Coolant Filters
08-27-2008, 13:29
Coolant Filters
forgot to change the pic extensions Greg
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Coolant Filter Installation -1987 PT38 â 8V92 Contributed by Curt Sprenger August 27.2008 Coolant Filter Base â Filters â 1st filter Parts â All Brass, all 3/8" - 4 street elbows, 1 close nipple, 1 1-1/2" nipple, 2 NIBCO T585 ball valves. Cost $68.79. You might find the part for less. I shop at a plumbing store that carries more parts than anyone in our area. They are not the least expensive but time is worth something. Hose â measure generously â I used just under 6' - get good ½" push-on or equivalent. Cost $10.00. Hose Clamps â 4 each. Bolts/Nuts â to mount the filter base.
Instructions - 1 I removed the Ether Injector system and installed the coolant filter base in the same location. Or pick a different location. 2 Loosely attach all the plumbing to the filter base, see picture, and the spin on the filter (not tight), to get an accurate mounting position that works. Keep the coolant hose clearance/routing in mind. 3 Drill new mounting holes if needed. 4 Install filter base. 5 Install the brass parts. See photos. Shorten the ball valve handles as needed. Use thread sealant. 6 Tighten the filter. 7 Remove the old hose at the Expansion Tank, save the coolant. Plug the hose for now. 8 Connect new hose from the expansion tank to the filter base center. 9 Connect new hose to the filter base outer connection. Run the hose to the thermostat housing street elbow to get the length of hose needed, and cut to length. 10 With a knife, slit the old hose at the street elbow on top of the thermostat housing. Quickly remove that hose and slid on the new hose. A terry towel on top of the thermostat housing will catch the small amount of coolant loss. |
08-27-2008, 14:09
Coolant Filters
John thanks, I was thinking of one inch or what ever size makes the
loop to the potable waterheater. blockage there is of little issue and no hot water at the sink would warn of a clogged filter. I like the idea of the filter being in a path like the waterheater because it is right off the pump and as the filter fills with crap, it catches smaller and smaller particles. placed in a spot where the path around is less restrictive will prove to become the path of least resistance ans the filter become only moderatly full. The other advantage of a coolant filter is you can get them charged with additives (RobR a Canadian, but ok) GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "jcmace59" wrote: > > Greg, > Here's one with 3/8 NPT inlet/outlet sizes. You should be able to > find it locally. It's what's used in the heavy truck side of > things. Takes standard filters. > > https://dynamic.donaldson.com/webc/WebSt...tail.html? > section=10324&item=1857 > > Hope this helps. I don't believe there is one designed for full flow > coolant, only partial flow. Prevents filter blockage from > interupting engine cooling. > > John > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > One mod I would like to add is a filter system for the coolant on > my > > bus. CurtS brought this up one time but now that I have a grand > > invested in cleaning out my rad, I have interest (I wasn't > political > > untill I paid taxes either). I am kinda surprised that there is not > > a OEM filter in the design some place. At the same time my Primus > > gone Wabasto need a filter system also. A recent flush of that > > independent system , register by register proved much crap inbeded > > in the path. > > > > I like the idea of running my bus as hot as the engineeres designed > > 185 to 195 to get all the hp and fluids working but the 10 degree > > margine prior to costly damage keeps me concerned. I proved that > the > > rad will cool things off even compramised 90%(subjective calc by > the > > shop that did the rodding) so the cooling system optimization is > > where I would like to relieve that concern. > > > > Has anyone added a coolant filter mod? > > I found this kit but would like a larger inlet outlet to mount it > on > > the cockpit heater defroster loop. > > > > https://www.dieselsite.com/index.asp? > > PageAction=VIEWPROD&ProdID=796&HS=1 > > > > > > > > GregoryO'Connor > > 94ptRomolandCa > > > |
08-27-2008, 15:03
Coolant Filters
Greg,
From my research John ??? is right. All coolant filter bases that I checked out were 3/8". If you want to build one to work with larger flow (1" line), we can build you one...I like your thinking. The only caution is the filter additives...maybe too much additive getting into the coolant system in a shorter period with that 1" line. Without getting into too much here...my understanding is the filters are designed to support or do their job over a one year period. You use filters with more additive the first year, and the second and subsequent years use filters with less additive. That could vary depending on the annual coolant test results. Maybe do an semi-annual coolant test and change filters then if needed. The science is close to the same as taking care of a swimming pool. On Wed, Aug 27, 2008 at 7:09 PM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
08-28-2008, 07:20
Coolant Filters
Curt's right about worrying if you're getting too much additive in
the system. I slightly overdid it in my 7.3 and ended up having to replace the water pump because of it. Definitely something to keep in mind. I wouldn't worry about the restriction in the filter pushing fluid around it, that's the whole safety factor of this type of system. Adding the filter will help. If it plugs completely, where are you? No worse than you are right now and a simple filter change immediately puts you back better than where you are now. Looks like a win/win to me. I need to do mine!! --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Greg, > > From my research John ??? is right. All coolant filter bases that I checked > out were 3/8". If you want to build one to work with larger flow (1" line), > we can build you one...I like your thinking. The only caution is the filter > additives...maybe too much additive getting into the coolant system in a > shorter period with that 1" line. Without getting into too much here...my > understanding is the filters are designed to support or do their job over a > one year period. You use filters with more additive the first year, and the > second and subsequent years use filters with less additive. That could vary > depending on the annual coolant test results. Maybe do an semi- annual > coolant test and change filters then if needed. The science is close to the > same as taking care of a swimming pool. > > On Wed, Aug 27, 2008 at 7:09 PM, Gregory OConnor wrote: > > > John thanks, I was thinking of one inch or what ever size makes the > > loop to the potable waterheater. blockage there is of little issue > > and no hot water at the sink would warn of a clogged filter. I like > > the idea of the filter being in a path like the waterheater because > > it is right off the pump and as the filter fills with crap, it > > catches smaller and smaller particles. placed in a spot where the > > path around is less restrictive will prove to become the path of > > least resistance ans the filter become only moderatly full. > > > > The other advantage of a coolant filter is you can get them > > charged with additives (RobR a Canadian, but ok) > > > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com > > "jcmace59" > > wrote: > > > > > > > > Greg, > > > Here's one with 3/8 NPT inlet/outlet sizes. You should be able to > > > find it locally. It's what's used in the heavy truck side of > > > things. Takes standard filters. > > > > > > > > https://dynamic.donaldson.com/webc/WebSt...tail.html? > > > section=10324&item=1857 > > > > > > Hope this helps. I don't believe there is one designed for full > > flow > > > coolant, only partial flow. Prevents filter blockage from > > > interupting engine cooling. > > > > > > John > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "Gregory OConnor" > > > > > > > > > > > One mod I would like to add is a filter system for the coolant > > on > > > my > > > > bus. CurtS brought this up one time but now that I have a grand > > > > invested in cleaning out my rad, I have interest (I wasn't > > > political > > > > untill I paid taxes either). I am kinda surprised that there is > > not > > > > a OEM filter in the design some place. At the same time my > > Primus > > > > gone Wabasto need a filter system also. A recent flush of that > > > > independent system , register by register proved much crap > > inbeded > > > > in the path. > > > > > > > > I like the idea of running my bus as hot as the engineeres > > designed > > > > 185 to 195 to get all the hp and fluids working but the 10 > > degree > > > > margine prior to costly damage keeps me concerned. I proved that > > > the > > > > rad will cool things off even compramised 90%(subjective calc by > > > the > > > > shop that did the rodding) so the cooling system optimization is > > > > where I would like to relieve that concern. > > > > > > > > Has anyone added a coolant filter mod? > > > > I found this kit but would like a larger inlet outlet to mount > > it > > > on > > > > the cockpit heater defroster loop. > > > > > > > > https://www.dieselsite.com/index.asp? > > > > PageAction=VIEWPROD&ProdID=796&HS=1 > > > > > > > > > > > > > > > > GregoryO'Connor > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
