propane fill
03-03-2007, 17:01
propane fill
ASME tanks like we have are exempt from inspection. Also the tank is purged
when the small valve is opened when filling. It is shut when a solid white spray is emitted, the complete the fill. Also at sea level, our 48 gallon tanks at 80% fill is only 39 gallons. That figure changes with cold and altitude. If your in cold country and the tank level is down around 1/4, the pressure is not going to be high enough to run 3 lp heaters. If you find your having a problem in the snow or just plain cold, you can set a drop light in the compartment to raise the boiling point of LP to increase the pressure until you can fill. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 09:17 PM 3/3/2007 -0600, you wrote: >They seem to be inconsistent. The Flying J in North Platt does not open the >valve, Oklahoma City does, El Paso does not, and Eloy does. Last time I was >in North Platt a couple of weeks ago they said they would not fill the tank >because of it's age until it was inspected. Went on down the road and >filled it in Oklahoma City. Any one else run into this? > >- Chuck Wheeler - >82 FC 31 SB >Fort Worth, TX > > |
03-04-2007, 03:51
propane fill
Think pointing to "ASME-inspection exempt" stenciled
in RED on the tank would get you the re-fill? They don't have to know you did the art work. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > ASME tanks like we have are exempt from inspection. Also the tank is purged > when the small valve is opened when filling. It is shut when a solid white > spray is emitted, the complete the fill. Also at sea level, our 48 gallon > tanks at 80% fill is only 39 gallons. That figure changes with cold and > altitude. If your in cold country and the tank level is down around 1/4, > the pressure is not going to be high enough to run 3 lp heaters. If you > find your having a problem in the snow or just plain cold, you can set a > drop light in the compartment to raise the boiling point of LP to increase > the pressure until you can fill. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 09:17 PM 3/3/2007 -0600, you wrote: > >They seem to be inconsistent. The Flying J in North Platt does not open the > >valve, Oklahoma City does, El Paso does not, and Eloy does. Last time I was > >in North Platt a couple of weeks ago they said they would not fill the tank > >because of it's age until it was inspected. Went on down the road and > >filled it in Oklahoma City. Any one else run into this? > > > >- Chuck Wheeler - > >82 FC 31 SB > >Fort Worth, TX > > > > > |
