1992 WB40 Spare wire from front to back?
04-01-2007, 14:46
Thanks for the note.
I have it on pin 1 on the 7 pin connector. Aux (battery) is pin 4, and toad brake signal is on pin 2. I am using the center pin to tie into the brake controller in the TOAD to send a signal back to the coach that I will use to illuminate a light on the dash to tell me the TOAD brakes are on. I used 14 gauge for the BATT wire which I will replace with 10 gauge when I get a chance to pick some up and replace it. Michael Brundrige 1992 WB40 - newbie Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Michael, the toad needs a ground that is common > to the coach for the aux 12 volts, otherwise no > reference, no charging. > bob janes, 87fc35, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > Well as luck would have it, I took the front nose panel off where > > all the relays and fuses are and I saw two wires that where in > > convoluted tubing and has a hand written label that said 'run to > > back' I jumped under the coach out back and sure enough there they > > where. I ohmed them to verify and sure enough. So some kind sole > > before me had already done the hard work So I just need tohook > > it to the controller in the coach now. > > > > Also I needed to run 12 volt from the engine batteries to TOAD to > > charge the battery. I was having a hard time finding a wire in the > > engine bay that was only hot when the ignition was on so I could > put > > it to a relay so the wire to the toad battery is only hot when the > > coach ignition was on. Then I looked up and remembered the rear > > coach ignition box, so I removed the screws and determined that the > > center post on one side of the front/off/rear switch is hot only > > when the front or rear ignition switch is on. So I tapped into > that > > and ran it to the relay, so now I have a hot AUX going to the toad > > only when the ignition is on. > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > Is there a spare wire that runs from the front to the back of a > > 1992 > > > WB40 that I can use for my brake controller? > > > > > > I have a US Gear D-Celerator brake system that needs one wire to > > tell > > > the system in the toad to apply the brake, and another to keep > the > > > battery charged. I am not worried about the one for charging as > I > > can > > > grab that right off the back of the coach, but did not want to > > have to > > > run a wire all the way from the front to the back if a spare > > already > > > exists for that. > > > > > > Michael Brundridge > > > 1992 WB40 - newbie > > > Georgetown, TX > > > > > > |
04-02-2007, 10:04
Some times in life you need a break. You missed all the fun though!
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville,FL ----- Original Message ----- From: mbrund To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 01, 2007 8:05 PM Subject: [WanderlodgeForum] Re: 1992 WB40 Spare wire from front to back? Well as luck would have it, I took the front nose panel off where all the relays and fuses are and I saw two wires that where in convoluted tubing and has a hand written label that said 'run to back' I jumped under the coach out back and sure enough there they where. I ohmed them to verify and sure enough. So some kind sole before me had already done the hard work So I just need to hookit to the controller in the coach now. Also I needed to run 12 volt from the engine batteries to TOAD to charge the battery. I was having a hard time finding a wire in the engine bay that was only hot when the ignition was on so I could put it to a relay so the wire to the toad battery is only hot when the coach ignition was on. Then I looked up and remembered the rear coach ignition box, so I removed the screws and determined that the center post on one side of the front/off/rear switch is hot only when the front or rear ignition switch is on. So I tapped into that and ran it to the relay, so now I have a hot AUX going to the toad only when the ignition is on. --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > Is there a spare wire that runs from the front to the back of a 1992 > WB40 that I can use for my brake controller? > > I have a US Gear D-Celerator brake system that needs one wire to tell > the system in the toad to apply the brake, and another to keep the > battery charged. I am not worried about the one for charging as I can > grab that right off the back of the coach, but did not want to have to > run a wire all the way from the front to the back if a spare already > exists for that. > > Michael Brundridge > 1992 WB40 - newbie > Georgetown, TX > [Non-text portions of this message have been removed] |
So I just need to
