AQUA HOT
02-26-2010, 07:17
AQUA HOT
Hi Ernie,
The Aqua-Hot tech is Roger Burke. Here is his web page address.
Raymond Jordan
1997 U 320 Foretravel
In a message dated 2/26/2010 5:39:20 P.M. Eastern Standard Time, ernietex@... writes:
02-26-2010, 08:22
AQUA HOT
I have an odor of diesel in the bays under my coach. I have not taken the cover
off of the Aqua hot yet but there are no obvious leaks. Any ideas about what I should look for. Where is the best place to get any needed parts. Also a while back I had posted about sticking windows. I found a product made by gunk that is a dry spray lubricant that works pretty well. Thanks, MIke Mcmahan 96 42' Wanderlodge |
02-26-2010, 09:03
AQUA HOT
A slight odor of diesel is not unusual in the storage bays, especially near the AquaHot.
If even a small quantity of diesel is spilled during a servicing, (e.g. while changing the inline filter on the fuel line just before the burner) the odor can be persistent, even if the spill was minor and carefully wiped up. Often, when the burner ignites, a bit of a "backfire" occurs, causing a little bit of diesel smoke to remain in the AquaHot rather than go out through the burner and AH Exhaust. This smoke generate an odor that drifts out the air-vents in the AH and permeates the storage bays. So, if the odor is light but persistent, it may simply be "normal" odor. Some of us also have rather more sensitive response to the diesel odor. In three years, I was never able to locate an actual source of diesel odor in the storage bays -- but I was always aware of it whenever I opened one of the doors. Keep in mind that the smoke-burp (backfire) occurs more often as the burner nozzle ages. So, the recommendation for an annual service is reasonable. The basic service replaces the inline fuel filter, the burner nozzle, and does some general clean up and adjustment to the burner and igniters. Parts can be obtained from AquaHot or Webasto. =============================================== Pete Masterson, Author of Book Design and Production: A Guide for Authors and Publishers "Aeonix1@Mac.com" Aeonix Publishing Group http://www.aeonix.com =============================================== On Feb 26, 2010, at 12:22 PM, mcmike1952 wrote:
02-26-2010, 10:17
AQUA HOT
02-26-2010, 10:27
AQUA HOT
02-26-2010, 10:49
AQUA HOT
Mike, you could check the fuel hose to the fuel filter and then pull the cover
on the A/H, 2 screws on the top and 2 on the bottom, on the side that has all the pipe coming out. If there is a leak there will probably be diesel in the bottom pan. You might want to get on this sooner than later, if the diesel get to deep it will start to soak into the carpet all around it. If your lucky the diesel has not spread to the liner in the A/H. good luck Marty Gregg 95 BMC 37 Kennewick WA |
02-26-2010, 11:36
AQUA HOT
Thanks Wallace. Let us know if you will be heading that way. Looks like it was
nearly 70 down there today 40s here. Mike mcmahan 96 42' Wanderlodge --- In WanderlodgeForum@yahoogroups.com, Wallace Craig wrote: > > Mike, there is a certified tech for AH Who was at quartzite that was reported as knowledgeable. He is based in Calif. cut travels in a Foetravel and does AH service. Might look into that. Leaving SPI Sunday for Sequin to meet Dave and get alternator fixed. > We "might" come to Ca. this summer; still negotiating. > > > Wallace & Faye Craig > 95 WLWB 42 > Azle, Texas > > --- On Fri, 2/26/10, mcmike1952 <mmcmahan@...> wrote: > > > From: mcmike1952 <mmcmahan@...> > Subject: [WanderlodgeForum] Aqua Hot > To: WanderlodgeForum@yahoogroups.com > Date: Friday, February 26, 2010, 2:22 PM > > > I have an odor of diesel in the bays under my coach. I have not taken the cover off of the Aqua hot yet but there are no obvious leaks. Any ideas about what I should look for. Where is the best place to get any needed parts. > > Also a while back I had posted about sticking windows. I found a product made by gunk that is a dry spray lubricant that works pretty well. > > Thanks, MIke Mcmahan 96 42' Wanderlodge > > > > ------------------------------------ > > Yahoo! Groups Links > |
02-26-2010, 11:38
AQUA HOT
Ernie, Do you have an email or phone number? Thanks, Mike mcmahan 96 42'
Wanderlodge --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > I believe he is George Burke. He has a trailer full of parts with hime, also. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Txà 817-475-3991 > http://www.ernieekbergflooring.net > > --- On Fri, 2/26/10, Wallace Craig > > > From: Wallace Craig > Subject: Re: [WanderlodgeForum] Aqua Hot > To: WanderlodgeForum@yahoogroups.com > Date: Friday, February 26, 2010, 4:17 PM > > > à > > > > > > > > > Mike, there is a certified tech for AH Who was at quartzite that was reported as knowledgeable. He is based in Calif. cut travels in a Foetravel and does AH service. Might look into that. Leaving SPI Sunday for Sequin to meet Dave and get alternator fixed. > We "might" come to Ca. this summer; still negotiating. > > > Wallace &à Faye Craig > 95 WLWB 42 > Azle, Texas > > --- On Fri, 2/26/10, mcmike1952 <mmcmahan@hot. rr.com> wrote: > > > From: mcmike1952 <mmcmahan@hot. rr.com> > Subject: [WanderlodgeForum] Aqua Hot > To: WanderlodgeForum@ yahoogroups. com > Date: Friday, February 26, 2010, 2:22 PM > > > I have an odor of diesel in the bays under my coach.à I have not taken the cover off of the Aqua hot yet but there are no obvious leaks.à Any ideas about what I should look for.à Where is the best place to get any needed parts. > > Also a while back I had posted about sticking windows.à I found a product made by gunk that is a dry spray lubricant that works pretty well. > > Thanks, MIke Mcmahan 96 42' Wanderlodge > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > |
02-26-2010, 11:48
AQUA HOT
Roger Berke (916)214-6518 Â or "roger.berke@gmail.com"
On 26 February 2010 16:36, mcmike1952 <"mmcmahan@hot.rr.com"> wrote:
-- Rob, Sue and Joey Robinson |
02-26-2010, 12:11
AQUA HOT
I would add that he normally keeps his position up to date on BBirdMaps.com,
currently outside of Tucson: http://www.bbirdmaps.com/user1.cfm?user=118 On 2/26/2010 at 4:48 PM Rob Robinson wrote: >Roger Berke (916)214-6518 or roger.berke@... > >On 26 February 2010 16:36, mcmike1952 <mmcmahan@...> wrote: > >> >> >> Thanks Wallace. Let us know if you will be heading that way. Looks like >it >> was nearly 70 down there today 40s here. Mike mcmahan 96 42' Wanderlodge >> >> >> --- In >WanderlodgeForum@yahoogroups.com >> Wallace Craig >> > >> > Mike, there is a certified tech for AH Who was at quartzite that was >> reported as knowledgeable. He is based in Calif. cut travels in a >Foetravel >> and does AH service. Might look into that. Leaving SPI Sunday for Sequin >to >> meet Dave and get alternator fixed. >> > We "might" come to Ca. this summer; still negotiating. >> > >> > >> > Wallace & Faye Craig >> >> > 95 WLWB 42 >> > Azle, Texas >> > >> > --- On Fri, 2/26/10, mcmike1952 <mmcmahan@...> wrote: >> > >> > >> > From: mcmike1952 <mmcmahan@...> >> >> > Subject: [WanderlodgeForum] Aqua Hot >> > To: >WanderlodgeForum@yahoogroups.com >> > Date: Friday, February 26, 2010, 2:22 PM >> > >> > >> > I have an odor of diesel in the bays under my coach. I have not taken >> the cover off of the Aqua hot yet but there are no obvious leaks. Any >ideas >> about what I should look for. Where is the best place to get any needed >> parts. >> > >> > Also a while back I had posted about sticking windows. I found a >product >> made by gunk that is a dry spray lubricant that works pretty well. >> >> > >> > Thanks, MIke Mcmahan 96 42' Wanderlodge >> > >> > >> > >> > ------------------------------------ >> > >> > Yahoo! Groups Links >> > >> >> >> > > > >-- >Rob, Sue and Joey Robinson |
