Mirrors
08-08-2007, 09:57
Mirrors
Hi George,
My mirror did the same two years ago. I used a product called Polyseamseal. ot sure this is correct spelling, it's close. It's a construction type adhesive. I used clear. Goes on white, dries clear. You shouldn't see it anyway. Use some tape to hold in position until dry. Lowes and Home Depot carry it here in Maryland. It is water soluble when wet. easy clean up. Keep it dry over night and it's good to go. My mirror has not budged since the repair. Raymond Jordan Foretravel Maryland ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-08-2007, 12:26
Mirrors
Hope someone has had a previous fix for this . My driver's side
mirror,(BlueBird upgrade,electric,heated, with lower convex), is hanging by its two wires. From looking at it, there appears to be two globs of silicon on the convex mirror at the top, one on each end. Has any one ran across a * super adhesive* that would work for this application. Because of the curvature of the mirror, I don't think that you could run a bead all the way across. Seems that the backing was designed to allow water to drip thru to prevent freezing. Any one that can send some freezing/cool weather this way would be a help to. This 100 degree humid stuff has gotten old. Thanks, George Burke, 1977FC31 Charlotte [Non-text portions of this message have been removed] |
08-08-2007, 12:49
Mirrors
From: George Burke To: wanderlodgeforum Sent: Wednesday, August 08, 2007 7:26 PM Subject: [WanderlodgeForum] Mirrors JB weld works great.Been there done that. Bob Loomas 1985 PT 36 Hope someone has had a previous fix for this . My driver's side mirror,(BlueBird upgrade,electric,heated, with lower convex), is hanging by its two wires. From looking at it, there appears to be two globs of silicon on the convex mirror at the top, one on each end. Has any one ran across a * super adhesive* that would work for this application. Because of the curvature of the mirror, I don't think that you could run a bead all the way across. Seems that the backing was designed to allow water to drip thru to prevent freezing. Any one that can send some freezing/cool weather this way would be a help to. This 100 degree humid stuff has gotten old. Thanks, George Burke, 1977FC31 Charlotte [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-08-2007, 13:40
Mirrors
Be careful about what kind of smoke that you inhale up there Ernie.
Remember that Willie and Fam got smacked down in La. for inhaling the wrong stuff. Enjoy your great weather. I do trust that you are going to vacate Mt. before winter hits, or face the opposite of what is happening here in N.C. now. My bones/body long to be in the cooler climes in the summer, and down Fl./Tx. way in the winter. Regards, George Burke in HOT! HOT! HOT! N.C. > > George, can't help you on your mirror problem, but we have had 80+ no > humidity in Montana. > > Ernie Ekberg > 83PT40 > Livingston, Mt > smelling smoke from all the fires- no fires here > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > |
08-08-2007, 13:48
Mirrors
Thanks Bob, I knew that JB Weld had plastics and metal covered, but
haven't seen or had a previous need for anything related to glass. If it worked for you, then it should clear up my problem. I will look for it tomorrow. Best Regards, George Burke 1977 FC31 Charlotte > > > ----- Original Message ----- > From: George Burke > To: wanderlodgeforum > Sent: Wednesday, August 08, 2007 7:26 PM > Subject: [WanderlodgeForum] Mirrors > JB weld works great.Been there done that. > Bob Loomas 1985 PT 36 > > > Hope someone has had a previous fix for this . My driver's side > mirror,(BlueBird upgrade,electric,heated, with lower convex), is hanging by > its two wires. From looking at it, there appears to be two globs of silicon > on the convex mirror at the top, one on each end. Has any one ran across a * > super adhesive* that would work for this application. Because of the > curvature of the mirror, I don't think that you could run a bead all the way > across. Seems that the backing was designed to allow water to drip thru to > prevent freezing. Any one that can send some freezing/cool weather this way > would be a help to. This 100 degree humid stuff has gotten old. Thanks, > George Burke, 1977FC31 Charlotte > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
08-09-2007, 09:28
Mirrors
Hank, it was 50 this am. Watch out for those kangs.
Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-09-2007, 12:44
Mirrors
---50 degrees here, windy & rainy, but the air and water are very
clear.....weather changes every day! chasing kangs on good days!!! Regards, Hank in Melbourne, Australia for now 90SP36 in VEGAS storage In WanderlodgeForum@yahoogroups.com, "George Burke" wrote: > > Be careful about what kind of smoke that you inhale up there Ernie. > Remember that Willie and Fam got smacked down in La. for inhaling the > wrong stuff. Enjoy your great weather. I do trust that you are going > to vacate Mt. before winter hits, or face the opposite of what is > happening here in N.C. now. My bones/body long to be in the cooler > climes in the summer, and down Fl./Tx. way in the winter. Regards, > George Burke in HOT! HOT! HOT! N.C. > > > > George, can't help you on your mirror problem, but we have had 80+ > no > > humidity in Montana. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > smelling smoke from all the fires- no fires here > > > > > > > > ************************************** Get a sneak peek of the all- > new AOL at > > http://discover.aol.com/memed/aolcom30tour > > > > > > [Non-text portions of this message have been removed] > > > |
08-09-2007, 22:16
Mirrors
You gotta love the dog days of summer in the Southeast. 83 degrees at 5AM,
raining hot water. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Henry Jay Hannigan To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 09, 2007 7:44 PM Subject: [WanderlodgeForum] Re: Mirrors ---50 degrees here, windy & rainy, but the air and water are very clear.....weather changes every day! chasing kangs on good days!!! Regards, Hank in Melbourne, Australia for now 90SP36 in VEGAS storage In WanderlodgeForum@yahoogroups.com, "George Burke" wrote: > > Be careful about what kind of smoke that you inhale up there Ernie. > Remember that Willie and Fam got smacked down in La. for inhaling the > wrong stuff. Enjoy your great weather. I do trust that you are going > to vacate Mt. before winter hits, or face the opposite of what is > happening here in N.C. now. My bones/body long to be in the cooler > climes in the summer, and down Fl./Tx. way in the winter. Regards, > George Burke in HOT! HOT! HOT! N.C. > > > > George, can't help you on your mirror problem, but we have had 80+ > no > > humidity in Montana. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > smelling smoke from all the fires- no fires here > > > > > > > > ************************************** Get a sneak peek of the all- > new AOL at > > http://discover.aol.com/memed/aolcom30tour > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
08-10-2007, 02:42
Mirrors
I got home from work yesterday and figured I should check on my pool. The
pool water was 90 degrees. Like taking a warm bath. Bleah. Jonathan Leifheit Wannabee At 09:43 AM 8/10/2007, you wrote: >You gotta love the dog days of summer in the Southeast. 83 degrees at 5AM, >raining hot water. >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Niceville, FL >Royale Conversion > ----- Original Message ----- > From: Henry Jay Hannigan > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 09, 2007 7:44 PM > Subject: [WanderlodgeForum] Re: Mirrors > > > ---50 degrees here, windy & rainy, but the air and water are very > clear.....weather changes every day! chasing kangs on good days!!! > Regards, > Hank in Melbourne, Australia for now > 90SP36 in VEGAS storage > > In WanderlodgeForum@yahoogroups.com, "George Burke" > wrote: > > > > Be careful about what kind of smoke that you inhale up there Ernie. > > Remember that Willie and Fam got smacked down in La. for inhaling > the > > wrong stuff. Enjoy your great weather. I do trust that you are > going > > to vacate Mt. before winter hits, or face the opposite of what is > > happening here in N.C. now. My bones/body long to be in the cooler > > climes in the summer, and down Fl./Tx. way in the winter. Regards, > > George Burke in HOT! HOT! HOT! N.C. > > > > > > George, can't help you on your mirror problem, but we have had > 80+ > > no > > > humidity in Montana. > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Mt > > > smelling smoke from all the fires- no fires here > > > > > > > > > > > > ************************************** Get a sneak peek of the > all- > > new AOL at > > > http://discover.aol.com/memed/aolcom30tour > > > > > > > > > [Non-text portions of this message have been removed] > > > |
02-07-2008, 13:42
Mirrors
A member of the forum was offering his mirrors for free. I was the
winning bidder and for some reason, his email address and name have disappeared from my 60+ year old brain. I need to be refreshed- so please let me know if they are on the way, you have changed your mind, or you sold them for cash. Thanks,Ernie- 83PT40 in Texas- thought I was going to Montana, soon, but they have no work either. |
