40 weight oil
11-16-2006, 10:42
40 weight oil
wrote: > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please advise. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > 8V92 > > G/Day All The reason engine manufacturers recomend 40wt oil is because they have been recomending it for years , it has not given any problems , but come on you guys technology has moved ahead somewhat since Rotella was invented, Synthetic is the latest technology it is a proven product , ask any motor sport organisation if they still use mineral oil in race car engines . Interstate truckers have been using it here for about 12 years because they can extend change intervals it is far more protective and they believe they get better mileage and engine protection. you have a computer get some synthetic oil!! > > > > ----- Original Message ----- > From: chapelhill2901 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, November 16, 2006 7:14 AM > Subject: [WanderlodgeForum] 40 weight oil > > > i am going to change the oil, and my owners manual tells me to use > 10w40 weight. as seen below im being advised to use straight 40. what > weight should i use? 40 grade Cx-II oil? > > thanks, robert > 85 pt40 6v92 > > Detroits have no glow plugs and "off the shelf" no starting assist. > They are ENTIRELY dependant on engine compression to start. They > also require (not recommend, REQUIRE) straight weight strength required > by the injector followers - you WILL destroy cams > if you run a 15W40 in them, > > > > > > [Non-text portions of this message have been removed] > |
11-16-2006, 10:57
40 weight oil
Thanks all:
Rotello T 40W it will be. Leroy Eckert 1990 WB-40 Niceville, FL Smoke N Mirrors ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 16, 2006 3:28 PM Subject: Re: [WanderlodgeForum] 40 weight oil Leroy, I changed my oil to 40 weight Rotella just before the RIV/RATS Ralley. I could not find it at any of the discount stores had to go to the Shell Distributor to purchase it. Howard Truitt Camilla, Ga. 86 PT40, 8V92 "Under The Waterfall" [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
11-16-2006, 11:27
40 weight oil
Detroit diesel is very clear on not using synthetic oils in their 2
cycle diesels. It causes problems. tom warner 1985 PT 40 At 05:42 PM 11/16/2006, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" >wrote: > > > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please >advise. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > 8V92 > > > > G/Day All > >The reason engine manufacturers recomend 40wt oil is because they have >been recomending it for years , it has not given any problems , but come >on you guys technology has moved ahead somewhat since Rotella was >invented, Synthetic is the latest technology it is a proven product , >ask any motor sport organisation if they still use mineral oil in race >car engines . Interstate truckers have been using it here for about 12 >years because they can extend change intervals it is far more protective >and they believe they get better mileage and engine protection. you have >a computer get some synthetic oil!! > > > > > > > > ----- Original Message ----- > > From: chapelhill2901 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, November 16, 2006 7:14 AM > > Subject: [WanderlodgeForum] 40 weight oil > > > > > > i am going to change the oil, and my owners manual tells me to use > > 10w40 weight. as seen below im being advised to use straight 40. what > > weight should i use? 40 grade Cx-II oil? > > > > thanks, robert > > 85 pt40 6v92 > > > > Detroits have no glow plugs and "off the shelf" no starting assist. > > They are ENTIRELY dependant on engine compression to start. They > > also require (not recommend, REQUIRE) straight weight strength >required > > by the injector followers - you WILL destroy cams > > if you run a 15W40 in them, > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > >Yahoo! Groups Links > > |
11-16-2006, 11:52
40 weight oil
Computers use synthetic oil????? Gollie!
I did not know that!!!Guess I better get some. Bob Janes --- In WanderlodgeForum@yahoogroups.com, "b_auzzie" <b-edmonds1@...> wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > wrote: > > > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please > advise. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > 8V92 > > > > G/Day All > > The reason engine manufacturers recomend 40wt oil is because they have > been recomending it for years , it has not given any problems , but come > on you guys technology has moved ahead somewhat since Rotella was > invented, Synthetic is the latest technology it is a proven product , > ask any motor sport organisation if they still use mineral oil in race > car engines . Interstate truckers have been using it here for about 12 > years because they can extend change intervals it is far more protective > and they believe they get better mileage and engine protection. you have > a computer get some synthetic oil!! > > > > > > > > ----- Original Message ----- > > From: chapelhill2901 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, November 16, 2006 7:14 AM > > Subject: [WanderlodgeForum] 40 weight oil > > > > > > i am going to change the oil, and my owners manual tells me to use > > 10w40 weight. as seen below im being advised to use straight 40. what > > weight should i use? 40 grade Cx-II oil? > > > > thanks, robert > > 85 pt40 6v92 > > > > Detroits have no glow plugs and "off the shelf" no starting assist. > > They are ENTIRELY dependant on engine compression to start. They > > also require (not recommend, REQUIRE) straight weight strength > required > > by the injector followers - you WILL destroy cams > > if you run a 15W40 in them, > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
