Flying J
09-18-2006, 09:28
Flying J
There is a gentleman who is listed in the forum who makes a brass insert
for the fuel port that mostly prevents splashback. I say mostly because it is not a complete solution since it will blow back some if you are running full bore on high speed pump. I like the terrycloth rag idea and it seems safe and practical. Pete Masterson Is there any reasonable solution to the BB's tendency to "gush" fuel just before the tank is full? I try to estimate the amount of fuel to take on ... but the fuel gauge is hardly precise enough to get within 20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or so splashes out, it tends to cover everything - gloves or not. (I've learned to stand back!) Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > Have > had some diesel puddles to wade thru, [Non-text portions of this message have been removed] Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
09-18-2006, 10:26
Flying J
He is good friends with John Benham, Skydreamer, and Tony Holterman. Check
the contact list for Ton'y's phone number. Also, Steve Gureasko is in Coere d Leane, Id on the way to Washington to see you. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-18-2006, 10:53
Flying J
I remember reading about that one ... but I can't find the email in
the archive... I'll probably do the rag thing for now. The pressure equalization tube as described by Jeff Miller is probably the "real" fix -- but is a lot more work to install. (Rags, I have. Access to the top of the fuel tank isn't easy.) Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 18, 2006, at 2:28 PM, Wallace Craig wrote: > There is a gentleman who is listed in the forum who makes a > brass insert for the fuel port that mostly prevents splashback. I > say mostly because it is not a complete solution since it will blow > back some if you are running full bore on high speed pump. > I like the terrycloth rag idea and it seems safe and practical. > Pete Masterson > Is there any reasonable solution to the BB's tendency to "gush" fuel > just before the tank is full? I try to estimate the amount of fuel to > take on ... but the fuel gauge is hardly precise enough to get within > 20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or > so splashes out, it tends to cover everything - gloves or not. (I've > learned to stand back!) [Non-text portions of this message have been removed] |
09-18-2006, 10:53
Flying J
Billy's unit works fine as long as you are not on the highest output
of the nozzle. I run mine at high till I know that I am within 50 gallons of the top and then I cut it back to prevent the blow back. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Billy Dawson, did a modification for the fuel blow back. I think he has an ad > on Vintage Birds. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
09-18-2006, 10:54
Flying J
There you go... I found the ad!
Thanks. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 18, 2006, at 2:48 PM, erniecarpet@... wrote: > Billy Dawson, did a modification for the fuel blow back. I think he > has an ad > on Vintage Birds. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > > > [Non-text portions of this message have been removed] |
09-18-2006, 12:12
Flying J
I emailed the guy who's name was in the archives...never heard back
from him. Bob Lawrence 84 PT36 Tacoma, Wa. > > Somewhere in the archives or files on either this site or the FC forum is a solution > designed by someone that I believe uses PVC pipe to solve the problem. > > Kerry > 82 Fc 35--Gusher > |
09-18-2006, 14:13
Flying J
He's the one I had sent an email to a while back..no reply.
Sent another one tonight, says email invalid. Bob Lawrence 84 PT36 Tacoma, Wa. > Billy Dawson, did a modification for the fuel blow back. I think he has an ad > on Vintage Birds. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > |
09-18-2006, 17:01
Flying J
No Ralph, that's the second thing to go. I can't remember what the first was.
Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 18, 2006 9:40 AM Subject: Re: [WanderlodgeForum] Flying J Pete: Check the archives for "fuel splash back" I remember someone having a solution to this problem, just not who. Well, they do say that the "memory" is first to go, right? Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm<http://home.swbell.net/rlf47/indexhtm> At 09:13 AM 9/18/2006 -0700, you wrote: >Is there any reasonable solution to the BB's tendency to "gush" fuel >just before the tank is full? I try to estimate the amount of fuel to >take on ... but the fuel gauge is hardly precise enough to get within >20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or >so splashes out, it tends to cover everything - gloves or not. (I've >learned to stand back!) > >Pete Masterson >aeonix1@... >'95 Bluebird Wanderlodge WBDA 42' >El Sobrante, CA > > > > >On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > > <snip> > > Have > > had some diesel puddles to wade thru, <snip> > > > [Non-text portions of this message have been removed] |
09-19-2006, 04:08
Flying J
BIlly Dawson's email is now sherryandbilly@..., phone
830-305-7496. The address, 4570 Barbarosa Road, Sequin, TX 78155 is still correct. I spoke with him this morning, and it is important to know what year/ model BB you have as newer ones have a smaller fuel pipe and 87-89 (if I got that right) have a half-moon shaped ledge (to help hold the nozzle) that would have to be removed to allow the baffle to fit. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 18, 2006, at 7:13 PM, Bob Lawrence wrote: > He's the one I had sent an email to a while back..no reply. > Sent another one tonight, says email invalid. > > Bob Lawrence > 84 PT36 > Tacoma, Wa. >> Billy Dawson, did a modification for the fuel blow back. I think he > has an ad >> on Vintage Birds. >> >> Ernie Ekberg >> 83 PT40 >> Livingston, Montana >> [Non-text portions of this message have been removed] |
