Oil pressure gauge
02-24-2008, 12:14
Oil pressure gauge
While driving north the last couple days, my oil pressure gauge has
fluctuated from 30 pounds to the "normal" 60 while driving. I wonder if
the sending unit is starting to go south- or the gauge?
Ernie- 83PT40
Buffalo, Wy
02-24-2008, 12:35
Oil pressure gauge
Or a loose wire with crud at the sensor.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
if
> Ernie- 83PT40
> Buffalo, Wy
02-24-2008, 12:38
Oil pressure gauge
Ernie, OOPS
I hit the send too quick,
an intermittent gage needle movement will
act like your symptom.
Bill 88 FC
wonder if
> Ernie- 83PT40
> Buffalo, Wy
02-24-2008, 13:21
Oil pressure gauge
Ernie: At one time I had a direct reading guage on that rig. Look
just above the pan on the curb side. That will at least tell you if
you have good oil pressure.
> Ernie- 83PT40
> Buffalo, Wy
02-24-2008, 13:24
Oil pressure gauge
Ernie, I agree with what Bill is saying. Check for corrosion/loose wires at both ends. I have seen both the sending unit and the gauge cause this problem. With the age of your bus it could be either. I would lean towards the sending unit if the previous checks don't work for you. Good Luck, George Burke 1977FC31 Charlotte
On Sun, Feb 24, 2008 at 7:14 PM, Ernest Ekberg <"erniecarpet@aol.com"> wrote:
Ernie- 83PT40
Buffalo, Wy
02-24-2008, 14:03
Oil pressure gauge
On the last leg of the trip,
Just a few more miles and a few more climbs.
Bill 88 FC
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
> I'm wondering if that sending unit is located beside the direct
reading
> gauge that Ron just mentioned?
> Ernie Ekberg
> 83PT40
> Buffalo, Wy, on my way to Livingston, Mt in the am---if it don't SNOW
> **************Ideas to please picky eaters. Watch video on AOL
Living.
> (http://living.aol.com/video/how-to-pleas...er/rachel-
campos-duffy/
> 2050827?NCID=aolcmp00300000002598)
02-24-2008, 15:16
Oil pressure gauge
Ernie, Check and make sure the oil level is as it should be. I know
you alrady did this but stranger things have happened. Look for loose
or coroded connections. If the sending unit goes out it is usually
dead, not intermitent. MIke McMahan
if
> Ernie- 83PT40
> Buffalo, Wy
02-24-2008, 15:44
Oil pressure gauge
I believe that is the case Ernie.
reading
> Ernie Ekberg
> 83PT40
Living.
(http://living.aol.com/video/how-to-pleas...pos-duffy/
02-24-2008, 16:20
Oil pressure gauge
Good point Mike, bet it is the gauge and not the sender???? Or a
wire grounding out on the way????? But you should not rule out
oilpressure reading being correct!!! Ernie has a Detroit6V92
The 3208Cats have a major oil pressure isssue that added a interval
replacement of the oil screen pickup tube in the pan. I had a 1985
3208T lose the oil pickup and droped it in the pan. The entire pipe
cracked off at the mounting because the screen cantilevers off the
pipe and constant vibration proved a crack. Cat Parts Clerk told me
it is a common issue and the pickup was in stock.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Mike McMahan"
know
loose
usually
has
wonder
> if
> > Ernie- 83PT40
> > Buffalo, Wy
02-24-2008, 20:58
Oil pressure gauge
Mike, my engine's "comfort" range is operating about 4 quarts low. The oil level holds pretty steady, there. This will be a spring time project upon my arrival in Livingston. Thanks
83PT40
Buffalo, Wy
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
