Removing the doghouse 84FC35
03-29-2007, 09:42
Your Cat dealer sells coolant test strips, and a "SCA" coolant
additive. The Cat 3208 on your coach does not use a coolant filter,
so that is not a avenue to add the SCA.
Dan
Prior 83 FC35, current 94 BMC 37'
NM
--- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> Yep, very sure. I may install one later but right now I just want
to
> attend to the immediate maintenance issues. Seems like pulling the
> radiator is not too much trouble? I need to change the coolant
> anyway.
> Speaking of coolant --- I've heard mention of coolant conditioners
> and checking the pH level? Do you know about that? Some have said
> it may be in the form of a filter?
> Thanks, Keith
> 84FC35
> --- In WanderlodgeForum@yahoogroups.com, "ac7880"
> > Since you have an 84, I am guessing you do indeed have the swing
> > radiator. Are your sure it is not a swing radiator?
> > Dan prior 83 Fc35
> > NM
> > wrote:
> > > Unfortunately the folks I bought the bird from were not very
> > familiar
> > > with the maintenance schedule. It appears the Bird was
> maintained
> > on
> > > a regular schedule but was stored outside. It has a very new
> > > appearance on the inside but the outside has suffered a
little.
> > Not
> > > much though. It was a "family" bus. Several brothers used the
> bus
> > > from time to time and none of them were real clear on what had
> been
> > > done. I had a friend and fellow bird owner, Robert Britton,
check
> > it
> > > out for me. I drove it from San Jose to San diego 500+ miles
with
> > no
> > > problems.
> > > This mobile mechanic was recommended by a local and well
> respected
> > RV
> > > shop in Escondido. But I agree and don't plan on letting him
do
> > > anything except general maintenance. I like to do as much of
> > > work as I can. Doghouse removal is one of the things I'll do
> > before
> > > having the valve adjustment done. Same with the hoses and
> belts.
> > > The air filter is just like yours and shouldn't be a problem.
> > > I plan to turn it into a "proven" coach by putting some miles
> > > some usage on it.
> > > So tomorrow I'm getting the front tires replaced and then the
> > general
> > > maintenance stuff. Just trying to get a little peace of mind
> > before
> > > driving to Arizona in April.
> > > I guess I'll have to save the coolant change, belts and hoses
for
> > > another weekend. I'll get the mobile mechanic to help me out.
> > I'll
> > > do the grunt work.
> > > Then I'll need to get the tranny serviced...
> > > It never ends does it? But it's been a lot of fun so far!
> > > Keith
> > > 84FC35
> > > --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
> > > wrote:
> > > > Keith,
> > > > If your air cleaner filter is mounted on the top of the
engine
> > like
> > > mine is, there is
> > > > absolutely no reason to remove the doghouse to change it.
It's
> a
> > > large, square, metal box
> > > > that sits right on top of the turbo intake. I recently
changed
> > > mine out in 20-30 minutes.
> > > > Bear in mind, there are various skill levels out there when
it
> > > comes to mechanical help.
> > > > This guy may be able to "check" belts and hoses but I
wouldn't
> > let
> > > him near the 3208
> > > > engine internals (I'm talking valve adjustments, etc) unless
he
> > is
> > > a trained, experienced,
> > > > diesel mechanic. Many of the really qualified people don't
> like
> > to
> > > mess with motorhomes
> > > > and things like doghouse removal, so you will need to talk to
> > other
> > > Bird owners in your
> > > > area or conduct your own search to find someone that CAN do
it
> > and
> > > WANTS to do it at
> > > > some reasonable cost. Hint...your local Caterpillar shop may
> do
> > > the job, on their terms,
> > > > but you will pay very dearly. My first valve
> adjustment/injector
> > > change cost $2,400 done
> > > > by Cat. This was after they estimated the cost at $800.
They
> > > blamed it all on the time it
> > > > took to remove and replace the doghouse.
> > > > There is no way to check condition, replace belts and
retension
> > > your belts without
> > > > removing the radiator. Same goes for hoses. There are quite
a
> > > number of hoses you can't
> > > > even really see from above or below the engine. I open up
> > > front or our coach at least
> > > > annually to look things over. Check the file I posted in the
> > files
> > > section under "3208 Belts
> > > > FC" if you want more data on belts and tensioning.
> > > > Changing oil/filters, air filter belts and hoses is a good
> place
> > to
> > > start. Do you know the
> > > > original owner so you can find out when and what maintenance
> > items
> > > he has done
> > > > recently? There is a real laundry list of other items, as
I'm
> > sure
> > > you're aware, of other
> > > > things to look at. I can send you a maintenance spreadsheet
I
> > use
> > > to keep track of stuff on
> > > > our coach if you're interested.
> > > > Finding an 84FC with only 36,000 miles is quite a find. If
it
> > was
> > > stored and maintained
> > > > well you are in luck. Low mileage is great from a cosmetic
> wear
> > > standpoint but these units
> > > > do best from a mechanical standpoint when they are used
> regularly.
> > > > Regards, Eric in San Antonio
> > > > 84FC35SBWL2
> > > wrote:
> > > > > I just bought the Bird and I'm trying to catch up on some
of
> > the
> > > more
> > > > > immediate maintenance issues. Oil/filter change, fuel
> filter,
> > > air
> > > > > filter, check belts and hoses, lube the chasis, etc. The
guy
> > > said he
> > > > > can do most of this in three hours. However, as it turns
> out,
> > > this
> > > > > Bird has 36,000 miles so it seems like a good time to
adjust
> > the
> > > > > valves.
> > > > > But one thing at a time... I don't have a swing radiator.
> I'm
> > > just
> > > > > wondering if he can get at the air filter without removing
> the
> > > dog
> > > > > house. And is there any access to check/adjust the belts
> from
> > > the
> > > > > bottom?
> > > > > Keith
> > > > > 84FC35
> > > > > wrote:
> > > > > > Keith,
> > > > > > You won't need to remove the doghouse to check the belts,
> > hoses
> > > and
> > > > > air filter but you
> > > > > > will need to open up the front of the coach which is much
> > > easier
> > > > > than removing the
> > > > > > doghouse. If you have a swing radiator, it will be a
> pretty
> > > short
> > > > > job to get to the front of
> > > > > > the engine. If you don't have a swing radiator (I don't)
> you
> > > will
> > > > > need to drain the radiator
> > > > > > and remove it. Takes about an hour when you're used to
> doing
> > > it.
> > > > > > Removing the doghouse is required when you need to get
into
> > the
> > > top
> > > > > of the engine to
> > > > > > adjust valves, replace injectors, etc. I posted a
> > Wanderlodge
> > > > > procedure for this in the Files
> > > > > > section of this forum. I just had an experienced BB
> mechanic
> > > pull
> > > > > the doghouse to do
> > > > > > some engine work. Took him 2 hours to get it out and 2
> hours
> > > to
> > > > > put it back in. It's heavy
> > > > > > and cumbersome to work with in a fairly tight area.
Avoid
> > this
> > > > > unless it's time to adjust
> > > > > > valves (every 40,000 miles per Caterpillar).
> > > > > > 84FC35SBWL2
> > > > > wrote:
> > > > > > > I recently saw a post on removing the doghouse. I'm
> having
> > > some
> > > > > > > maintenance done tomorrow by a mobile mechanic and
> thought
> > it
> > > > > would be
> > > > > > > a good idea to be familiar with doghouse removal. He
says
> > he
> > > will
> > > > > check
> > > > > > > all the belts , hoses, and air filter, etc. I think it
> > > > > says "dynapak"
> > > > > > > on the filter housing and I'm certain I'll need to
remove
> > the
> > > > > doghouse
> > > > > > > to get at the belts, etc.
> > > > > > > Your help is appreciated, Keith
> > > > > > > 84FC35
03-29-2007, 10:00
Thanks! That's good info. I guess I better get busy finding my
local Cat dealer.
Keith
84FC35
filter,
> Dan
> NM
want
> to
> > anyway.
conditioners
> > Thanks, Keith
> > 84FC35
swing
> > > Dan prior 83 Fc35
> > > NM
> > > familiar
> > maintained
> > > on
> little.
> > > Not
> > bus
had
> > been
> check
> > > it
> with
> > > no
> > > > problems.
> > respected
> > > RV
> do
> the
> > > before
> > belts.
> and
> > > > some usage on it.
> > > general
> > > before
> for
out.
> > > I'll
> > > > do the grunt work.
> > > > Keith
> > > > 84FC35
> > > > wrote:
> > > > > Keith,
> engine
> > > like
> > > > mine is, there is
> It's
> > a
> changed
> it
> wouldn't
> > > let
> > > > him near the 3208
unless
> he
> > > is
> > like
> > > to
to
> > > other
> > > > Bird owners in your
> it
> > > and
> > > > WANTS to do it at
may
> > do
> > adjustment/injector
> They
> retension
> > > > your belts without
quite
> a
> the
> > > files
> > place
> > > to
maintenance
> > > items
> > > > he has done
> I'm
> > > sure
spreadsheet
> I
> > > use
> it
> > > was
> > wear
> > regularly.
> > > > > 84FC35SBWL2
> of
> > > the
> > > > more
> > filter,
> > > > air
> guy
> > > > said he
> > out,
> > > > this
> adjust
> > > the
> > > > > > valves.
radiator.
> > I'm
> > > > just
removing
> > the
> > > > dog
> > from
> > > > the
> > > > > > bottom?
> > > > > > Keith
> > > > > > 84FC35
> > > > > > wrote:
> > > > > > > Keith,
belts,
> > > hoses
> > > > and
> > > > > > air filter but you
much
> > > > easier
> > > > > > than removing the
> > pretty
> > > > short
don't)
> > you
> > > > will
> > doing
> > > > it.
> into
> > > the
> > > > top
> > > > > > of the engine to
> > > Wanderlodge
> > mechanic
> > > > pull
> > > > > > the doghouse to do
> > hours
> > > > to
> Avoid
> > > this
> > > > > > > 84FC35SBWL2
Strehle"
> > having
> > > > some
> > thought
> > > it
> > > > > > would be
> says
> > > he
> > > > will
> > > > > > check
it
> > > > > > says "dynapak"
> remove
> > > the
> > > > > > doghouse
> > > > > > > > 84FC35
03-29-2007, 10:42
Keith,
I have an 84FC without a swing radiator either so don't feel lonesome on this
issue.
Pulling the radiator is a pretty simple proposition once you've done it and know
what to
expect. Here is how it goes:
1. Get under the coach and close the three block valves that isolate the engine
cooling
from the coach heating loops.
2. Disconnect the electrical wires that run to the driving lights in the
bumper.
3. Put a floor jack or other means of support under your front bumper and
remove the
four large bolts holding it in place.
4. Take the bumper and set it aside.
5. Open the door in the front of the coach and remove the radiator cap. Open
radiator drain cock and drain the coolant to a suitable container(s). I use 3
five gallon
plastic gas cans. Total liquid capacity is 12-15 gallons.
6. Remove the hexhead rivnuts holding the middle steel panel in place. I use a
cordless
drill to get these out expeditiously. You will also find a couple of phillips
screws hiding
behind the black vinyl trim strip that need to be removed to get the panel
removed.
7. Open up the doghouse hatch in the coach and remove the hose clamps on the
large
and small hoses you see on the top radiator tank. Unhook the temperature sensor
wire
from the tank.
8. Remove the hose clamps on the radiator hose at the bottom of the radiator.
9. You will find that, with the assistance of a floor jack or other lifting
device, you can tilt
the radiator forward and that will allow you to do a lot of work on the front of
the engine
without completely removing the radiator.
10. If you choose to completely remove the radiator, you will have to
disconnect the
transmission cooling hoses from the bottom of the radiator. When I do this, I
use rubber
stoppers to plug the hoses so I don't lose a lot of transmission fluid. You
will have to
drain the transmission fluid remaining in the radiator but that isn't a
significant volume.
When you're done. Reverse the above. Like I said, takes about an hour each
way. Good
luck with your new to you coach. BB's are a great way to travel and live.
84FC35SBWL2
> Yep, very sure. I may install one later but right now I just want to
> anyway.
> Thanks, Keith
> 84FC35
> > Dan prior 83 Fc35
> > NM
> > familiar
> maintained
> > on
> > > appearance on the inside but the outside has suffered a little.
> > Not
> bus
> been
> > > done. I had a friend and fellow bird owner, Robert Britton, check
> > it
> > > out for me. I drove it from San Jose to San diego 500+ miles with
> > no
> > > problems.
> respected
> > RV
> > > shop in Escondido. But I agree and don't plan on letting him do
> > > anything except general maintenance. I like to do as much of the
> > before
> belts.
> > > I plan to turn it into a "proven" coach by putting some miles and
> > > some usage on it.
> > general
> > before
> > > I guess I'll have to save the coolant change, belts and hoses for
> > I'll
> > > do the grunt work.
> > > Keith
> > > 84FC35
> > > wrote:
> > > > Keith,
> > > > If your air cleaner filter is mounted on the top of the engine
> > like
> > > mine is, there is
> > > > absolutely no reason to remove the doghouse to change it. It's
> a
> > > > that sits right on top of the turbo intake. I recently changed
> > > > Bear in mind, there are various skill levels out there when it
> > > > This guy may be able to "check" belts and hoses but I wouldn't
> > let
> > > him near the 3208
> > > > engine internals (I'm talking valve adjustments, etc) unless he
> > is
> like
> > to
> > other
> > > Bird owners in your
> > > > area or conduct your own search to find someone that CAN do it
> > and
> > > WANTS to do it at
> do
> adjustment/injector
> > > > by Cat. This was after they estimated the cost at $800. They
> > > > There is no way to check condition, replace belts and retension
> > > your belts without
> > > > removing the radiator. Same goes for hoses. There are quite a
> > > > even really see from above or below the engine. I open up the
> > files
> place
> > to
> > items
> > > he has done
> > > > recently? There is a real laundry list of other items, as I'm
> > sure
> > > > things to look at. I can send you a maintenance spreadsheet I
> > use
> > > > Finding an 84FC with only 36,000 miles is quite a find. If it
> > was
> wear
> regularly.
> > > > 84FC35SBWL2
> > > wrote:
> > > > > I just bought the Bird and I'm trying to catch up on some of
> > the
> > > more
> filter,
> > > air
> > > > > filter, check belts and hoses, lube the chasis, etc. The guy
> > > said he
> out,
> > > this
> > > > > Bird has 36,000 miles so it seems like a good time to adjust
> > the
> > > > > valves.
> I'm
> > > just
> the
> > > dog
> from
> > > the
> > > > > bottom?
> > > > > Keith
> > > > > 84FC35
> > > > > wrote:
> > > > > > Keith,
> > hoses
> > > and
> > > > > air filter but you
> > > easier
> > > > > than removing the
> pretty
> > > short
> you
> > > will
> doing
> > > it.
> > > > > > Removing the doghouse is required when you need to get into
> > the
> > > top
> > > > > of the engine to
> > Wanderlodge
> mechanic
> > > pull
> > > > > the doghouse to do
> hours
> > > to
> > > > > > and cumbersome to work with in a fairly tight area. Avoid
> > this
> > > > > > 84FC35SBWL2
> having
> > > some
> thought
> > it
> > > > > would be
> > > > > > > a good idea to be familiar with doghouse removal. He says
> > he
> > > will
> > > > > check
> > > > > says "dynapak"
> > > > > > > on the filter housing and I'm certain I'll need to remove
> > the
> > > > > doghouse
> > > > > > > 84FC35
03-29-2007, 10:46
Hi Ernie,
Yes, he did remove the top cover first. I ain't even gonna try to lift that
thing on my own.
My back isn't what it used to be and doctors charge even more than diesel
mechanics.
Eric in San Antonio
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
> Eric, did your mechanic take the top cover off the doghouse? Even then, it
> takes 2 people to get the bottom section out of the coach- unless you are
> really strong.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
> ************************************** See what's free at http://www.aol.com.
03-29-2007, 10:53
Hmmmmm? Don't know? But the previous owner told me there was not a
swing radiator. And when I looked I didn't see anything that looked
like hinges. I'll look again tomorrow just to be sure.
Thanks again,
Keith
84FC35
> Keith- on your front bumper, is there 2 small hinges under the
bottom edge?
> You still have 4 bolts on the bumper. Just curious.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
http://www.aol.com.
03-29-2007, 11:01
Thanks Eric, I'm sure I can get this done. I have all the tools and
most of the skill required. Or is it the other way around? My
biggest challenge is where I live. I live on a Cul-de-Sac and the
bus sticks out into the street when I pull into the driveway.
Neighbors are pretty tolerant but I don't want to push my luck....
Keith
San Diego
84FC35
> Keith,
lonesome on this issue.
done it and know what to
isolate the engine cooling
in the bumper.
bumper and remove the
cap. Open the
(s). I use 3 five gallon
place. I use a cordless
of phillips screws hiding
the panel removed.
clamps on the large
temperature sensor wire
> from the tank.
the radiator.
lifting device, you can tilt
the front of the engine
to disconnect the
do this, I use rubber
fluid. You will have to
isn't a significant volume.
hour each way. Good
and live.
> 84FC35SBWL2
want to
> > anyway.
conditioners
> > Thanks, Keith
> > 84FC35
swing
> > > Dan prior 83 Fc35
> > > NM
> > > familiar
> > maintained
> > > on
little.
> > > Not
> > bus
had
> > been
check
> > > it
with
> > > no
> > > > problems.
> > respected
> > > RV
do
> > > before
> > belts.
> > > > some usage on it.
> > > general
> > > before
for
out.
> > > I'll
> > > > do the grunt work.
> > > > Keith
> > > > 84FC35
> > > > wrote:
> > > > > Keith,
engine
> > > like
> > > > mine is, there is
It's
> > a
changed
it
wouldn't
> > > let
> > > > him near the 3208
unless he
> > > is
> > like
> > > to
to
> > > other
> > > > Bird owners in your
it
> > > and
> > > > WANTS to do it at
may
> > do
> > adjustment/injector
They
retension
> > > > your belts without
quite a
> > > files
> > place
> > > to
maintenance
> > > items
> > > > he has done
I'm
> > > sure
spreadsheet I
> > > use
it
> > > was
> > wear
> > regularly.
> > > > > 84FC35SBWL2
of
> > > the
> > > > more
> > filter,
> > > > air
guy
> > > > said he
> > out,
> > > > this
adjust
> > > the
> > > > > > valves.
radiator.
> > I'm
> > > > just
removing
> > the
> > > > dog
> > from
> > > > the
> > > > > > bottom?
> > > > > > Keith
> > > > > > 84FC35
> > > > > > wrote:
> > > > > > > Keith,
belts,
> > > hoses
> > > > and
> > > > > > air filter but you
much
> > > > easier
> > > > > > than removing the
> > pretty
> > > > short
don't)
> > you
> > > > will
> > doing
> > > > it.
into
> > > the
> > > > top
> > > > > > of the engine to
> > > Wanderlodge
> > mechanic
> > > > pull
> > > > > > the doghouse to do
> > hours
> > > > to
Avoid
> > > this
> > > > > > > 84FC35SBWL2
Strehle"
> > having
> > > > some
> > thought
> > > it
> > > > > > would be
says
> > > he
> > > > will
> > > > > > check
it
> > > > > > says "dynapak"
remove
> > > the
> > > > > > doghouse
> > > > > > > > 84FC35
03-29-2007, 12:50
Keith,
Mike (previous owner) is a nice guy, but I'm not sure if he would know
if it had a swing radiator or not. From talking with him, I dont
think he did any work on the coach himself.
Look for the hinge that Ernie was asking about or a hinge on the
radiator. You have to look close for this stuff, it might be there.
Robert Britton
87FC
Hollister, California
a
looked
> Thanks again,
> Keith
> 84FC35
> bottom edge?
> > Ernie Ekberg
> > 83PT40
> > Livingston, Mt
> http://www.aol.com.
03-29-2007, 13:46
Just courious. Is there any reason the cooling system, can't be converted to
DexCool?, Permenant Antifreeze ( the green) isn't really permenant. It will
never freeze, but after time it turns from Allaline, to acid, hence the need to
check the PH level. If you don't maintain that, Radiators corrode,engines with
cylinder liners, will start pitting, etc. With Dexcool, you don't have to worry
about all that. I have converted everything I own to Dexcool and so has Penske,
all 270,000 trucks.
Keith Strehle wrote: Thanks! That's good info.
local Cat dealer.
Keith
84FC35
filter,
> Dan
> NM
want
> to
> > anyway.
conditioners
> > Thanks, Keith
> > 84FC35
swing
> > > Dan prior 83 Fc35
> > > NM
> > > familiar
> > maintained
> > > on
> little.
> > > Not
> > bus
had
> > been
> check
> > > it
> with
> > > no
> > > > problems.
> > respected
> > > RV
> do
> the
> > > before
> > belts.
> and
> > > > some usage on it.
> > > general
> > > before
> for
out.
> > > I'll
> > > > do the grunt work.
> > > > Keith
> > > > 84FC35
> > > > wrote:
> > > > > Keith,
> engine
> > > like
> > > > mine is, there is
> It's
> > a
> changed
> it
> wouldn't
> > > let
> > > > him near the 3208
unless
> he
> > > is
> > like
> > > to
to
> > > other
> > > > Bird owners in your
> it
> > > and
> > > > WANTS to do it at
may
> > do
> > adjustment/injector
> They
> retension
> > > > your belts without
quite
> a
> the
> > > files
> > place
> > > to
maintenance
> > > items
> > > > he has done
> I'm
> > > sure
spreadsheet
> I
> > > use
> it
> > > was
> > wear
> > regularly.
> > > > > 84FC35SBWL2
> of
> > > the
> > > > more
> > filter,
> > > > air
> guy
> > > > said he
> > out,
> > > > this
> adjust
> > > the
> > > > > > valves.
radiator.
> > I'm
> > > > just
removing
> > the
> > > > dog
> > from
> > > > the
> > > > > > bottom?
> > > > > > Keith
> > > > > > 84FC35
> > > > > > wrote:
> > > > > > > Keith,
belts,
> > > hoses
> > > > and
> > > > > > air filter but you
much
> > > > easier
> > > > > > than removing the
> > pretty
> > > > short
don't)
> > you
> > > > will
> > doing
> > > > it.
> into
> > > the
> > > > top
> > > > > > of the engine to
> > > Wanderlodge
> > mechanic
> > > > pull
> > > > > > the doghouse to do
> > hours
> > > > to
> Avoid
> > > this
> > > > > > > 84FC35SBWL2
Strehle"
> > having
> > > > some
> > thought
> > > it
> > > > > > would be
> says
> > > he
> > > > will
> > > > > > check
it
> > > > > > says "dynapak"
> remove
> > > the
> > > > > > doghouse
> > > > > > > > 84FC35
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
03-29-2007, 14:07
My Cat dealer only sells the test strips in huge quantities. 50 I
think, Thes strips have a limited shelf life so most would end up in
the garbage. I still have not found a source for small quantities of
these strips. There are some multi purpose strips but they are not
accurate.
Bruce
1988FC35
03-29-2007, 15:58
James, One thing I can think of is the arduous task of evacuating the
green from the entire system. I understand Dexcool is not compatible
with the green and or the additives that went along with the green
during interval PM. RV's have uncommon factors that may not have
studied in development or testing. Low use; long periods of storage;
use of fluids for other applications; volume of fluid. Penske may
only max ownership of a fleetvehicle for 6 years. I wonder if the
sales term 'permanent' is that period one owner retains a vehicle?
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, James Harvie
converted to DexCool?, Permenant Antifreeze ( the green) isn't really
permenant. It will never freeze, but after time it turns from
Allaline, to acid, hence the need to check the PH level. If you don't
maintain that, Radiators corrode,engines with cylinder liners, will
start pitting, etc. With Dexcool, you don't have to worry about all
all 270,000 trucks.
> local Cat dealer.
> Keith
> 84FC35
> filter,
> > Dan
> > NM
> want
> > to
> the
> > > anyway.
> conditioners
> > > Thanks, Keith
> > > 84FC35
> swing
> > > > Dan prior 83 Fc35
> > > > NM
very
> > > > familiar
> > > maintained
> > > > on
new
> > little.
> > > > Not
> the
> > > bus
> had
> > > been
> > check
> > > > it
miles
> > with
> > > > no
> > > > > problems.
> > > respected
> > > > RV
him
> > do
of
> > the
do
> > > > before
> > > belts.
problem.
miles
> > and
> > > > > some usage on it.
> > > > general
mind
> > > > before
hoses
> > for
> out.
> > > > I'll
> > > > > do the grunt work.
> > > > > Keith
> > > > > 84FC35
> > > > > wrote:
> > > > > > Keith,
> > engine
> > > > like
> > > > > mine is, there is
> > It's
> > > a
> > changed
when
> > it
> > wouldn't
> > > > let
> > > > > him near the 3208
> unless
> > he
> > > > is
don't
> > > like
> > > > to
talk
> to
> > > > other
> > > > > Bird owners in your
do
> > it
> > > > and
> > > > > WANTS to do it at
> may
> > > do
> > > adjustment/injector
> > They
> > retension
> > > > > your belts without
> quite
> > a
> > the
> the
> > > > files
good
> > > place
> > > > to
> maintenance
> > > > items
> > > > > he has done
> > I'm
> > > > sure
> spreadsheet
> > I
> > > > use
If
> > it
> > > > was
cosmetic
> > > wear
> > > regularly.
> > > > > > 84FC35SBWL2
some
> > of
> > > > the
> > > > > more
> > > filter,
> > > > > air
The
> > guy
> > > > > said he
turns
> > > out,
> > > > > this
> > adjust
> > > > the
> > > > > > > valves.
> radiator.
> > > I'm
> > > > > just
> removing
> > > the
> > > > > dog
belts
> > > from
> > > > > the
> > > > > > > bottom?
> > > > > > > Keith
> > > > > > > 84FC35
> > > > > > > wrote:
> > > > > > > > Keith,
> belts,
> > > > hoses
> > > > > and
> > > > > > > air filter but you
> much
> > > > > easier
> > > > > > > than removing the
> > > pretty
> > > > > short
> don't)
> > > you
> > > > > will
to
> > > doing
> > > > > it.
get
> > into
> > > > the
> > > > > top
> > > > > > > of the engine to
> > > > Wanderlodge
> > > mechanic
> > > > > pull
> > > > > > > the doghouse to do
2
> > > hours
> > > > > to
> > Avoid
> > > > this
> > > > > > > > 84FC35SBWL2
> Strehle"
> > > having
> > > > > some
> > > thought
> > > > it
> > > > > > > would be
He
> > says
> > > > he
> > > > > will
> > > > > > > check
> it
> > > > > > > says "dynapak"
> > remove
> > > > the
> > > > > > > doghouse
> > > > > > > > > 84FC35
