Air Level Master - Dim Suspension Dump Light
05-20-2007, 17:17
> Curt.. dont know... never tried it..dont know if its for motion or not. Manual says not to leave it in level for long periods of time.. Will try it soon as I need to go top off fuel Ed Gardels 89sp Arlington Texas > Ed, > What does it do when in the "level" setting? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ed Gardels wrote: > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Curt... I have the Air Level System in my 89sp and dont know how to > > use it. A rocker switch with "level" on one side and "Ride" on the > > other side. Middle position is off. All i have done is put it > > in "ride" when in motion. > > Any body else use this option?? And how?? > > Thanks > > Ed Gardels 89sp > > Arlington Texas > > > > > Leroy, > > > Bluebird offered an Air Leveling system instead of the jack system. > > I > > > believe my dash has the place holder for the air leveling switch, > > if it > > > had the system. I have the jack leveling system. > > > > > > Could be the main ground, good thought. If I understand the Lower > > Load > > > Center, it's in the generator fan/control bay, up top in that bay. > > Right? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Leroy Eckert wrote: > > > > > > > Curt: > > > > I don't have an Air Level Master that I know of. I would like to > > know > > > > what it does. I did have a ghost monitor light on the marker > > light > > > > switch and found a dirty ground. Could it possibly be the main > > ground > > > > in the lower load center. The main ground bus bar connection? > > > > > > > > Leroy Eckert > > > > 1990 WB-40 "Smoke N Mirrors" > > > > Niceville, FL > > > > ----- Original Message ----- > > > > From: Curt Sprenger > > > > To: wanderlodge@yahoogroups.com > > > > > > ; WanderlodgeForum@yahoogroups.com > > > > > > > > > > Sent: Thursday, May 17, 2007 11:56 AM > > > > Subject: [WanderlodgeForum] Air Level Master - Dim Suspension > > Dump Light > > > > > > > > What is the "Air Level Master" as labeled on the dash? Mine has a > > flat > > > > plastic plate, not a switch. It does have the LED, but it never > > lights up. > > > > > > > > I aired up the suspension system this morning. Everything aired > > up as it > > > > should. I've used my leak detector tools and have not found a > > leak one. > > > > I'll let it stand for a couple hours to see if it settles any. > > When I > > > > turn the ignition key to on I get a very dim suspension dump > > light. Any > > > > thoughts on why the dim light? > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > |
