Tooo much voltage!
02-26-2007, 14:07
Tooo much voltage!
Ron,
Yes, I have done that on our last BB and on our boat. Ample Power has a routine
to modify the regulator that will remove the built-in reg. and bring out the
field wire. I think you'll need to email David Smead or others at Ample Power
since I don't know if it is to be found on the website. David is the
owner/designer/engineer of the place and sometimes is not available.
Good luck. Let us know how it turns out if you do it.
Sent: Monday, February 26, 2007 2:14 PM
Subject: [WanderlodgeForum] Re: Tooo much voltage!
Thanks Dick: Can you use the same alternators and simply remove the
built-in regulator?
--- In
WanderlodgeForum@yahoogroups.com,
"Richard Hayden"
> Ron, I've had good luck with these on boat and bus..
http://www.amplepower.com/products/ns2/index.html<http://www.amplepower.com/prod\
ucts/ns2/index.html><http://www.amplepower.com/products/ns2/index.html<http://ww\
w.amplepower.com/products/ns2/index.html>>
> From: ronmarabito2002
> To:
WanderlodgeForum@yahoogroups.com to:WanderlodgeForum@yahoogroups.com>
> Sent: Monday, February 26, 2007 8:02 AM
> Jeff: Not sure that I agree with you on internal. I have lost 2
> regulators recently and it is a royal pain in the *&%$ to get to under
> the bedroom floor. I think I'm going to explore external regulators
> that are convenient to replace.
> --- In
WanderlodgeForum@yahoogroups.com to:WanderlodgeForum@yahoogroups.com>,
"Jeff Miller"
> > Does this coach have the remote regulator or alternator with
internal
> > regulator?
> > If remote, I'd suggest replacing it with internally regulated.
It can
> > be fixed as-is, but an open circuit between the regulator and the
> > coach can cause the regulator to see no voltage and go to full
output.
> > - Jeff Miller
> > in Holland, MI
> > --- In
WanderlodgeForum@yahoogroups.com to:WanderlodgeForum%40yahoogroups.com>,
"webdarn" wrote:
> > > About two years ago, my 82 35 FC began cooking my batteries with
> > over
> > > 16 volts. I removed the alternator and regulator and the
alternator
> > > shop bench tested both and found no problem. After reinstalling,
> > > still over 16 volts.
> > > I bought a programable Xantrex regulator and everything worked
fine
> > > for two years, now nothing. I plugged the wiring to the origiinal
> > > regulator back in and the old problem is back, 16.1 volts.
> > > Any thoughts?
> > > Andy Clayton
> > > '82 35FC
02-26-2007, 16:48
Tooo much voltage!
Thanks Dick. I'll get a hold of him.
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
> Ron,
has a routine to modify the regulator that will remove the built-in
reg. and bring out the field wire. I think you'll need to email David
Smead or others at Ample Power since I don't know if it is to be found
on the website. David is the owner/designer/engineer of the place and
> To:
> built-in regulator?
> --- In
"Richard Hayden"
> > To:
under
> > --- In
> "Jeff Miller"
> internal
> > > regulator?
> It can
> output.
> > > - Jeff Miller
> > > in Holland, MI
> > > --- In
with
> > > over
> alternator
> fine
origiinal
> > > > Any thoughts?
> > > > Andy Clayton
> > > > '82 35FC
02-27-2007, 03:25
Tooo much voltage!
Andy,
Check price at fleetsource dot com.
Howard Truitt, 86 PT40, Camilla, Ga.
Sent: Monday, February 26, 2007 7:34 PM
--- In WanderlodgeForum@yahoogroups.com, "Andy Clayton"
>My local heavy duty alternator dealer suggested to replace the old
alternator and external regulator (both obsolete) with a new Leece-
Neville 160 amp. Cost over the counter is $375.00 plus tax. Does
this sound about par?
Andy Clayton
'82 35 FC
> My alternator has an external voltage regulator that is mounted
above the
> batteries and has a small harness connecting it to the alternator.
I
> unplugged the original two years ago and installed the Xantrax
regulator.
> It worked fine for two years, now nothing.
> Andy Clayton
> '82 35FC
> __________________________________________________________
> Refi Now: Rates near 39yr lows! $430,000 Mortgage for $1,399/mo -
Calculate
> new payment
> http://www.lowermybills.com/lre/index.js...=lmb-9632-
17727&moid=7581
Checked by AVG Free Edition.
Version: 7.1.412 / Virus Database: 268.18.3/697 - Release Date: 2/22/2007
Loading...
