Primus System
02-25-2006, 20:16
Primus System
Brian,
I have all of the manuals that came with the Primus on my 91. I will assume
for the sake of this email that the 91 and 93 are the same. I have usually
found the red fault light will flash on with ign of the burner then go out.
If it stays on the problem for me has been in the over temp switch in the
hoses behind the boilers. I have been told by BB and others to bypass this
system it is redundant. It is easy to by pass by putting a bayonet fuse in the
two wires. I had a tech a Foot hills RV in Taylorsville NC that put new
pumps on mine and it is running fine. he says it is one of the best heats in
RV's when it works right. Be sure and keep the reservoir tanks full so air
doesn't get in the system. call me at 704-6643121 if you have que. I am not
an
expert but mine was doing exactly like yours and now they are fine.
john redden 91 PT 40
