Front wheel seals and bearings
12-29-2006, 10:23
Jeff- on my coach, the tire was defective. Tire looked good. Replaced the 2
front steers and no ticking. It was driving us nuts at slow speed, cause at high speed, the wind noise counteracted that ticking sound. Bearings-possible? Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
12-29-2006, 10:35
Hello All
There has been a ticking noise at the left front wheel of the bird since we put steer tires on 2 seasons ago, you hear it when you get next to a median wall or go under a bridge. We have taken the wheel off and inspected it and the bearing twice only for the noise to come back, should we remove the bearing to see if it is bad? It has been about 12 to 15 thousand miles like that without a problem. Thanks Guys! Jeff & Michelle August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > I'll watch for that Howard > Don > 89 SP 36' > Butler, PA > > Don, > Even in a situation where the oil is at the proper level the bearings will > wear over time to a point where there is loose play in the race. That is what > causes the noise and the bearings and seals need replacing. > Keep a watch on the back side of the tires for any oil a sure sign of a seal > leak. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > > > > > [Non-text portions of this message have been removed] > |
12-30-2006, 02:54
Jeff,
I remember something said at the RIV this year about the metal stem on the tires inner tube striking on the brake pad or caliper and that it could cut thru it and cause loss of tire pressure. Worth checking. Howard Truitt Camilla, Ga "Sowega" 86 PT40 ----- Original Message ----- From: Jeff August To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 29, 2006 5:35 PM Subject: [WanderlodgeForum] Re: Front wheel seals and bearings Hello All There has been a ticking noise at the left front wheel of the bird since we put steer tires on 2 seasons ago, you hear it when you get next to a median wall or go under a bridge. We have taken the wheel off and inspected it and the bearing twice only for the noise to come back, should we remove the bearing to see if it is bad? It has been about 12 to 15 thousand miles like that without a problem. Thanks Guys! Jeff & Michelle August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > I'll watch for that Howard > Don > 89 SP 36' > Butler, PA > > Don, > Even in a situation where the oil is at the proper level the bearings will > wear over time to a point where there is loose play in the race. That is what > causes the noise and the bearings and seals need replacing. > Keep a watch on the back side of the tires for any oil a sure sign of a seal > leak. > Howard Truitt > Camilla, Ga. > "Sowega" > 86 PT40 > > > > > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 [Non-text portions of this message have been removed] |
12-30-2006, 04:26
Switch rims/tire assemblies right to left and see if the noise
follows. Paint the stem and see if it strikes off. The ticking may be a shoe tracking also? if it stops ticking with minimal braking force it may well be a brake issue. the easy fix for that is to hone the drums The good thing with viewable oil bath bearings is you can see when a bearing is crapping out. the oil gets dirty, kinda muddy looking. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Jeff, > I remember something said at the RIV this year about the metal stem on the tires inner tube striking on the brake pad or caliper and that it could cut thru it and cause loss of tire pressure. Worth checking. > Howard Truitt > Camilla, Ga > "Sowega" > 86 PT40 > > > ----- Original Message ----- > From: Jeff August > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, December 29, 2006 5:35 PM > Subject: [WanderlodgeForum] Re: Front wheel seals and bearings > > > Hello All > There has been a ticking noise at the left front wheel of the bird > since we put steer tires on 2 seasons ago, you hear it when you get > next to a median wall or go under a bridge. We have taken the wheel > off and inspected it and the bearing twice only for the noise to come > back, should we remove the bearing to see if it is bad? It has been > about 12 to 15 thousand miles like that without a problem. > Thanks Guys! > Jeff & Michelle August > 1980FC35RB > Plymouth Wi. > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > > > I'll watch for that Howard > > Don > > 89 SP 36' > > Butler, PA > > > > Don, > > Even in a situation where the oil is at the proper level the > bearings will > > wear over time to a point where there is loose play in the race. > That is what > > causes the noise and the bearings and seals need replacing. > > Keep a watch on the back side of the tires for any oil a sure sign > of a seal > > leak. > > Howard Truitt > > Camilla, Ga. > > "Sowega" > > 86 PT40 > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > -------------------------------------------------------------------- ---------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 > > > [Non-text portions of this message have been removed] > |
