Can Anyone Help??? Stuck with an extended generator... 84PT40!!!!
06-29-2007, 10:06
I have the light, and it comes on when I extend the tray. Strange.
Scott --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > On 6/29/07, mbulriss <mbulriss@...> wrote: > > > > Scott, > > > > I don't known the answer to that. I thought all the early/mid 80s > > with hydraulic rams had the manual lock. Looks like I was wrong in > > that assumption. Someone with another 86 will have to address your > > question. > > Scott, > > '86 PT-40 here. I have a lock. Big black lever on the front. I would > expect you should have one, too. Do you have the corresponding dash > light?? I have a red light on the dash that will come on if the gen > tray is unlocked. The digitel will also complain about it. > > I'd find out why you don't have one - previous owner modification is > my guess - and get it fixed. I'd imagine this is a critical safety > feature to keep the genset in the coach. You'd hate to lose the entire > unit into the back of a compact if you had to come to a quick stop and > the hydraulics decided not to hold it. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
06-29-2007, 10:54
Scott,
Starting to sound like a prior owner modification to remove the locking slider bar that I would not care for if it was mine. The small stop tabs at the back of the tray runners will not stop it under a hard stop. Seems like a few years back, someone posted about their genset tray sliding out and landing on the road in front of them under a hard braking scenario. Oooops! Anyone else remember that post? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX - nice and steamy right now..... --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I have the light, and it comes on when I extend the tray. Strange. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > On 6/29/07, mbulriss <mbulriss@> wrote: > > > > > > Scott, > > > > > > I don't known the answer to that. I thought all the early/mid > 80s > > > with hydraulic rams had the manual lock. Looks like I was wrong > in > > > that assumption. Someone with another 86 will have to address > your > > > question. > > > > Scott, > > > > '86 PT-40 here. I have a lock. Big black lever on the front. I would > > expect you should have one, too. Do you have the corresponding dash > > light?? I have a red light on the dash that will come on if the gen > > tray is unlocked. The digitel will also complain about it. > > > > I'd find out why you don't have one - previous owner modification is > > my guess - and get it fixed. I'd imagine this is a critical safety > > feature to keep the genset in the coach. You'd hate to lose the > entire > > unit into the back of a compact if you had to come to a quick stop > and > > the hydraulics decided not to hold it. > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > |
06-29-2007, 13:04
Yes, for some reason that is beyond my understanding, the entire
assembly has been removed. I thought it odd that BB wouldn't have put one on there, but figured they know more than me. With this conversation, though, I can see where the release lever used to stick out the front and where the bolts extended out the sides to secure it. Ah...but never fear...shadetree engineering to the rescue. Went to my local Lowes and bought two 3/4 X 3" clevis pins and pushed them through the original holes from the inside. Engages the frame perfectly and locks in with cotter pins. Tried to slide the tray with the hydraulics, and it won't budge with those on there. So I think I have solved the problem. Will be a bit less convenient to pop those out than slide the original latch, but functional. Scott --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Scott, > > Starting to sound like a prior owner modification to remove the > locking slider bar that I would not care for if it was mine. The > small stop tabs at the back of the tray runners will not stop it under > a hard stop. Seems like a few years back, someone posted about their > genset tray sliding out and landing on the road in front of them under > a hard braking scenario. Oooops! Anyone else remember that post? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX - nice and steamy right now..... > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > I have the light, and it comes on when I extend the tray. Strange. > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > > > > On 6/29/07, mbulriss <mbulriss@> wrote: > > > > > > > > Scott, > > > > > > > > I don't known the answer to that. I thought all the early/mid > > 80s > > > > with hydraulic rams had the manual lock. Looks like I was wrong > > in > > > > that assumption. Someone with another 86 will have to address > > your > > > > question. > > > > > > Scott, > > > > > > '86 PT-40 here. I have a lock. Big black lever on the front. I would > > > expect you should have one, too. Do you have the corresponding dash > > > light?? I have a red light on the dash that will come on if the gen > > > tray is unlocked. The digitel will also complain about it. > > > > > > I'd find out why you don't have one - previous owner modification is > > > my guess - and get it fixed. I'd imagine this is a critical safety > > > feature to keep the genset in the coach. You'd hate to lose the > > entire > > > unit into the back of a compact if you had to come to a quick stop > > and > > > the hydraulics decided not to hold it. > > > > > > -Ryan > > > '86 PT-40 8V92 > > > Tri-Cities, WA > > > > > > |
06-29-2007, 13:23
Scott,
Mine doesn't have a safety lock either (that I'm aware of), or a light on the dash. My ram is electric, if that has anything to do with it? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I have > wondered what the "safety" was if the ram failed... > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > You are most welcome Brian. Remember to keep a good eye on the > genset > > locking bar to make sure it stays solidly locked. You could even > put > > a bungee cord on it for extra peace of mind! If the genset slide > bar > > lock comes unlocked with the ram disconnected, there is nothing to > > keep the genset tray from sliding out on a stop. NOT a good > deal! ;^) > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > Soggy San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" wrote: > > > > > > OK.... I couldn't wait till the morning! > > > > > > I just did what you mentioned.... I did have to remove both > pins... > > > slide the RAM out of the way.. and presto! I slid the generator > into > > > position and it is locked and ready to go! > > > > > > again.... THANK YOU SO MUCH! > > > > > > I really have not been able to participate in this forum and > > > contribute to it's content as I could have.... self employeed .... > > > family of 6 .... we are also foster parents.... and a wanderlodge > > > newbe....... > > > > > > I will make time in the future to return to this forum that in > only a > > > few interactions with my questions... had made such a positive and > > > supportive effect on our families well being! > > > > > > Thank You > > > > > > Brian! > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > > > > > Brian, > > > > > > > > Sorry to hear about the funeral. > > > > > > > > Re the gen set hydraulic leak: > > > > Been there, done that. The seal is blown. NO big deal. > Adding more > > > > fluid is pointless right now. To get going NOW, you just need > to > > > > crawl under there and just pull the cotter key that holds in > the pin > > > > on the back of the genset hydraulic ram. Then pull the pin and > push > > > > the genset tray back in by hand (You may have to lift the > genset ram > > > > up to clear the frame cross rail). When all the way in, lock > the > > > > handset bar in the front. Make very sure it is secure and stays > > > > locked! You're good to go now. > > > > > > > > When you get back, you will then need to replace the seals in > the ram. > > > > About a 20 minute job. To get the correct seals, unscrew the > clevis > > > > end, on the end of the ram you disconnected and remove it. Then > > > > remove the cap on the end of the ram with a pair of water pump > pliers. > > > > As I recall, there is a "wiper" seal in the cap and a > hydraulic fluid > > > > seal in the cap. Take them to a good hydraulic shop to match > up the > > > > replacements and reinstall them the way you took them out. Put > > > > everything back together and THEN add the hydraulic fluid > (actually > > > > Dexron ATF) to the reservoir under the steps. Cycle the syetm a > > > > couple of times and you will be done. > > > > > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > VERY wet San Antonio, TX > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > wrote: > > > > > > > > > > Hello.... I hope someone can help.... > > > > > > > > > > 84 PT40 generator stuck open .... hydraulic leak from piston > that > > > > > pushes & pulls the generator tray open & closed.... how... or > > where do > > > > > I add hydraulic fluid so that I can get the generator to > slide back > > > > in??? > > > > > > > > > > Many.... many much appreciated thanks in advance.... family is > > > > > supposed to be leaving town in the morning to attend a > funeral.... > > > > > > > > > > Thank You > > > > > Brian > > > > > > > > > > > > > > > |
06-29-2007, 13:33
I think mine is electric, too...maybe we are on to something?
Scott --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Scott, > > Mine doesn't have a safety lock either (that I'm aware of), or a > light on the dash. My ram is electric, if that has anything to do > with it? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I > have > > wondered what the "safety" was if the ram failed... > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > > wrote: > > > > > > You are most welcome Brian. Remember to keep a good eye on the > > genset > > > locking bar to make sure it stays solidly locked. You could even > > put > > > a bungee cord on it for extra peace of mind! If the genset slide > > bar > > > lock comes unlocked with the ram disconnected, there is nothing to > > > keep the genset tray from sliding out on a stop. NOT a good > > deal! ;^) > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > Soggy San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > wrote: > > > > > > > > OK.... I couldn't wait till the morning! > > > > > > > > I just did what you mentioned.... I did have to remove both > > pins... > > > > slide the RAM out of the way.. and presto! I slid the generator > > into > > > > position and it is locked and ready to go! > > > > > > > > again.... THANK YOU SO MUCH! > > > > > > > > I really have not been able to participate in this forum and > > > > contribute to it's content as I could have.... self > employeed .... > > > > family of 6 .... we are also foster parents.... and a > wanderlodge > > > > newbe....... > > > > > > > > I will make time in the future to return to this forum that in > > only a > > > > few interactions with my questions... had made such a positive > and > > > > supportive effect on our families well being! > > > > > > > > Thank You > > > > > > > > Brian! > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > > wrote: > > > > > > > > > > Brian, > > > > > > > > > > Sorry to hear about the funeral. > > > > > > > > > > Re the gen set hydraulic leak: > > > > > Been there, done that. The seal is blown. NO big deal. > > Adding more > > > > > fluid is pointless right now. To get going NOW, you just > need > > to > > > > > crawl under there and just pull the cotter key that holds in > > the pin > > > > > on the back of the genset hydraulic ram. Then pull the pin > and > > push > > > > > the genset tray back in by hand (You may have to lift the > > genset ram > > > > > up to clear the frame cross rail). When all the way in, lock > > the > > > > > handset bar in the front. Make very sure it is secure and > stays > > > > > locked! You're good to go now. > > > > > > > > > > When you get back, you will then need to replace the seals in > > the ram. > > > > > About a 20 minute job. To get the correct seals, unscrew > the > > clevis > > > > > end, on the end of the ram you disconnected and remove it. > Then > > > > > remove the cap on the end of the ram with a pair of water > pump > > pliers. > > > > > As I recall, there is a "wiper" seal in the cap and a > > hydraulic fluid > > > > > seal in the cap. Take them to a good hydraulic shop to match > > up the > > > > > replacements and reinstall them the way you took them out. > Put > > > > > everything back together and THEN add the hydraulic fluid > > (actually > > > > > Dexron ATF) to the reservoir under the steps. Cycle the > syetm a > > > > > couple of times and you will be done. > > > > > > > > > > Mike Bulriss > > > > > 1991 WB40 "Texas Minivan" > > > > > VERY wet San Antonio, TX > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > wrote: > > > > > > > > > > > > Hello.... I hope someone can help.... > > > > > > > > > > > > 84 PT40 generator stuck open .... hydraulic leak from > piston > > that > > > > > > pushes & pulls the generator tray open & closed.... how... > or > > > where do > > > > > > I add hydraulic fluid so that I can get the generator to > > slide back > > > > > in??? > > > > > > > > > > > > Many.... many much appreciated thanks in advance.... family > is > > > > > > supposed to be leaving town in the morning to attend a > > funeral.... > > > > > > > > > > > > Thank You > > > > > > Brian > > > > > > > > > > > > > > > > > > > > > |
06-29-2007, 15:13
If "Electric" means what mine is (not hydraulic), I'm not sure why it would have
a latch. Mine doesn't. On 6/30/2007 at 1:33 AM Scott Forman wrote: >I think mine is electric, too...maybe we are on to something? > >Scott |
06-29-2007, 15:21
Might be ... I think mine's electric too. Open or close, when it
reaches the stop, it makes a 'click-click' noise. No safety latch. No dash lights (that I noticed --since I've always opened/closed the generator from the outside and have never looked at the dash when it's been open). On Jun 29, 2007, at 6:33 PM, Scott Forman wrote: > I think mine is electric, too...maybe we are on to something? > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > >> >> Scott, >> >> Mine doesn't have a safety lock either (that I'm aware of), or a >> light on the dash. My ram is electric, if that has anything to do >> with it? >> >> Tom Sorrentino >> 1987 PT38 >> Bedford Hills, NY >> >> >> >> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> >> wrote: >>> >>> Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I >> have >>> wondered what the "safety" was if the ram failed... >>> >>> Scott Forman >>> 86 PT38 >>> Memphis >>> >>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> >>> wrote: >>>> >>>> You are most welcome Brian. Remember to keep a good eye on the >>> genset >>>> locking bar to make sure it stays solidly locked. You could > even >>> put >>>> a bungee cord on it for extra peace of mind! If the genset > slide >>> bar >>>> lock comes unlocked with the ram disconnected, there is nothing > to >>>> keep the genset tray from sliding out on a stop. NOT a good >>> deal! ;^) >>>> >>>> Mike Bulriss >>>> 1991 WB40 "Texas Minivan" >>>> Soggy San Antonio, TX >>>> >>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" >> wrote: >>>>> >>>>> OK.... I couldn't wait till the morning! >>>>> >>>>> I just did what you mentioned.... I did have to remove both >>> pins... >>>>> slide the RAM out of the way.. and presto! I slid the > generator >>> into >>>>> position and it is locked and ready to go! >>>>> >>>>> again.... THANK YOU SO MUCH! >>>>> >>>>> I really have not been able to participate in this forum and >>>>> contribute to it's content as I could have.... self >> employeed .... >>>>> family of 6 .... we are also foster parents.... and a >> wanderlodge >>>>> newbe....... >>>>> >>>>> I will make time in the future to return to this forum that > in >>> only a >>>>> few interactions with my questions... had made such a > positive >> and >>>>> supportive effect on our families well being! >>>>> >>>>> Thank You >>>>> >>>>> Brian! >>>>> >>>>> >>>>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" > <mbulriss@> >>> wrote: >>>>>> >>>>>> Brian, >>>>>> >>>>>> Sorry to hear about the funeral. >>>>>> >>>>>> Re the gen set hydraulic leak: >>>>>> Been there, done that. The seal is blown. NO big deal. >>> Adding more >>>>>> fluid is pointless right now. To get going NOW, you just >> need >>> to >>>>>> crawl under there and just pull the cotter key that holds > in >>> the pin >>>>>> on the back of the genset hydraulic ram. Then pull the pin >> and >>> push >>>>>> the genset tray back in by hand (You may have to lift the >>> genset ram >>>>>> up to clear the frame cross rail). When all the way in, > lock >>> the >>>>>> handset bar in the front. Make very sure it is secure and >> stays >>>>>> locked! You're good to go now. >>>>>> >>>>>> When you get back, you will then need to replace the seals > in >>> the ram. >>>>>> About a 20 minute job. To get the correct seals, unscrew >> the >>> clevis >>>>>> end, on the end of the ram you disconnected and remove it. >> Then >>>>>> remove the cap on the end of the ram with a pair of water >> pump >>> pliers. >>>>>> As I recall, there is a "wiper" seal in the cap and a >>> hydraulic fluid >>>>>> seal in the cap. Take them to a good hydraulic shop to > match >>> up the >>>>>> replacements and reinstall them the way you took them out. >> Put >>>>>> everything back together and THEN add the hydraulic fluid >>> (actually >>>>>> Dexron ATF) to the reservoir under the steps. Cycle the >> syetm a >>>>>> couple of times and you will be done. >>>>>> >>>>>> Mike Bulriss >>>>>> 1991 WB40 "Texas Minivan" >>>>>> VERY wet San Antonio, TX >>>>>> >>>>>> >>>>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" > >>> wrote: >>>>>>> >>>>>>> Hello.... I hope someone can help.... >>>>>>> >>>>>>> 84 PT40 generator stuck open .... hydraulic leak from >> piston >>> that >>>>>>> pushes & pulls the generator tray open & closed.... > how... >> or >>>> where do >>>>>>> I add hydraulic fluid so that I can get the generator to >>> slide back >>>>>> in??? >>>>>>> >>>>>>> Many.... many much appreciated thanks in advance.... > family >> is >>>>>>> supposed to be leaving town in the morning to attend a >>> funeral.... >>>>>>> >>>>>>> Thank You >>>>>>> Brian >>>>>>> >>>>>> >>>>> >>>> >>> >> > > > > > > Yahoo! Groups Links > > > |
06-30-2007, 01:44
That sounds like mine.
Scott --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Might be ... I think mine's electric too. Open or close, when it > reaches the stop, it makes a 'click-click' noise. No safety latch. No > dash lights (that I noticed --since I've always opened/closed the > generator from the outside and have never looked at the dash when > it's been open). > > On Jun 29, 2007, at 6:33 PM, Scott Forman wrote: > > > I think mine is electric, too...maybe we are on to something? > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > >> > >> Scott, > >> > >> Mine doesn't have a safety lock either (that I'm aware of), or a > >> light on the dash. My ram is electric, if that has anything to do > >> with it? > >> > >> Tom Sorrentino > >> 1987 PT38 > >> Bedford Hills, NY > >> > >> > >> > >> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > >> wrote: > >>> > >>> Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I > >> have > >>> wondered what the "safety" was if the ram failed... > >>> > >>> Scott Forman > >>> 86 PT38 > >>> Memphis > >>> > >>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > >>> wrote: > >>>> > >>>> You are most welcome Brian. Remember to keep a good eye on the > >>> genset > >>>> locking bar to make sure it stays solidly locked. You could > > even > >>> put > >>>> a bungee cord on it for extra peace of mind! If the genset > > slide > >>> bar > >>>> lock comes unlocked with the ram disconnected, there is nothing > > to > >>>> keep the genset tray from sliding out on a stop. NOT a good > >>> deal! ;^) > >>>> > >>>> Mike Bulriss > >>>> 1991 WB40 "Texas Minivan" > >>>> Soggy San Antonio, TX > >>>> > >>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" > >> wrote: > >>>>> > >>>>> OK.... I couldn't wait till the morning! > >>>>> > >>>>> I just did what you mentioned.... I did have to remove both > >>> pins... > >>>>> slide the RAM out of the way.. and presto! I slid the > > generator > >>> into > >>>>> position and it is locked and ready to go! > >>>>> > >>>>> again.... THANK YOU SO MUCH! > >>>>> > >>>>> I really have not been able to participate in this forum and > >>>>> contribute to it's content as I could have.... self > >> employeed .... > >>>>> family of 6 .... we are also foster parents.... and a > >> wanderlodge > >>>>> newbe....... > >>>>> > >>>>> I will make time in the future to return to this forum that > > in > >>> only a > >>>>> few interactions with my questions... had made such a > > positive > >> and > >>>>> supportive effect on our families well being! > >>>>> > >>>>> Thank You > >>>>> > >>>>> Brian! > >>>>> > >>>>> > >>>>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" > > <mbulriss@> > >>> wrote: > >>>>>> > >>>>>> Brian, > >>>>>> > >>>>>> Sorry to hear about the funeral. > >>>>>> > >>>>>> Re the gen set hydraulic leak: > >>>>>> Been there, done that. The seal is blown. NO big deal. > >>> Adding more > >>>>>> fluid is pointless right now. To get going NOW, you just > >> need > >>> to > >>>>>> crawl under there and just pull the cotter key that holds > > in > >>> the pin > >>>>>> on the back of the genset hydraulic ram. Then pull the pin > >> and > >>> push > >>>>>> the genset tray back in by hand (You may have to lift the > >>> genset ram > >>>>>> up to clear the frame cross rail). When all the way in, > > lock > >>> the > >>>>>> handset bar in the front. Make very sure it is secure and > >> stays > >>>>>> locked! You're good to go now. > >>>>>> > >>>>>> When you get back, you will then need to replace the seals > > in > >>> the ram. > >>>>>> About a 20 minute job. To get the correct seals, unscrew > >> the > >>> clevis > >>>>>> end, on the end of the ram you disconnected and remove it. > >> Then > >>>>>> remove the cap on the end of the ram with a pair of water > >> pump > >>> pliers. > >>>>>> As I recall, there is a "wiper" seal in the cap and a > >>> hydraulic fluid > >>>>>> seal in the cap. Take them to a good hydraulic shop to > > match > >>> up the > >>>>>> replacements and reinstall them the way you took them out. > >> Put > >>>>>> everything back together and THEN add the hydraulic fluid > >>> (actually > >>>>>> Dexron ATF) to the reservoir under the steps. Cycle the > >> syetm a > >>>>>> couple of times and you will be done. > >>>>>> > >>>>>> Mike Bulriss > >>>>>> 1991 WB40 "Texas Minivan" > >>>>>> VERY wet San Antonio, TX > >>>>>> > >>>>>> > >>>>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > >>> wrote: > >>>>>>> > >>>>>>> Hello.... I hope someone can help.... > >>>>>>> > >>>>>>> 84 PT40 generator stuck open .... hydraulic leak from > >> piston > >>> that > >>>>>>> pushes & pulls the generator tray open & closed.... > > how... > >> or > >>>> where do > >>>>>>> I add hydraulic fluid so that I can get the generator to > >>> slide back > >>>>>> in??? > >>>>>>> > >>>>>>> Many.... many much appreciated thanks in advance.... > > family > >> is > >>>>>>> supposed to be leaving town in the morning to attend a > >>> funeral.... > >>>>>>> > >>>>>>> Thank You > >>>>>>> Brian > >>>>>>> > >>>>>> > >>>>> > >>>> > >>> > >> > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > |
06-30-2007, 02:49
Scott,
Thomas Eastham in Texas that is parting out a BB might have what you need. Howard T., Ga., 86 PT40 > > From: "mbulriss" <mbulriss@...> > Date: 2007/06/29 Fri PM 06:54:55 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Can Anyone Help??? Stuck with an extended generator... 84PT40!!!! > > Scott, > > Starting to sound like a prior owner modification to remove the > locking slider bar that I would not care for if it was mine. The > small stop tabs at the back of the tray runners will not stop it under > a hard stop. Seems like a few years back, someone posted about their > genset tray sliding out and landing on the road in front of them under > a hard braking scenario. Oooops! Anyone else remember that post? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX - nice and steamy right now..... > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> > wrote: > > > > I have the light, and it comes on when I extend the tray. Strange. > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > > > > On 6/29/07, mbulriss <mbulriss@> wrote: > > > > > > > > Scott, > > > > > > > > I don't known the answer to that. I thought all the early/mid > > 80s > > > > with hydraulic rams had the manual lock. Looks like I was wrong > > in > > > > that assumption. Someone with another 86 will have to address > > your > > > > question. > > > > > > Scott, > > > > > > '86 PT-40 here. I have a lock. Big black lever on the front. I would > > > expect you should have one, too. Do you have the corresponding dash > > > light?? I have a red light on the dash that will come on if the gen > > > tray is unlocked. The digitel will also complain about it. > > > > > > I'd find out why you don't have one - previous owner modification is > > > my guess - and get it fixed. I'd imagine this is a critical safety > > > feature to keep the genset in the coach. You'd hate to lose the > > entire > > > unit into the back of a compact if you had to come to a quick stop > > and > > > the hydraulics decided not to hold it. > > > > > > -Ryan > > > '86 PT-40 8V92 > > > Tri-Cities, WA > > > > > > > > > |
06-30-2007, 02:54
Scott,
Mine is electric Howard T. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/06/30 Sat AM 09:44:38 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Can Anyone Help??? Stuck with an extended generator... 84PT40!!!! > > That sounds like mine. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > Might be ... I think mine's electric too. Open or close, when it > > reaches the stop, it makes a 'click-click' noise. No safety latch. > No > > dash lights (that I noticed --since I've always opened/closed the > > generator from the outside and have never looked at the dash when > > it's been open). > > > > On Jun 29, 2007, at 6:33 PM, Scott Forman wrote: > > > > > I think mine is electric, too...maybe we are on to something? > > > > > > Scott > > > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > >> > > >> Scott, > > >> > > >> Mine doesn't have a safety lock either (that I'm aware of), or a > > >> light on the dash. My ram is electric, if that has anything to do > > >> with it? > > >> > > >> Tom Sorrentino > > >> 1987 PT38 > > >> Bedford Hills, NY > > >> > > >> > > >> > > >> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> > > >> wrote: > > >>> > > >>> Mike...my 86 PT38 doesn't have a manual lock bar. Should it? I > > >> have > > >>> wondered what the "safety" was if the ram failed... > > >>> > > >>> Scott Forman > > >>> 86 PT38 > > >>> Memphis > > >>> > > >>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > > >>> wrote: > > >>>> > > >>>> You are most welcome Brian. Remember to keep a good eye on the > > >>> genset > > >>>> locking bar to make sure it stays solidly locked. You could > > > even > > >>> put > > >>>> a bungee cord on it for extra peace of mind! If the genset > > > slide > > >>> bar > > >>>> lock comes unlocked with the ram disconnected, there is nothing > > > to > > >>>> keep the genset tray from sliding out on a stop. NOT a good > > >>> deal! ;^) > > >>>> > > >>>> Mike Bulriss > > >>>> 1991 WB40 "Texas Minivan" > > >>>> Soggy San Antonio, TX > > >>>> > > >>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > >> wrote: > > >>>>> > > >>>>> OK.... I couldn't wait till the morning! > > >>>>> > > >>>>> I just did what you mentioned.... I did have to remove both > > >>> pins... > > >>>>> slide the RAM out of the way.. and presto! I slid the > > > generator > > >>> into > > >>>>> position and it is locked and ready to go! > > >>>>> > > >>>>> again.... THANK YOU SO MUCH! > > >>>>> > > >>>>> I really have not been able to participate in this forum and > > >>>>> contribute to it's content as I could have.... self > > >> employeed .... > > >>>>> family of 6 .... we are also foster parents.... and a > > >> wanderlodge > > >>>>> newbe....... > > >>>>> > > >>>>> I will make time in the future to return to this forum that > > > in > > >>> only a > > >>>>> few interactions with my questions... had made such a > > > positive > > >> and > > >>>>> supportive effect on our families well being! > > >>>>> > > >>>>> Thank You > > >>>>> > > >>>>> Brian! > > >>>>> > > >>>>> > > >>>>> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" > > > <mbulriss@> > > >>> wrote: > > >>>>>> > > >>>>>> Brian, > > >>>>>> > > >>>>>> Sorry to hear about the funeral. > > >>>>>> > > >>>>>> Re the gen set hydraulic leak: > > >>>>>> Been there, done that. The seal is blown. NO big deal. > > >>> Adding more > > >>>>>> fluid is pointless right now. To get going NOW, you just > > >> need > > >>> to > > >>>>>> crawl under there and just pull the cotter key that holds > > > in > > >>> the pin > > >>>>>> on the back of the genset hydraulic ram. Then pull the pin > > >> and > > >>> push > > >>>>>> the genset tray back in by hand (You may have to lift the > > >>> genset ram > > >>>>>> up to clear the frame cross rail). When all the way in, > > > lock > > >>> the > > >>>>>> handset bar in the front. Make very sure it is secure and > > >> stays > > >>>>>> locked! You're good to go now. > > >>>>>> > > >>>>>> When you get back, you will then need to replace the seals > > > in > > >>> the ram. > > >>>>>> About a 20 minute job. To get the correct seals, unscrew > > >> the > > >>> clevis > > >>>>>> end, on the end of the ram you disconnected and remove it. > > >> Then > > >>>>>> remove the cap on the end of the ram with a pair of water > > >> pump > > >>> pliers. > > >>>>>> As I recall, there is a "wiper" seal in the cap and a > > >>> hydraulic fluid > > >>>>>> seal in the cap. Take them to a good hydraulic shop to > > > match > > >>> up the > > >>>>>> replacements and reinstall them the way you took them out. > > >> Put > > >>>>>> everything back together and THEN add the hydraulic fluid > > >>> (actually > > >>>>>> Dexron ATF) to the reservoir under the steps. Cycle the > > >> syetm a > > >>>>>> couple of times and you will be done. > > >>>>>> > > >>>>>> Mike Bulriss > > >>>>>> 1991 WB40 "Texas Minivan" > > >>>>>> VERY wet San Antonio, TX > > >>>>>> > > >>>>>> > > >>>>>> --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > > >>> wrote: > > >>>>>>> > > >>>>>>> Hello.... I hope someone can help.... > > >>>>>>> > > >>>>>>> 84 PT40 generator stuck open .... hydraulic leak from > > >> piston > > >>> that > > >>>>>>> pushes & pulls the generator tray open & closed.... > > > how... > > >> or > > >>>> where do > > >>>>>>> I add hydraulic fluid so that I can get the generator to > > >>> slide back > > >>>>>> in??? > > >>>>>>> > > >>>>>>> Many.... many much appreciated thanks in advance.... > > > family > > >> is > > >>>>>>> supposed to be leaving town in the morning to attend a > > >>> funeral.... > > >>>>>>> > > >>>>>>> Thank You > > >>>>>>> Brian > > >>>>>>> > > >>>>>> > > >>>>> > > >>>> > > >>> > > >> > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > |
