83 FC - Is my engine 225 or 250 horse?
05-02-2006, 10:42
All MY-83 Wanderlodge FCs had the 3208Ta (Ta = Turbo, automatic
transmission) engine. Most all of them were 225hp, the last dozen were reputedly 250hp. Externally the engines are identical, all of the BB turbo engines have the larger oil cooler which indicates the turbo engine with piston oil-cooling sprays and roller lifters etc., the only way I know to tell is finding the ID plate on one of the valve covers (which one depends on whether it is original or replacement). The valve- covers originally also said "Intercity" on them. 4.89:1 gears were standard and equipped on over 95% of the '83-'86 FCs, the optional 4.63:1 gears nicer but very rare. The model year on the production line in those years started around August '82 and ran through around July of '83 before changing to the '84. I have had one of the first '83s, one of the last, and a couple in-between. The last-late one I had was originally a 250hp, also had the '84 inside window trim (no aluminum trim), the air-cruise- control, and other '84 items I can't remember currently. If your '83 was built June or before, I doubt it originally had the 250hp engine (tag above the center of the windshield). A July coach, possibly. This might be a moot point as so many FCs have had engines replaced, and most of those replacements were upgraded to the 250hp engine. Also, if someone knowledgable like Buddy Gregg, salesman at that time for Harvey Mitchell Cadillac (love this trivia) knew it was possible, he might have ordered the 250hp for a special customer ahead of production. To further confuse the issue, BlueBird is a manufacturer, they can technically title an '83FC as a 2007 if they still have the chassis incomplete / un-titled. Some coaches were not complete during the model year the chassis was built, an example being some of the 96" wide PTs sold in '89, so they were titled as the model year when the coach was completed. Late Lxi coaches were also built on chassis which were built earlier. I don't know if there are examples of 31' or 33' coaches that crossed model years, but it could happen, especially in the case of the WLII which had significant differences in chassis equipment. Some indicators of a late '83 coach were the deadbolt on the door being a couple of inches above the rub-rail, the 4-bolt mirror mounts, and the rectangular turn-signals on the sides replacing the earlier beehive-style ones. As Mike H. has said though, what matters more than whether it is a 225 or 250, is the arrangement number. If you need parts such as injector nozzles, Cat won't be able to help you much without both the arrangement and serial number. Other items such as the rocker-cover gaskets, PCV, filters, etc., are common to all of the '83-'86 FCs and you should be able to get that information here. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > I have not checked mine out yet to tell which engine it might be. I > know it came from the factory with a 225hp, but was told it was > replaced with a rebuilt 250hp, but don't have any documentation on > it. Getting it out of storage tonight for the summer so now I will > have it at the house to play with and try to figure these things > out. Just ordered a new back up camera system from rvcams.com, so > that will be this weekends project. > > Phil Olson > Appleton, WI > 83FC35SB |
05-03-2006, 18:16
Thank you Jeff for the great info!
If I were to call the BB factory and provide them with all the numbers on my service parts sheet, might they be able to provide me with a build sheet containing all the info on my bus? Including engine type and factory options? It would sure be nice to know what my bus was like out of the factory! Andy --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > All MY-83 Wanderlodge FCs had the 3208Ta (Ta = Turbo, automatic > transmission) engine. Most all of them were 225hp, the last dozen were > reputedly 250hp. Externally the engines are identical, all of the BB > turbo engines have the larger oil cooler which indicates the turbo > engine with piston oil-cooling sprays and roller lifters etc., the only > way I know to tell is finding the ID plate on one of the valve covers > (which one depends on whether it is original or replacement). The valve- > covers originally also said "Intercity" on them. 4.89:1 gears were > standard and equipped on over 95% of the '83-'86 FCs, the optional > 4.63:1 gears nicer but very rare. > > The model year on the production line in those years started around > August '82 and ran through around July of '83 before changing to > the '84. I have had one of the first '83s, one of the last, and a > couple in-between. The last-late one I had was originally a 250hp, also > had the '84 inside window trim (no aluminum trim), the air-cruise- > control, and other '84 items I can't remember currently. > > If your '83 was built June or before, I doubt it originally had the > 250hp engine (tag above the center of the windshield). A July coach, > possibly. This might be a moot point as so many FCs have had engines > replaced, and most of those replacements were upgraded to the 250hp > engine. Also, if someone knowledgable like Buddy Gregg, salesman at > that time for Harvey Mitchell Cadillac (love this trivia) knew it was > possible, he might have ordered the 250hp for a special customer ahead > of production. > > To further confuse the issue, BlueBird is a manufacturer, they can > technically title an '83FC as a 2007 if they still have the chassis > incomplete / un-titled. Some coaches were not complete during the model > year the chassis was built, an example being some of the 96" wide PTs > sold in '89, so they were titled as the model year when the coach was > completed. Late Lxi coaches were also built on chassis which were built > earlier. I don't know if there are examples of 31' or 33' coaches that > crossed model years, but it could happen, especially in the case of the > WLII which had significant differences in chassis equipment. > > Some indicators of a late '83 coach were the deadbolt on the door > being a couple of inches above the rub-rail, the 4-bolt mirror mounts, > and the rectangular turn-signals on the sides replacing the earlier > beehive-style ones. > > As Mike H. has said though, what matters more than whether it is a 225 > or 250, is the arrangement number. If you need parts such as injector > nozzles, Cat won't be able to help you much without both the > arrangement and serial number. Other items such as the rocker-cover > gaskets, PCV, filters, etc., are common to all of the '83-'86 FCs and > you should be able to get that information here. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > > > I have not checked mine out yet to tell which engine it might be. I > > know it came from the factory with a 225hp, but was told it was > > replaced with a rebuilt 250hp, but don't have any documentation on > > it. Getting it out of storage tonight for the summer so now I will > > have it at the house to play with and try to figure these things > > out. Just ordered a new back up camera system from rvcams.com, so > > that will be this weekends project. > > > > Phil Olson > > Appleton, WI > > 83FC35SB > |
05-04-2006, 09:19
When I was getting build sheets, Bennie was the guy. He is still
there, but he was unsuccessful last time I wanted one. Bennie is over in Coachworks, the records are in the bus company, not sure if they all exist anymore. Best of luck, - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Thank you Jeff for the great info! > > If I were to call the BB factory and provide them with all the numbers > on my service parts sheet, might they be able to provide me with a > build sheet containing all the info on my bus? Including engine type > and factory options? > > It would sure be nice to know what my bus was like out of the factory! > > Andy > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > wrote: > > > > All MY-83 Wanderlodge FCs had the 3208Ta (Ta = Turbo, automatic > > transmission) engine. Most all of them were 225hp, the last dozen were > > reputedly 250hp. Externally the engines are identical, all of the BB > > turbo engines have the larger oil cooler which indicates the turbo > > engine with piston oil-cooling sprays and roller lifters etc., the only > > way I know to tell is finding the ID plate on one of the valve covers > > (which one depends on whether it is original or replacement). The valve- > > covers originally also said "Intercity" on them. 4.89:1 gears were > > standard and equipped on over 95% of the '83-'86 FCs, the optional > > 4.63:1 gears nicer but very rare. > > > > The model year on the production line in those years started around > > August '82 and ran through around July of '83 before changing to > > the '84. I have had one of the first '83s, one of the last, and a > > couple in-between. The last-late one I had was originally a 250hp, also > > had the '84 inside window trim (no aluminum trim), the air-cruise- > > control, and other '84 items I can't remember currently. > > > > If your '83 was built June or before, I doubt it originally had the > > 250hp engine (tag above the center of the windshield). A July coach, > > possibly. This might be a moot point as so many FCs have had engines > > replaced, and most of those replacements were upgraded to the 250hp > > engine. Also, if someone knowledgable like Buddy Gregg, salesman at > > that time for Harvey Mitchell Cadillac (love this trivia) knew it was > > possible, he might have ordered the 250hp for a special customer ahead > > of production. > > > > To further confuse the issue, BlueBird is a manufacturer, they can > > technically title an '83FC as a 2007 if they still have the chassis > > incomplete / un-titled. Some coaches were not complete during the model > > year the chassis was built, an example being some of the 96" wide PTs > > sold in '89, so they were titled as the model year when the coach was > > completed. Late Lxi coaches were also built on chassis which were built > > earlier. I don't know if there are examples of 31' or 33' coaches that > > crossed model years, but it could happen, especially in the case of the > > WLII which had significant differences in chassis equipment. > > > > Some indicators of a late '83 coach were the deadbolt on the door > > being a couple of inches above the rub-rail, the 4-bolt mirror mounts, > > and the rectangular turn-signals on the sides replacing the earlier > > beehive-style ones. > > > > As Mike H. has said though, what matters more than whether it is a 225 > > or 250, is the arrangement number. If you need parts such as injector > > nozzles, Cat won't be able to help you much without both the > > arrangement and serial number. Other items such as the rocker- cover > > gaskets, PCV, filters, etc., are common to all of the '83-'86 FCs and > > you should be able to get that information here. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > > > > > I have not checked mine out yet to tell which engine it might be. I > > > know it came from the factory with a 225hp, but was told it was > > > replaced with a rebuilt 250hp, but don't have any documentation on > > > it. Getting it out of storage tonight for the summer so now I will > > > have it at the house to play with and try to figure these things > > > out. Just ordered a new back up camera system from rvcams.com, so > > > that will be this weekends project. > > > > > > Phil Olson > > > Appleton, WI > > > 83FC35SB > > > |
