Racor Filter
07-09-2005, 11:13
Racor Filter
don, i have seen a couple of Racor's that were mounted pretty low on the
frame. it could have happened. Mine is up almost 18 inches above the tank and couldn't siphon. ERnie in montana- maybe bringing the coach up here where it's cool next month [Non-text portions of this message have been removed] |
07-09-2005, 11:48
Racor Filter
In a message dated 7/9/2005 11:14:07 P.M. Eastern Daylight Time,
erniecarpet@... writes: don, i have seen a couple of Racor's that were mounted pretty low on the frame. it could have happened. Mine is up almost 18 inches above the tank and couldn't siphon. ERnie in montana- maybe bringing the coach up here where it's cool next month Hay Ernie I would mind being in Montana myself. Tomorrow I think I will try it with taking the top off of the Racor & see if that doesn't brake the siphon. I had never tried to drain it before Just a little to get any settlement out of it. Tom I know the key wasn't on in the rear because it will start from up front& it won't if the key is on in the rear. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
07-09-2005, 15:25
Racor Filter
If you got more then a coffee can out of your racor, then you were
syphoning it out of the tank. No matter how hard you try you cant get a gallon of diesel from a quart jar racor does not have to be below the tank. If the lines are already filled and I assume they were, you could probably have taken fuel out of the bottom of the racor until you ran the tank dry. I have a strong feeling that you had the key on maybe from the rear? tom 1982 FC35 Vernon Center,NY At 10:43 PM 7/9/2005 -0400, you wrote: >Hi All I have a dumb question about the racor filter. A year and a half >ago I had a shop take my filter apart & clean it. The other day I was >going to >clean it myself & I started draining the fuel out of the bottom of the >filter. I got about 4 gallons out of it & it was still draining. I was >wandering if >it was siphoning out of the fuel tank??? Is that a possibility? > Don > 89 SP 36' > Butler, PA > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > |
07-10-2005, 12:20
Racor Filter
About four days ago I did the same thing. If you take the cap of the top of
the racor, it will no longer siphon from the tank. dandarst86fc35rbhuntleyil. >From: dspithaler@... >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Racor Filter >Date: Sat, 9 Jul 2005 23:09:57 EDT > > >In a message dated 7/9/2005 10:55:29 P.M. Eastern Daylight Time, >erniecarpet@... writes: > >don, thats strange. When I cleaned my racor I was able to just use a >coffee > >can to catch my diesel. was your key on? ernie- 83pt 40 in montana > > > > >No the key wasn't on but I hadn't unscrewed the top yet do you think it >could siphon out of the tank? > Don > 89 SP 36' > Butler, PA > > >[Non-text portions of this message have been removed] > |
