Wood Plank Sand and Finish Floor
06-03-2008, 07:53
Well, that is a good point and one I have considered and it may yet be a deal breaker. It could become a woody. It could very well darken the inside and close it in visually. I am going to lay a couple of long pieces over the carpet and see the change before I make a final decision. The good thing is the floor would butt to white ceramic tile. The white carpet in the coach, primarily in the front, is such a headache and I have not been able to come up with any other option because of the Royale Conversion and its hand crafted wood everywhere. I sure do not want to destroy that effect.
As always, I appreciate your input. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Gregory OConnor
06-03-2008, 08:11
I stored the flooring inside my non air condition shop and inside the bird was the same temp & the same percentage of humidity so I did not fined any need to store the flooring inside the bird. Bob Loomas PT 36 85 Harahan La. > > Thanks to all for the replies. I think I will try it sometime in the near future. One more question. Did you let the wood acclimate inside the coach for a period before installation? > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > robert nloomas <bbpt36@...> wrote: --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > > A few years ago I remove all the carpet from my bird and installed > tong & grove red oak flooring.It took me a month to do the install > and three days to clean up all the sanding dust.I no this is not the > question you are asking.The big problem I found laying a plank > flooring is that nothing is square or level.Even with the mess it was > easier for me to lay the flood plug and screw the floor into place > then > sand after sanding the floor I finish the floor with three coats of > Min wax polyurethane. > Bob Loomas PT 36 85 > Harahan La. > > > Ernie or anyone else: > > I am considering installing a custom sand and finish floor from the > > kitchen tile forward probably with inlays made from exotic wood to > and > > including the stair well surround. I know how to install, I think, > but > > this is what I want to do. > > Purchase 12" red oak planks 1/2" thick(my coach is red oak), plane > it > > down (probably to about 3/8")to meet the elevation of the tile to > > eliminate any transition strip between the tile and wood, t&g it > then > > screw and glue it down. I would pre-sanded, stain and first coat the > > wood prior to installation. The final finish and detail would be > > applied in the coach. Can I do this, and how thin can I plane 12" > > plank wood and expect it not to crack. > > Thanks, > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > |
