air leak/vacuum generator leak
09-09-2006, 07:52
Wouldn't the unknown hose be the air to run the vac generator?
Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 09, 2006 12:46 PM Subject: [WanderlodgeForum] Re: air leak/vacuum generator leak There are two vacuum (?) hoses coming off the generator. One goes to the cruise, the other to ???. The air system schematics that came with my coach don't show any of that circuit as far as I can see. Perhaps the second hose is a return line to catch the compressed air after it produces a vacuum? I'm guessing it's sole pupose is for the cruise control, replacing the electric vacuum pump that was the source of vacuum in earlier years. You should be able to tell if yours is working by testing the input vacuum line into the vacuum canister on the top left of the engine. If you have enough vacuum there, that's not your problem. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com cfsomers@... wrote: > > I am new to all the details on the bluebirds, but my cruise stopped > working out of the blue going down the road. what is this vacumm generator > and is it's sole purpose to run the cruise? > > Chuck S > 81FC35SB > Florida > > > > I think someone wrote earlier that the device will 'leak' if there is > > a vacuum leak in the cruise control system. This makes sense. My next > > test will be to remove the input vacuum line from the cruise control, > > plug it and see if it stops the air leak. > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com "Stephen H" <share@> wrote: > >> > >> Kerry, > >> > >> > >> > >> My 81 does the same thing. After shutting off the engine, it will > > make a air > >> leak sound for a little while, that changes when the lines are > > moved. It has > >> been awhile since I have looked at it, but if memory serves- I have > > the same > >> device, with a leaking sound coming from a empty port as well. I will be > >> monitoring this post for a repair and or replacement for the device. > > Let me > >> > >> > >> > >> > >> Stephen H > >> > >> 81 FC-33SB > >> > >> Plant City, FL > >> > >> > >> > >> > >> > >> _____ > >> > >> From: WanderlodgeForum@yahoogroups.com > >> [mailto:WanderlodgeForum@yahoogroups.com davidkerryedwards > >> Sent: Friday, September 08, 2006 2:55 PM > >> To: WanderlodgeForum@yahoogroups.com > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > >> > >> > >> > >> I investiagted my air leak a little more. It does appear to be the > >> vacuum generator mounted on the bottom of an air manifold behind the > >> bumper. Air is coming out of the one of the fittings that has never > >> had a hose on it. When I plug that fitting, the air must backfeed > >> thru the cruise control vacuum system because it blows the hose off > >> the vacuum canister on the engine. Do I need to replace the vacuum > >> generator (if that is what it is)? If so, where would I purchase a > >> replacement? > >> > >> Kerry Edwards > >> 82 FC 35 > >> Denver > >> > >> > >> > >> > >> > >> [Non-text portions of this message have been removed] > >> > > > > > > > > > > > > > [Non-text portions of this message have been removed] |
09-09-2006, 08:01
The generator screws directly into an air manifold, receiving it's air
thru that threaded connection. (at least on my coach). It has three barbed outlets. One to the cruise control, one to ??, one with nothing attached. Air was leaking out of unused fitting on mine. Once I took it apart and reassembled it (partly) that leak stopped when I tested it by blowing thru it. I suspect the plastic needle valve was stuck. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Wouldn't the unknown hose be the air to run the vac generator? > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, September 09, 2006 12:46 PM > Subject: [WanderlodgeForum] Re: air leak/vacuum generator leak > > > There are two vacuum (?) hoses coming off the generator. One goes to > the cruise, the other to ???. The air system schematics that came > with my coach don't show any of that circuit as far as I can see. > Perhaps the second hose is a return line to catch the compressed air > after it produces a vacuum? > I'm guessing it's sole pupose is for the cruise control, replacing the > electric vacuum pump that was the source of vacuum in earlier years. > You should be able to tell if yours is working by testing the input > vacuum line into the vacuum canister on the top left of the engine. > If you have enough vacuum there, that's not your problem. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com cfsomers@ wrote: > > > > I am new to all the details on the bluebirds, but my cruise stopped > > working out of the blue going down the road. what is this vacumm > generator > > and is it's sole purpose to run the cruise? > > > > Chuck S > > 81FC35SB > > Florida > > > > > > > I think someone wrote earlier that the device will 'leak' if there is > > > a vacuum leak in the cruise control system. This makes sense. My next > > > test will be to remove the input vacuum line from the cruise control, > > > plug it and see if it stops the air leak. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com "Stephen H" <share@> wrote: > > >> > > >> Kerry, > > >> > > >> > > >> > > >> My 81 does the same thing. After shutting off the engine, it will > > > make a air > > >> leak sound for a little while, that changes when the lines are > > > moved. It has > > >> been awhile since I have looked at it, but if memory serves- I have > > > the same > > >> device, with a leaking sound coming from a empty port as well. I > will be > > >> monitoring this post for a repair and or replacement for the device. > > > Let me > > >> > > >> > > >> > > >> > > >> Stephen H > > >> > > >> 81 FC-33SB > > >> > > >> Plant City, FL > > >> > > >> > > >> > > >> > > >> > > >> _____ > > >> > > >> From: WanderlodgeForum@yahoogroups.com > > >> [mailto:WanderlodgeForum@yahoogroups.com On Behalf Of > davidkerryedwards > > >> Sent: Friday, September 08, 2006 2:55 PM > > >> To: WanderlodgeForum@yahoogroups.com > > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > > >> > > >> > > >> > > >> I investiagted my air leak a little more. It does appear to be the > > >> vacuum generator mounted on the bottom of an air manifold behind the > > >> bumper. Air is coming out of the one of the fittings that has never > > >> had a hose on it. When I plug that fitting, the air must backfeed > > >> thru the cruise control vacuum system because it blows the hose off > > >> the vacuum canister on the engine. Do I need to replace the vacuum > > >> generator (if that is what it is)? If so, where would I purchase a > > >> replacement? > > >> > > >> Kerry Edwards > > >> 82 FC 35 > > >> Denver > > >> > > >> > > >> > > >> > > >> > > >> [Non-text portions of this message have been removed] > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
09-09-2006, 08:17
When that happened on my FC, the air continuously expelled from the vacant
fitting, the vac generator was replaced and the symptom stopped. However, I must tell you the rest of the story, though it would then engage, the cc would surge so badly that it couldn't be used. I think that was a low voltage problem but I never tackled that problem. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 09, 2006 1:01 PM Subject: [WanderlodgeForum] Re: air leak/vacuum generator leak The generator screws directly into an air manifold, receiving it's air thru that threaded connection. (at least on my coach). It has three barbed outlets. One to the cruise control, one to ??, one with nothing attached. Air was leaking out of unused fitting on mine. Once I took it apart and reassembled it (partly) that leak stopped when I tested it by blowing thru it. I suspect the plastic needle valve was stuck. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > Wouldn't the unknown hose be the air to run the vac generator? > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, September 09, 2006 12:46 PM > Subject: [WanderlodgeForum] Re: air leak/vacuum generator leak > > > There are two vacuum (?) hoses coming off the generator. One goes to > the cruise, the other to ???. The air system schematics that came > with my coach don't show any of that circuit as far as I can see. > Perhaps the second hose is a return line to catch the compressed air > after it produces a vacuum? > I'm guessing it's sole pupose is for the cruise control, replacing the > electric vacuum pump that was the source of vacuum in earlier years. > You should be able to tell if yours is working by testing the input > vacuum line into the vacuum canister on the top left of the engine. > If you have enough vacuum there, that's not your problem. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com cfsomers@ wrote: > > > > I am new to all the details on the bluebirds, but my cruise stopped > > working out of the blue going down the road. what is this vacumm > generator > > and is it's sole purpose to run the cruise? > > > > Chuck S > > 81FC35SB > > Florida > > > > > > > I think someone wrote earlier that the device will 'leak' if there is > > > a vacuum leak in the cruise control system. This makes sense. My next > > > test will be to remove the input vacuum line from the cruise control, > > > plug it and see if it stops the air leak. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com "Stephen H" <share@> wrote: > > >> > > >> Kerry, > > >> > > >> > > >> > > >> My 81 does the same thing. After shutting off the engine, it will > > > make a air > > >> leak sound for a little while, that changes when the lines are > > > moved. It has > > >> been awhile since I have looked at it, but if memory serves- I have > > > the same > > >> device, with a leaking sound coming from a empty port as well. I > will be > > >> monitoring this post for a repair and or replacement for the device. > > > Let me > > >> > > >> > > >> > > >> > > >> Stephen H > > >> > > >> 81 FC-33SB > > >> > > >> Plant City, FL > > >> > > >> > > >> > > >> > > >> > > >> _____ > > >> > > >> From: WanderlodgeForum@yahoogroups.com > > >> [mailto:WanderlodgeForum@yahoogroups.com On Behalf Of > davidkerryedwards > > >> Sent: Friday, September 08, 2006 2:55 PM > > >> To: WanderlodgeForum@yahoogroups.com > > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > > >> > > >> > > >> > > >> I investiagted my air leak a little more. It does appear to be the > > >> vacuum generator mounted on the bottom of an air manifold behind the > > >> bumper. Air is coming out of the one of the fittings that has never > > >> had a hose on it. When I plug that fitting, the air must backfeed > > >> thru the cruise control vacuum system because it blows the hose off > > >> the vacuum canister on the engine. Do I need to replace the vacuum > > >> generator (if that is what it is)? If so, where would I purchase a > > >> replacement? > > >> > > >> Kerry Edwards > > >> 82 FC 35 > > >> Denver > > >> > > >> > > >> > > >> > > >> > > >> [Non-text portions of this message have been removed] > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
09-09-2006, 09:26
My cruise control has been working but not correctly. It surges or
cuts out unless I just keep slight pressure on the accelerator, then it seems to work ok. We'll see what happens once I fix the vacuum generator. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > When that happened on my FC, the air continuously expelled from the vacant fitting, the vac generator was replaced and the symptom stopped. However, I must tell you the rest of the story, though it would then engage, the cc would surge so badly that it couldn't be used. I think that was a low voltage problem but I never tackled that problem. > > Good luck. > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > |
09-09-2006, 11:57
Good luck Kerry.
Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 09, 2006 2:26 PM Subject: [WanderlodgeForum] Re: air leak/vacuum generator leak My cruise control has been working but not correctly. It surges or cuts out unless I just keep slight pressure on the accelerator, then it seems to work ok. We'll see what happens once I fix the vacuum generator. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > When that happened on my FC, the air continuously expelled from the vacant fitting, the vac generator was replaced and the symptom stopped. However, I must tell you the rest of the story, though it would then engage, the cc would surge so badly that it couldn't be used. I think that was a low voltage problem but I never tackled that problem. > > Good luck. > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > [Non-text portions of this message have been removed] |
