Need Help With 12 Volt Water System...
05-12-2006, 11:12
James,
You don't have any switches or Sporlan valves on your water system.
David Hollis Springfield,IL James has my old bus
05-12-2006, 13:45
Sounds your fill valve, sporland valve, is defective and need of repair. Or, as
I found with the same symptoms after fixing the sporland valve, the hot water
dump valve was defective. Either one can cause the same symptom. That was on
our '81 FC.
Sent: Friday, May 12, 2006 2:26 PM
Subject: [WanderlodgeForum] Need Help With 12 Volt Water System...
My water pump runs and pumps water, but very slowly. I could not find
any leaks or lose connections. It seems like the pump does not prime
it's self for some reason. The pump will run constantly.
I'm digging into it now. Does anyone have any advice to offer?
Thanks in advance.
James
78FC33SB
Kingman AZ (But not for long)
YAHOO! GROUPS LINKS
a.. Visit your group
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
WanderlodgeForum-unsubscribe@yahoogroups.com @yahoogroups.com?subject=Unsubscribe>
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service<http://docs.yahoo.com/info/terms/>.
05-12-2006, 14:43
Thanks to everyone who responded to my cry for help. Your immediate
and insightful responses are greatfully appreciated.
The problem was a pressure relief valve that was mounted to the hot
water heater directly above the hot water drain pipe.
I removed the valve and droped the drain tube, went to a local
hardware store and found a valve with the same specs as the one I
removed. I was told that it is a very common valve. It fit into
the hot water heater and and with an adapter, fitted it to the drain
pipe.
Total cost -- $37.42US, not counting the teflon tape I had in the
toad.
A special thanks to my main man, fire-fighter Dave Hollis.
Well, enough of this for now. It's time to take a nice shower.
James
78FC33SB
Kingman AZ (But headed east, slowly and very surely ;-)
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
repair. Or, as I found with the same symptoms after fixing the
sporland valve, the hot water dump valve was defective. Either one
can cause the same symptom. That was on our '81 FC.
> From: orbitalsolutions
> To:
WanderlodgeForum@yahoogroups.com com>
System...
not find
prime
> Thanks in advance.
> James
> 78FC33SB
> YAHOO! GROUPS LINKS
> a.. Visit your
group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForu
m>" on the web.
> WanderlodgeForum-
unsubscribe@yahoogroups.com unsubscribe@yahoogroups.com?subject=Unsubscribe>
of Service<http://docs.yahoo.com/info/terms/>.
05-12-2006, 15:02
James,
That is what this site is all about. Glad everything work out ok.
> pipe.
> toad.
> James
> 78FC33SB
> > To:
> WanderlodgeForum@yahoogroups.com > com>
> System...
> not find
> prime
> > Thanks in advance.
> > James
> > 78FC33SB
> > YAHOO! GROUPS LINKS
> > a.. Visit your
> m>" on the web.
> > WanderlodgeForum-
> unsubscribe@yahoogroups.com > unsubscribe@yahoogroups.com?subject=Unsubscribe>
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
