Klunking noise
04-28-2008, 13:55
Klunking noise
I have auto slack adjusters also. It is a strange thing because the only time it happens on my bus is when I really stomp on it. Strange thing, it never happens when I let off. One would think if the front end had a problem it would happen both ways. When I get off the treadle after one of those panic stops nothing happens, no noise. Leads me to believe it is in the wheel where the brake clamps down. The front end does not seem to have any problems visually. Had it aligned, no problems. Gotta read Pappy's link.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Pete Masterson
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
04-28-2008, 15:16
Klunking noise
Its the roller that the shoe rotates on. the roller comes with the
spring kit. the roller probably has a flat spot on it . You can change the shoes without a spring kit so I guess you can just buy the spring kit $9.00 per side and replace the hardware. I keep an extra set of shoes on hand and have them relined at a place in RiversideCa called L&M Friction they wont let me leave the shop without spring kits. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > If I have to brake a little quickly there is a fairly loud "klunk" > sound which occurs each and every time. Seems to be coming from the > wheel or suspension area. Brakes work fine, previous owner said the > bus as always done this. In my process of repair and improvements, I > thought I should address this. Any idea's. > John Heckman > central Pa > 1973 > |
04-28-2008, 16:23
Klunking noise
here is a link to a great tutorial pdf that does a wonderful job on
explaining every part of an airbrake system and has some fantastic diagrams. A 'must read' for Canadian Commercial driver a 'should read' for AirBrake CoachOwners. https://gov.ns.ca/snsmr/rmv/licence/pdf/...manual.pdf I cant find any written confirmation of my $9.00 brake roller KlunkFix (googeled more hits with clunk) but the most it will cost is $18.00 and time if you have the ability to pull a wheel, the drum will pull over the lugs. I think the roller and bushing are the issue and the cam may also have a flat spot? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Its the roller that the shoe rotates on. the roller comes with the > spring kit. the roller probably has a flat spot on it . You can change > the shoes without a spring kit so I guess you can just buy the spring > kit $9.00 per side and replace the hardware. I keep an extra set of > shoes on hand and have them relined at a place in RiversideCa called > L&M Friction they wont let me leave the shop without spring kits. > > GregoryO'Connor > 94ptRomolandCa > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > If I have to brake a little quickly there is a fairly loud "klunk" > > sound which occurs each and every time. Seems to be coming from the > > wheel or suspension area. Brakes work fine, previous owner said the > > bus as always done this. In my process of repair and improvements, I > > thought I should address this. Any idea's. > > John Heckman > > central Pa > > 1973 > > > |
04-28-2008, 16:58
Klunking noise
Pete:
I do not knowwhen they started putting the auto slack adjusters on, but my 84 has them, I just replaced them all. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada ----- Original Message ----
From: susanmarycamilleri To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 28, 2008 5:42:05 PM Subject: [WanderlodgeForum] Re: Klunking noise My 78 FC 35' make the very same noise under heavy braking. The NTSB article refers to vehicles equipted with automatic slack adjusters. From what I have read on this thread all the wanderlodges are too old to have automatic slack adjusters. I must admit that I adjust my brakes a lot. If I am going to slide under the bus to check the brakes I might as well adjust them. Pete "Prairie Dog" 78 FC 35' --- In "WanderlodgeForum%40yahoogroups.com", "whistles_n_ bells" > > Folks, let me toss this out - for what it is worth; there has been a > number of discussions over recent years that address air brake slack > adjusters - and possible control arm issues. Just a thought. If you do a > Google search "brake slack adjusters," there are numerous articles and > diagrams - including results of NTSB accident investigations involving > air brake-equipped buses and trucks. It is possible that a faulty > control arm could be the culprit. > > I found this link very informative: > > http://www.ntsb. gov/recs/ letters/2001/ H01_02.pdf. > > Again, I hope this might be useful. I am not a mechanic. The articles > provide good reading. > > Joe (Pappy) Hagan > St. George, UT > Wannabe > > --- In "WanderlodgeForum%40yahoogroups.com", "bubblerboy64" > wrote: > > > > If I have to brake a little quickly there is a fairly loud "klunk" > > sound which occurs each and every time. Seems to be coming from the > > wheel or suspension area. Brakes work fine, previous owner said the > > bus as always done this. In my process of repair and improvements, I > > thought I should address this. Any idea's. > > John Heckman > > central Pa > > 1973 > > > Instant message from any web browser! Try the new Yahoo! Canada Messenger for the Web BETA |
04-29-2008, 00:28
Klunking noise
Thanks Greg, I have to have an state inspection done soon. I suspect
that I will need some brake work, certainly a time to address this klunk now that I have a lead as to what is causing it. John Heckman central Pa 1973 FC > > here is a link to a great tutorial pdf that does a wonderful job on > explaining every part of an airbrake system and has some fantastic > diagrams. A 'must read' for Canadian Commercial driver a 'should > read' for AirBrake CoachOwners. > > https://gov.ns.ca/snsmr/rmv/licence/pdf/...manual.pdf > > I cant find any written confirmation of my $9.00 brake roller > KlunkFix (googeled more hits with clunk) but the most it will cost > is $18.00 and time if you have the ability to pull a wheel, the drum > will pull over the lugs. I think the roller and bushing are the > issue and the cam may also have a flat spot? > > GregoryO'Connor > 94ptRomolandCa > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Its the roller that the shoe rotates on. the roller comes with the > > spring kit. the roller probably has a flat spot on it . You can > change > > the shoes without a spring kit so I guess you can just buy the > spring > > kit $9.00 per side and replace the hardware. I keep an extra set > of > > shoes on hand and have them relined at a place in RiversideCa > called > > L&M Friction they wont let me leave the shop without spring kits. > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > If I have to brake a little quickly there is a fairly > loud "klunk" > > > sound which occurs each and every time. Seems to be coming from > the > > > wheel or suspension area. Brakes work fine, previous owner said > the > > > bus as always done this. In my process of repair and > improvements, I > > > thought I should address this. Any idea's. > > > John Heckman > > > central Pa > > > 1973 > > > > > > |
04-29-2008, 00:44
Klunking noise
John,
Take a trip to Pgh. Route 8 Exit Pa, turnpike. Walt will fix you up at the Dinnerbell Garage, Butler Pa. Great mechanic, fair and honest. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Thanks Greg, I have to have an state inspection done soon. I suspect > that I will need some brake work, certainly a time to address this > klunk now that I have a lead as to what is causing it. > John Heckman > central Pa > 1973 FC > > > > here is a link to a great tutorial pdf that does a wonderful job on > > explaining every part of an airbrake system and has some fantastic > > diagrams. A 'must read' for Canadian Commercial driver a 'should > > read' for AirBrake CoachOwners. > > > > https://gov.ns.ca/snsmr/rmv/licence/pdf/...manual.pdf > > > > I cant find any written confirmation of my $9.00 brake roller > > KlunkFix (googeled more hits with clunk) but the most it will cost > > is $18.00 and time if you have the ability to pull a wheel, the > drum > > will pull over the lugs. I think the roller and bushing are the > > issue and the cam may also have a flat spot? > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Its the roller that the shoe rotates on. the roller comes with > the > > > spring kit. the roller probably has a flat spot on it . You can > > change > > > the shoes without a spring kit so I guess you can just buy the > > spring > > > kit $9.00 per side and replace the hardware. I keep an extra set > > of > > > shoes on hand and have them relined at a place in RiversideCa > > called > > > L&M Friction they wont let me leave the shop without spring kits. > > > > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > wrote: > > > > > > > > If I have to brake a little quickly there is a fairly > > loud "klunk" > > > > sound which occurs each and every time. Seems to be coming from > > the > > > > wheel or suspension area. Brakes work fine, previous owner > said > > the > > > > bus as always done this. In my process of repair and > > improvements, I > > > > thought I should address this. Any idea's. > > > > John Heckman > > > > central Pa > > > > 1973 > > > > > > > > > > |
04-29-2008, 01:36
Klunking noise
Had the same noise on severe stops. Read some place that by fullly
depressing the Brake pedal while standing still once a day, would do the adjustment (if needed) and alleviate the klunking on subsequent stops. This has worked for me. Kurt in NH '97 BMC 37' and '83 FCSB 35' (for sale) --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Well, I guess I won't worry about it then but it seems like > something that loud (and apparently common) would have a known cause. > Maybe some one will chip in here with answer. > John Heckman > central Pa > 1973 FC > > > > Mine too. It does tend to pull a little to one side when it > > happens, but not badly. I had things checked out and they found > > nothing. > > > > Hardner > > 78FC33 > > > > > > --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > > > > > > > And so do I if I really need to brake hard. No pull or anything > > else unusual. It does not happen any other time. I have had my > front > > end inspected and cannot find the source. Please advise if you find > > anything. > > > > > > Leroy Eckert > > > 1990 WB-40 Smoke n Mirrors > > > Dahlonega, GA > > > Royale Conversion > > > > > > Dorn Hetzel > > the same thing from time to time, haven't been able to put my > finger > > on what's doing it either. > > > > > > Seems to occur mostly when I brake quite hard for some reason. > > > > > > Dorn Hetzel > > > 77FC35 > > > Hogansville, GA > > > > > > > > > On Mon, Apr 28, 2008 at 11:03 AM, bubblerboy64 > > > If I have to brake a little > > quickly there is a fairly loud "klunk" > > > sound which occurs each and every time. Seems to be coming from > > the > > > wheel or suspension area. Brakes work fine, previous owner said > > the > > > bus as always done this. In my process of repair and > improvements, > > I > > > thought I should address this. Any idea's. > > > John Heckman > > > central Pa > > > 1973 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Be a better friend, newshound, and know-it-all with Yahoo! > Mobile. > > Try it now. > > > > > > |
04-29-2008, 03:22
Klunking noise
What I said is all the Wanderlodges in this thread, ie the klunking
noise, were too old for automatic slack adjusters. I am well aware that the newer birds have auto slack adjusters. Pete 78 FC 35' --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > I'm not sure when the automatic slack adjusters appeared (sometime in > the 80's) but my coach has them. So, "all the Wanderlodges" aren't > too old to have them. > > FWIW, I've never heard any klunking noise from the brakes -- but a > few things in the refrigerator sometimes klunk during a vigorous stop. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Apr 28, 2008, at 5:42 PM, susanmarycamilleri wrote: > > > My 78 FC 35' make the very same noise under heavy braking. The NTSB > > article refers to vehicles equipted with automatic slack adjusters. > > From what I have read on this thread all the wanderlodges are too old > > to have automatic slack adjusters. I must admit that I adjust my > > brakes a lot. If I am going to slide under the bus to check the > > brakes I might as well adjust them. > > > |
04-29-2008, 03:22
Klunking noise
