Toad wiring
08-27-2006, 13:53
Toad wiring
Bill,
I forgot to mention: The SMI only monitors the toad brake signal at the switch on the pedal and uses this to activate the transmitter to signal the receiver in the coach that the brakes are applied. As long as the coach brake voltage is not fed back into the line, the SMI signaling will not be effected. The SMI does need to see the coach brake voltage on a specific pair of wires to work, but that can be tapped off the coach signal prior to the relays I mentioned in the previous post. Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of pattypape Sent: Sunday, August 27, 2006 9:45 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Toad wiring Gardner, Curt, We have a 2001 Jeep Cherokee. Found the Cherokee tail light/stop light wires and spliced in two DPDT switches, This method uses the existing Jeep lights and sockets. Switches are UP for Bird towing, DOWN for Jeep Driving. The Jeep tail lights are used for turn signals, hazards, and stop lights. No need for diodes, But I must remember to throw the manual switches. Easy to install. I do not know if this works with the SMI. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com wrote: > > I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > the lights. It seems I have no choice but to use separate lights for > the turn signals since the SMI will activate the normal brake light > circuit in the toad, so I will not be able indicate a turn when the > SMI is active. I believe I will also need to use diodes at the brake > lights so the lights work with both the RV and the toad brake > lighting without feeding back into either vehicle. > > Also, dumb question: Does the 78FC use the same lights for the > brakes and turn signals? Mine is at the storage facility and I > completely forgot to check this when I was there. > > Has anyone out there had experience with this and can you add any > comments to what my observations. > > > Thanks > Gardner > 78FC33 > [Non-text portions of this message have been removed] |
