > > > Also it appears that the charger and the converter are two seperate > > units that were originally mounted next to each other in a road side > > bay. I have no problems with the converter at all. Are all newer units > > combo charger/converters? Would it make sense to only up grade the > > charger? Is that even possible? Whats the best type of charger to use? > > > > > > > > Thanks in advance. > > > > > > > > -James > > > > 78FC33SB -- LasVegas NV > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
02-04-2006, 10:23
Thanks, Don. The cheapest price I've found on the T-105's is $69.
Sounds like about $30 dollars more per battery. I'm just starting to figure out how to upgrade my DC system from the original configuration. It's not easy for me to get a grasp on the performance of the practical application. I mean to say, if the bank is 50% depleted, with the T-145's you would need to replace 260 AH to get a full charge. If you had the AGM replacements that cost $209 a piece, you would have to replace 220AH for a full charge. Being that the final 10% charge takes forever(scientific term) in a practical application you would only charge them up to about 85% - 90%. The big advantage of AGM types, besides no acid or filling required, is that they supposedly will accept a charge must faster than the conventional lead-acid battterys. So what I want to know is this... Given that I have (2) 55Amp 3 stage temperture sensing chargers. How long(amount of generator running time) would be required to bring both the above mentioned banks to an 85% - 90% charge? Thanks in advance, I actually remember Ohm's law if that will help anyone. -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > James, My 145's cost $397.50 for four with .06/% sales tax in PA two years ago & i water mine with a Baster also. Want to install a fill system later on. > Don > 89 SP 36' > Butler, PA In Zephyrhills FL right now > > -----Original Message----- > From: orbitalsolutions > To: WanderlodgeForum@yahoogroups.com > Sent: Sat, 04 Feb 2006 20:07:41 -0000 > Subject: [WanderlodgeForum] Re: Trojan Batteries And Chargers > > > Hello, Fred. According to the Trojan Web Site the dimentions are > identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an > inch taller with the same footprint. > > I do not know what a Blue Point filler is. Sounds interesting > though. I fill my batteries with a baster and an eye droper. I get > the job done eventually, with minimum spilliage and believe I can do > the same with the taller T-145's in my '78 FC. > > I still have not priced the T-145's, but they are a nice jump in > AH's, at 12VDC you can add a useable 70 AH's !! > > -James > 78FC33SB > LasVegas NV > > > --- In WanderlodgeForum@yahoogroups.com, "fred89sp" > wrote: > > > > I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > > battery filler just fits. > > > > How do you top off your batteries with the added height of the T > 145s, > > have you found a lower profile battery filler? > > > > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > > > Hi James I have four T-145's in my house compartment up front > & > > they work good for me. I have had them in for two years. Just make > > sure you have the room for the higher batteries in the compartment. > > They are in a 89 SP 36'. I had T-105's in my 79 FC that worked > good also. > > > Don 89 SP 36' > > > Butler, PA in Zephyrhills FL right now > > > > > > -----Original Message----- > > > From: orbitalsolutions > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > > > > > > > > > I just finished looking at the Trojan Web Site. There are three > models > > > that I want to talk about -- T-105, T-125, T-145. > > > > > > > > > > > > These are all identical in dimensions with the only exception > being that > > > the T-145 is slightly less than an inch taller. > > > > > > > > > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = > 260AH. > > > > > > > > > > > > The only other difference is their weight -- T-105 = 60lbs, T- > 125 = > > > 66lbs, T-145 = 72lbs. > > > > > > > > > > > > Seems like the heavier models have larger plates and should have > > > greater durability, I suppose, more Amp Hours for sure. So I am > > > wondering why everyone uses the T-105's? Is there a problem with > using > > > the higher reated models? > > > > > > > > > > > > If any one has any input on a new charge/converter to replace the > > > original I would appreciate it. the original charger/converter > works > > > fine but I have been told that it will boil the batteries. In > fact, the > > > previous owner of my bus has a timer in line with the charger to > prevent > > > it from running full time when the bus is "pluged in." This > actually > > > works fine but I'm assuming that it is a one stage charger and > was > > > wondering if it would make sense to replace it with a modern 3 > stage > > > job. > > > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > |
02-04-2006, 11:06
James,
A couple of thoughts: The best way to fill the batteries is to use an automatic fill device such as came standard on our Alpine Apex. All you have to do is flip a switch until the float indicators tell you all cells are full. You can't overfill. System holds around a gallon of distilled water. Before we got this, we used a douche/enema bag. holds a quart of water and is easy to control. If you want to add to usable capacity, if you have not already added a three stage charging system, do that. A standard single stage charger will only fill the battery to approximately 85% of its AH capacity. Since you should not discharge to less that 50% of capacity, you have lost 30% of usable right off the top. The three stage charger will charge to 100% of capacity gaining you that 30% in usable capacity. Not only do you get more usable battery capacity but the batteries will last longer also. George Lowry '06 Alpine Apex - Former owner '95 WBDA 4203 Spearfish, SD enjoying the warmth in Palm Springs. orbitalsolutions wrote: >Hello, Fred. According to the Trojan Web Site the dimentions are >identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an >inch taller with the same footprint. > >I do not know what a Blue Point filler is. Sounds interesting >though. I fill my batteries with a baster and an eye droper. I get >the job done eventually, with minimum spilliage and believe I can do >the same with the taller T-145's in my '78 FC. > >I still have not priced the T-145's, but they are a nice jump in >AH's, at 12VDC you can add a useable 70 AH's !! > >-James >78FC33SB >LasVegas NV > > >--- In WanderlodgeForum@yahoogroups.com, "fred89sp" >wrote: > > >>I have T 125s (taller than the T 105s) in my 89SP and my Blue Point >>battery filler just fits. >> >>How do you top off your batteries with the added height of the T >> >> >145s, > > >>have you found a lower profile battery filler? >> >> >>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: >> >> >>>Hi James I have four T-145's in my house compartment up front >>> >>> >& > > >>they work good for me. I have had them in for two years. Just make >>sure you have the room for the higher batteries in the compartment. >>They are in a 89 SP 36'. I had T-105's in my 79 FC that worked >> >> >good also. > > >>> Don 89 SP 36' >>> Butler, PA in Zephyrhills FL right now >>> >>>-----Original Message----- >>>From: orbitalsolutions >>>To: WanderlodgeForum@yahoogroups.com >>>Sent: Wed, 01 Feb 2006 01:44:43 -0000 >>>Subject: [WanderlodgeForum] Trojan Batteries And Chargers >>> >>> >>> >>>I just finished looking at the Trojan Web Site. There are three >>> >>> >models > > >>>that I want to talk about -- T-105, T-125, T-145. >>> >>> >>> >>>These are all identical in dimensions with the only exception >>> >>> >being that > > >>>the T-145 is slightly less than an inch taller. >>> >>> >>> >>>Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = >>> >>> >260AH. > > >>> >>>The only other difference is their weight -- T-105 = 60lbs, T- >>> >>> >125 = > > >>>66lbs, T-145 = 72lbs. >>> >>> >>> >>>Seems like the heavier models have larger plates and should have >>>greater durability, I suppose, more Amp Hours for sure. So I am >>>wondering why everyone uses the T-105's? Is there a problem with >>> >>> >using > > >>>the higher reated models? >>> >>> >>> >>>If any one has any input on a new charge/converter to replace the >>>original I would appreciate it. the original charger/converter >>> >>> >works > > >>>fine but I have been told that it will boil the batteries. In >>> >>> >fact, the > > >>>previous owner of my bus has a timer in line with the charger to >>> >>> >prevent > > >>>it from running full time when the bus is "pluged in." This >>> >>> >actually > > >>>works fine but I'm assuming that it is a one stage charger and >>> >>> >was > > >>>wondering if it would make sense to replace it with a modern 3 >>> >>> >stage > > >>>job. >>> >>> > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > |
02-04-2006, 11:21
you can use a single point battery watering system
I have them Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, George Lowry > > James, > > A couple of thoughts: The best way to fill the batteries is to use an > automatic fill device such as came standard on our Alpine Apex. All you > have to do is flip a switch until the float indicators tell you all > cells are full. You can't overfill. System holds around a gallon of > distilled water. Before we got this, we used a douche/enema bag. holds > a quart of water and is easy to control. > > If you want to add to usable capacity, if you have not already added a > three stage charging system, do that. A standard single stage charger > will only fill the battery to approximately 85% of its AH capacity. > Since you should not discharge to less that 50% of capacity, you have > lost 30% of usable right off the top. The three stage charger will > charge to 100% of capacity gaining you that 30% in usable capacity. > Not only do you get more usable battery capacity but the batteries will > last longer also. > > George Lowry > '06 Alpine Apex - Former owner '95 WBDA 4203 > Spearfish, SD enjoying the warmth in Palm Springs. > > orbitalsolutions wrote: > > >Hello, Fred. According to the Trojan Web Site the dimentions are > >identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an > >inch taller with the same footprint. > > > >I do not know what a Blue Point filler is. Sounds interesting > >though. I fill my batteries with a baster and an eye droper. I get > >the job done eventually, with minimum spilliage and believe I can do > >the same with the taller T-145's in my '78 FC. > > > >I still have not priced the T-145's, but they are a nice jump in > >AH's, at 12VDC you can add a useable 70 AH's !! > > > >-James > >78FC33SB > >LasVegas NV > > > > > >--- In WanderlodgeForum@yahoogroups.com, "fred89sp" > >wrote: > > > > > >>I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > >>battery filler just fits. > >> > >>How do you top off your batteries with the added height of the T > >> > >> > >145s, > > > > > >>have you found a lower profile battery filler? > >> > >> > >>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > >> > >> > >>>Hi James I have four T-145's in my house compartment up front > >>> > >>> > >& > > > > > >>they work good for me. I have had them in for two years. Just make > >>sure you have the room for the higher batteries in the compartment. > >>They are in a 89 SP 36'. I had T-105's in my 79 FC that worked > >> > >> > >good also. > > > > > >>> Don 89 SP 36' > >>> Butler, PA in Zephyrhills FL right now > >>> > >>>-----Original Message----- > >>>From: orbitalsolutions > >>>To: WanderlodgeForum@yahoogroups.com > >>>Sent: Wed, 01 Feb 2006 01:44:43 -0000 > >>>Subject: [WanderlodgeForum] Trojan Batteries And Chargers > >>> > >>> > >>> > >>>I just finished looking at the Trojan Web Site. There are three > >>> > >>> > >models > > > > > >>>that I want to talk about -- T-105, T-125, T-145. > >>> > >>> > >>> > >>>These are all identical in dimensions with the only exception > >>> > >>> > >being that > > > > > >>>the T-145 is slightly less than an inch taller. > >>> > >>> > >>> > >>>Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = > >>> > >>> > >260AH. > > > > > >>> > >>>The only other difference is their weight -- T-105 = 60lbs, T- > >>> > >>> > >125 = > > > > > >>>66lbs, T-145 = 72lbs. > >>> > >>> > >>> > >>>Seems like the heavier models have larger plates and should have > >>>greater durability, I suppose, more Amp Hours for sure. So I am > >>>wondering why everyone uses the T-105's? Is there a problem with > >>> > >>> > >using > > > > > >>>the higher reated models? > >>> > >>> > >>> > >>>If any one has any input on a new charge/converter to replace the > >>>original I would appreciate it. the original charger/converter > >>> > >>> > >works > > > > > >>>fine but I have been told that it will boil the batteries. In > >>> > >>> > >fact, the > > > > > >>>previous owner of my bus has a timer in line with the charger to > >>> > >>> > >prevent > > > > > >>>it from running full time when the bus is "pluged in." This > >>> > >>> > >actually > > > > > >>>works fine but I'm assuming that it is a one stage charger and > >>> > >>> > >was > > > > > >>>wondering if it would make sense to replace it with a modern 3 > >>> > >>> > >stage > > > > > >>>job. > >>> > >>> > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > |
02-04-2006, 12:05
Sounds good, Steve. I will talk to you further about the fill
system if I decide to go with the T-145's. I'm confused about conventional lead-acid and the new AGM batteries. I am trying to understand the practical differences in charging time to bring a bank up from a 50% discharge. Lifeline Co. has a 6V AGM that is a perfect repacement. At 6 volts they are rated at 220AH. Four of these babies will give me a total of 440AH @ 12V. I like the idea of a sealed power cell, but I have lived with Trojans for many years. What I would like to know is if there is a shorter charge time needed for AGM than the Trojans, given a fixed charge rate of 110A 3 stage temperature sensitive charge. I think George Lowery might be able to help me(if that's possible). George, in your new Apex I believe you have Lifeline AGM's. If so, is the value of the battery bank 12V? What is the total AH rating of the bank? At a 50% discharge, how long do you have to run your genny to get a full charge? Lastly, How many amps are you charging them with? AGM's may be worth the price to me if they redeuce the charge time compared to the Trojans. I hve been informed, by theory experts, that the rate of charge of AGM types is unlimited, but I do not want to spent 1500 dollars for chargers. I am going to replace the originals with (2) 55A 3 stage temp sensing chargers. That gives me a charging total of 110Amps. Will these chargers take a 50% depleted AGM bank to full considerably faster than if they were charging the Trojans? Theory is just that. I am interested in practical application results, and have no refrence points. Still scratching my head and learning. -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > you can use a single point battery watering system > I have them > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > > > > James, > > > > A couple of thoughts: The best way to fill the batteries is to use an > > automatic fill device such as came standard on our Alpine Apex. All you > > have to do is flip a switch until the float indicators tell you all > > cells are full. You can't overfill. System holds around a gallon of > > distilled water. Before we got this, we used a douche/enema bag. holds > > a quart of water and is easy to control. > > > > If you want to add to usable capacity, if you have not already added a > > three stage charging system, do that. A standard single stage charger > > will only fill the battery to approximately 85% of its AH capacity. > > Since you should not discharge to less that 50% of capacity, you have > > lost 30% of usable right off the top. The three stage charger will > > charge to 100% of capacity gaining you that 30% in usable capacity. > > Not only do you get more usable battery capacity but the batteries will > > last longer also. > > > > George Lowry > > '06 Alpine Apex - Former owner '95 WBDA 4203 > > Spearfish, SD enjoying the warmth in Palm Springs. > > > > orbitalsolutions wrote: > > > > >Hello, Fred. According to the Trojan Web Site the dimentions are > > >identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an > > >inch taller with the same footprint. > > > > > >I do not know what a Blue Point filler is. Sounds interesting > > >though. I fill my batteries with a baster and an eye droper. I get > > >the job done eventually, with minimum spilliage and believe I can do > > >the same with the taller T-145's in my '78 FC. > > > > > >I still have not priced the T-145's, but they are a nice jump in > > >AH's, at 12VDC you can add a useable 70 AH's !! > > > > > >-James > > >78FC33SB > > >LasVegas NV > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "fred89sp" > > >wrote: > > > > > > > > >>I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > > >>battery filler just fits. > > >> > > >>How do you top off your batteries with the added height of the T > > >> > > >> > > >145s, > > > > > > > > >>have you found a lower profile battery filler? > > >> > > >> > > >>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > >> > > >> > > >>>Hi James I have four T-145's in my house compartment up front > > >>> > > >>> > > >& > > > > > > > > >>they work good for me. I have had them in for two years. Just make > > >>sure you have the room for the higher batteries in the compartment. > > >>They are in a 89 SP 36'. I had T-105's in my 79 FC that worked > > >> > > >> > > >good also. > > > > > > > > >>> Don 89 SP 36' > > >>> Butler, PA in Zephyrhills FL right now > > >>> > > >>>-----Original Message----- > > >>>From: orbitalsolutions > > >>>To: WanderlodgeForum@yahoogroups.com > > >>>Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > >>>Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > >>> > > >>> > > >>> > > >>>I just finished looking at the Trojan Web Site. There are three > > >>> > > >>> > > >models > > > > > > > > >>>that I want to talk about -- T-105, T-125, T-145. > > >>> > > >>> > > >>> > > >>>These are all identical in dimensions with the only exception > > >>> > > >>> > > >being that > > > > > > > > >>>the T-145 is slightly less than an inch taller. > > >>> > > >>> > > >>> > > >>>Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T- 145 = > > >>> > > >>> > > >260AH. > > > > > > > > >>> > > >>>The only other difference is their weight -- T-105 = 60lbs, T- > > >>> > > >>> > > >125 = > > > > > > > > >>>66lbs, T-145 = 72lbs. > > >>> > > >>> > > >>> > > >>>Seems like the heavier models have larger plates and should have > > >>>greater durability, I suppose, more Amp Hours for sure. So I am > > >>>wondering why everyone uses the T-105's? Is there a problem with > > >>> > > >>> > > >using > > > > > > > > >>>the higher reated models? > > >>> > > >>> > > >>> > > >>>If any one has any input on a new charge/converter to replace the > > >>>original I would appreciate it. the original charger/converter > > >>> > > >>> > > >works > > > > > > > > >>>fine but I have been told that it will boil the batteries. In > > >>> > > >>> > > >fact, the > > > > > > > > >>>previous owner of my bus has a timer in line with the charger to > > >>> > > >>> > > >prevent > > > > > > > > >>>it from running full time when the bus is "pluged in." This > > >>> > > >>> > > >actually > > > > > > > > >>>works fine but I'm assuming that it is a one stage charger and > > >>> > > >>> > > >was > > > > > > > > >>>wondering if it would make sense to replace it with a modern 3 > > >>> > > >>> > > >stage > > > > > > > > >>>job. > > >>> > > >>> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
02-04-2006, 13:04
Hi James,
First thing to remember is: Everything in an RV is a compromise. Cost vs. convenience vs. life cycle vs. god only knows what. The most bang for the buck or AH per $$ is the lead acid batteries. The AGM (Absorbed Glass Mat) gives the next best and the Gel is the most expensive for the AH Capacity. For the house batteries, AH capacity is the determining factor. In this Alpine, they put Interstate lead acid wet batteries. I have never had good luck with Interstates but will try them until they fail. Also, we have only had this rig for two weeks and do not have enough experience with it to give a good analysis. In the GM bus we converted, I had four Trojan L-16 Batteries in series-parallel. That was the best I could fit in the space and for the cost. There are better batteries such as the Surette and the Rolls but the cost is prohibitive. When we bought the Wanderlodge, the dealer had replaced the Gell cells with Interstate Lead acid wet cells. Three boiled before we made it home and the other three followed soon after. Interstate refused to stand behind them. I replaced them with the East Penn Deka AGM (12V). The advantage was that no service was needed however, the AH capacity was lower. Those batteries have served well. Re: Charging: With a three stage charger, the charging rate varies. For most, with the battery at 70 degrees F, the first stage is commonly called the "bulk" stage. This means that the charger will pour in the full rate until the voltage raises to 14.4 volts. In the "acceptance" stage the voltage is maintained at 14.4V and the current rate (amps) decreases until it reaches some predetermined percentage of the battery capacity, usually around 2 - 4%. At that point, the voltage is reduced to the "float" voltage, around 13.5 - 13.7 volts. It normally took me about three hours to recharge the batteries after draining them to the 50% level. Hope this helps. I have just been called for dinner. If you have more questions, please ask. George Lowry '06 Alpine Apex - Former owner '95 WBDA 4203 Spearfish, SD in Palm Springs orbitalsolutions wrote: >Sounds good, Steve. I will talk to you further about the fill >system if I decide to go with the T-145's. > >I'm confused about conventional lead-acid and the new AGM >batteries. I am trying to understand the practical differences in >charging time to bring a bank up from a 50% discharge. > >Lifeline Co. has a 6V AGM that is a perfect repacement. At 6 volts >they are rated at 220AH. Four of these babies will give me a total >of 440AH @ 12V. I like the idea of a sealed power cell, but I have >lived with Trojans for many years. What I would like to know is if >there is a shorter charge time needed for AGM than the Trojans, >given a fixed charge rate of 110A 3 stage temperature sensitive >charge. > >I think George Lowery might be able to help me(if that's possible). > >George, in your new Apex I believe you have Lifeline AGM's. If so, >is the value of the battery bank 12V? What is the total AH rating >of the bank? At a 50% discharge, how long do you have to run your >genny to get a full charge? Lastly, How many amps are you charging >them with? > >AGM's may be worth the price to me if they redeuce the charge time >compared to the Trojans. I hve been informed, by theory experts, >that the rate of charge of AGM types is unlimited, but I do not want >to spent 1500 dollars for chargers. I am going to replace the >originals with (2) 55A 3 stage temp sensing chargers. > >That gives me a charging total of 110Amps. Will these chargers take >a 50% depleted AGM bank to full considerably faster than if they >were charging the Trojans? > >Theory is just that. I am interested in practical application >results, and have no refrence points. > >Still scratching my head and learning. > > >-James >78FC33SB >LasVegas NV > > >--- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > >>you can use a single point battery watering system >>I have them >>Stephen 77fc35 >> >>--- In WanderlodgeForum@yahoogroups.com, George Lowry >> >> >wrote: > > >>>James, >>> >>>A couple of thoughts: The best way to fill the batteries is to >>> >>> >use an > > >>>automatic fill device such as came standard on our Alpine Apex. >>> >>> >All you > > >>>have to do is flip a switch until the float indicators tell you >>> >>> >all > > >>>cells are full. You can't overfill. System holds around a gallon >>> >>> >of > > >>>distilled water. Before we got this, we used a douche/enema >>> >>> >bag. holds > > >>>a quart of water and is easy to control. >>> >>>If you want to add to usable capacity, if you have not already >>> >>> >added a > > >>>three stage charging system, do that. A standard single stage >>> >>> >charger > > >>>will only fill the battery to approximately 85% of its AH >>> >>> >capacity. > > >>>Since you should not discharge to less that 50% of capacity, you >>> >>> >have > > >>>lost 30% of usable right off the top. The three stage charger >>> >>> >will > > >>>charge to 100% of capacity gaining you that 30% in usable >>> >>> >capacity. > > >>>Not only do you get more usable battery capacity but the >>> >>> >batteries will > > >>>last longer also. >>> >>>George Lowry >>>'06 Alpine Apex - Former owner '95 WBDA 4203 >>>Spearfish, SD enjoying the warmth in Palm Springs. >>> >>>orbitalsolutions wrote: >>> >>> >>> >>>>Hello, Fred. According to the Trojan Web Site the dimentions >>>> >>>> >are > > >>>>identical for the T-105 and the T-125. The T-145 is apx. 7/8 >>>> >>>> >of an > > >>>>inch taller with the same footprint. >>>> >>>>I do not know what a Blue Point filler is. Sounds interesting >>>>though. I fill my batteries with a baster and an eye droper. >>>> >>>> >I get > > >>>>the job done eventually, with minimum spilliage and believe I >>>> >>>> >can do > > >>>>the same with the taller T-145's in my '78 FC. >>>> >>>>I still have not priced the T-145's, but they are a nice jump >>>> >>>> >in > > >>>>AH's, at 12VDC you can add a useable 70 AH's !! >>>> >>>>-James >>>>78FC33SB >>>>LasVegas NV >>>> >>>> >>>>--- In WanderlodgeForum@yahoogroups.com, "fred89sp" >>>>wrote: >>>> >>>> >>>> >>>> >>>>>I have T 125s (taller than the T 105s) in my 89SP and my Blue >>>>> >>>>> >Point > > >>>>>battery filler just fits. >>>>> >>>>>How do you top off your batteries with the added height of the >>>>> >>>>> >T > > >>>>> >>>>> >>>>> >>>>> >>>>145s, >>>> >>>> >>>> >>>> >>>>>have you found a lower profile battery filler? >>>>> >>>>> >>>>>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: >>>>> >>>>> >>>>> >>>>> >>>>>>Hi James I have four T-145's in my house compartment up >>>>>> >>>>>> >front > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>& >>>> >>>> >>>> >>>> >>>>>they work good for me. I have had them in for two years. Just >>>>> >>>>> >make > > >>>>>sure you have the room for the higher batteries in the >>>>> >>>>> >compartment. > > >>>>>They are in a 89 SP 36'. I had T-105's in my 79 FC that worked >>>>> >>>>> >>>>> >>>>> >>>>good also. >>>> >>>> >>>> >>>> >>>>>>Don 89 SP 36' >>>>>>Butler, PA in Zephyrhills FL right now >>>>>> >>>>>>-----Original Message----- >>>>>>From: orbitalsolutions >>>>>>To: WanderlodgeForum@yahoogroups.com >>>>>>Sent: Wed, 01 Feb 2006 01:44:43 -0000 >>>>>>Subject: [WanderlodgeForum] Trojan Batteries And Chargers >>>>>> >>>>>> >>>>>> >>>>>>I just finished looking at the Trojan Web Site. There are >>>>>> >>>>>> >three > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>models >>>> >>>> >>>> >>>> >>>>>>that I want to talk about -- T-105, T-125, T-145. >>>>>> >>>>>> >>>>>> >>>>>>These are all identical in dimensions with the only exception >>>>>> >>>>>> >>>>>> >>>>>> >>>>being that >>>> >>>> >>>> >>>> >>>>>>the T-145 is slightly less than an inch taller. >>>>>> >>>>>> >>>>>> >>>>>>Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T- >>>>>> >>>>>> >145 = > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>260AH. >>>> >>>> >>>> >>>> >>>>>>The only other difference is their weight -- T-105 = 60lbs, T- >>>>>> >>>>>> >>>>>> >>>>>> >>>>125 = >>>> >>>> >>>> >>>> >>>>>>66lbs, T-145 = 72lbs. >>>>>> >>>>>> >>>>>> >>>>>>Seems like the heavier models have larger plates and should >>>>>> >>>>>> >have > > >>>>>>greater durability, I suppose, more Amp Hours for sure. So I >>>>>> >>>>>> >am > > >>>>>>wondering why everyone uses the T-105's? Is there a problem >>>>>> >>>>>> >with > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>using >>>> >>>> >>>> >>>> >>>>>>the higher reated models? >>>>>> >>>>>> >>>>>> >>>>>>If any one has any input on a new charge/converter to replace >>>>>> >>>>>> >the > > >>>>>>original I would appreciate it. the original >>>>>> >>>>>> >charger/converter > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>works >>>> >>>> >>>> >>>> >>>>>>fine but I have been told that it will boil the batteries. In >>>>>> >>>>>> >>>>>> >>>>>> >>>>fact, the >>>> >>>> >>>> >>>> >>>>>>previous owner of my bus has a timer in line with the charger >>>>>> >>>>>> >to > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>prevent >>>> >>>> >>>> >>>> >>>>>>it from running full time when the bus is "pluged in." This >>>>>> >>>>>> >>>>>> >>>>>> >>>>actually >>>> >>>> >>>> >>>> >>>>>>works fine but I'm assuming that it is a one stage charger >>>>>> >>>>>> >and > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>was >>>> >>>> >>>> >>>> >>>>>>wondering if it would make sense to replace it with a modern >>>>>> >>>>>> >3 > > >>>>>> >>>>>> >>>>>> >>>>>> >>>>stage >>>> >>>> >>>> >>>> >>>>>>job. >>>>>> >>>>>> >>>>>> >>>>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>Yahoo! Groups Links >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > |
02-04-2006, 13:31
You press this battery filler into the fill hole and it shuts off when
the cell gets to proper level. It is quick and easy. http://buy1.snapon.com/catalog/item.asp?...up_ID=1498 --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Hello, Fred. According to the Trojan Web Site the dimentions are > identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an > inch taller with the same footprint. > > I do not know what a Blue Point filler is. Sounds interesting > though. I fill my batteries with a baster and an eye droper. I get > the job done eventually, with minimum spilliage and believe I can do > the same with the taller T-145's in my '78 FC. > > I still have not priced the T-145's, but they are a nice jump in > AH's, at 12VDC you can add a useable 70 AH's !! > > -James > 78FC33SB > LasVegas NV > > > --- In WanderlodgeForum@yahoogroups.com, "fred89sp" > wrote: > > > > I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > > battery filler just fits. > > > > How do you top off your batteries with the added height of the T > 145s, > > have you found a lower profile battery filler? > > > > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > > > Hi James I have four T-145's in my house compartment up front > & > > they work good for me. I have had them in for two years. Just make > > sure you have the room for the higher batteries in the compartment. > > They are in a 89 SP 36'. I had T-105's in my 79 FC that worked > good also. > > > Don 89 SP 36' > > > Butler, PA in Zephyrhills FL right now > > > > > > -----Original Message----- > > > From: orbitalsolutions > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > > > > > > > > > I just finished looking at the Trojan Web Site. There are three > models > > > that I want to talk about -- T-105, T-125, T-145. > > > > > > > > > > > > These are all identical in dimensions with the only exception > being that > > > the T-145 is slightly less than an inch taller. > > > > > > > > > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = > 260AH. > > > > > > > > > > > > The only other difference is their weight -- T-105 = 60lbs, T- > 125 = > > > 66lbs, T-145 = 72lbs. > > > > > > > > > > > > Seems like the heavier models have larger plates and should have > > > greater durability, I suppose, more Amp Hours for sure. So I am > > > wondering why everyone uses the T-105's? Is there a problem with > using > > > the higher reated models? > > > > > > > > > > > > If any one has any input on a new charge/converter to replace the > > > original I would appreciate it. the original charger/converter > works > > > fine but I have been told that it will boil the batteries. In > fact, the > > > previous owner of my bus has a timer in line with the charger to > prevent > > > it from running full time when the bus is "pluged in." This > actually > > > works fine but I'm assuming that it is a one stage charger and > was > > > wondering if it would make sense to replace it with a modern 3 > stage > > > job. > |
02-04-2006, 13:42
Stephen,
What do these units cost? Thanks. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Stephen Birtles wrote: > you can use a single point battery watering system > I have them > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > > > > James, > > > > A couple of thoughts: The best way to fill the batteries is to use an > > automatic fill device such as came standard on our Alpine Apex. All you > > have to do is flip a switch until the float indicators tell you all > > cells are full. You can't overfill. System holds around a gallon of > > distilled water. Before we got this, we used a douche/enema bag. holds > > a quart of water and is easy to control. > > > > If you want to add to usable capacity, if you have not already added a > > three stage charging system, do that. A standard single stage charger > > will only fill the battery to approximately 85% of its AH capacity. > > Since you should not discharge to less that 50% of capacity, you have > > lost 30% of usable right off the top. The three stage charger will > > charge to 100% of capacity gaining you that 30% in usable capacity. > > Not only do you get more usable battery capacity but the batteries will > > last longer also. > > > > George Lowry > > '06 Alpine Apex - Former owner '95 WBDA 4203 > > Spearfish, SD enjoying the warmth in Palm Springs. > > > > orbitalsolutions wrote: > > > > >Hello, Fred. According to the Trojan Web Site the dimentions are > > >identical for the T-105 and the T-125. The T-145 is apx. 7/8 of an > > >inch taller with the same footprint. > > > > > >I do not know what a Blue Point filler is. Sounds interesting > > >though. I fill my batteries with a baster and an eye droper. I get > > >the job done eventually, with minimum spilliage and believe I can do > > >the same with the taller T-145's in my '78 FC. > > > > > >I still have not priced the T-145's, but they are a nice jump in > > >AH's, at 12VDC you can add a useable 70 AH's !! > > > > > >-James > > >78FC33SB > > >LasVegas NV > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "fred89sp" > > >wrote: > > > > > > > > >>I have T 125s (taller than the T 105s) in my 89SP and my Blue Point > > >>battery filler just fits. > > >> > > >>How do you top off your batteries with the added height of the T > > >> > > >> > > >145s, > > > > > > > > >>have you found a lower profile battery filler? > > >> > > >> > > >>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > >> > > >> > > >>>Hi James I have four T-145's in my house compartment up front > > >>> > > >>> > > >& > > > > > > > > >>they work good for me. I have had them in for two years. Just make > > >>sure you have the room for the higher batteries in the compartment. > > >>They are in a 89 SP 36'. I had T-105's in my 79 FC that worked > > >> > > >> > > >good also. > > > > > > > > >>> Don 89 SP 36' > > >>> Butler, PA in Zephyrhills FL right now > > >>> > > >>>-----Original Message----- > > >>>From: orbitalsolutions > > >>>To: WanderlodgeForum@yahoogroups.com > > >>>Sent: Wed, 01 Feb 2006 01:44:43 -0000 > > >>>Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > >>> > > >>> > > >>> > > >>>I just finished looking at the Trojan Web Site. There are three > > >>> > > >>> > > >models > > > > > > > > >>>that I want to talk about -- T-105, T-125, T-145. > > >>> > > >>> > > >>> > > >>>These are all identical in dimensions with the only exception > > >>> > > >>> > > >being that > > > > > > > > >>>the T-145 is slightly less than an inch taller. > > >>> > > >>> > > >>> > > >>>Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = > > >>> > > >>> > > >260AH. > > > > > > > > >>> > > >>>The only other difference is their weight -- T-105 = 60lbs, T- > > >>> > > >>> > > >125 = > > > > > > > > >>>66lbs, T-145 = 72lbs. > > >>> > > >>> > > >>> > > >>>Seems like the heavier models have larger plates and should have > > >>>greater durability, I suppose, more Amp Hours for sure. So I am > > >>>wondering why everyone uses the T-105's? Is there a problem with > > >>> > > >>> > > >using > > > > > > > > >>>the higher reated models? > > >>> > > >>> > > >>> > > >>>If any one has any input on a new charge/converter to replace the > > >>>original I would appreciate it. the original charger/converter > > >>> > > >>> > > >works > > > > > > > > >>>fine but I have been told that it will boil the batteries. In > > >>> > > >>> > > >fact, the > > > > > > > > >>>previous owner of my bus has a timer in line with the charger to > > >>> > > >>> > > >prevent > > > > > > > > >>>it from running full time when the bus is "pluged in." This > > >>> > > >>> > > >actually > > > > > > > > >>>works fine but I'm assuming that it is a one stage charger and > > >>> > > >>> > > >was > > > > > > > > >>>wondering if it would make sense to replace it with a modern 3 > > >>> > > >>> > > >stage > > > > > > > > >>>job. > > >>> > > >>> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
