Broken Microphor toilet
03-26-2009, 05:51
03-26-2009, 07:20
Keep in mind that there are 2 versions of the Microphor. The hard one to replace
is mounted where air needs to be used to flush the waste to the black tank, and there is a separate air pump which handles the low pressure. The other one (which I have) IS mounted over the blackwater tank with a straight-down pipe, and uses a 12vdc flush system. That one should be easy to replace with any standard Thetford or Sealand that will physically fit. Note that Sealand is Dometic and Thetford is Norcold if you have any bias toward/against either companies products. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 3/26/2009 at 9:15 AM nelson slinkman wrote: >Thanks, That will take the place of the Microphor. I see some people >mentiones some toilets need a plumbing change. I sure don't want go do >that. I just want one that I can bolt to the floor and connect the water >line. >Thanks >Nelson 1994 40'WB > >--- On Wed, 3/25/09, Wallace Craig > > >From: Wallace Craig >Subject: Re: [WanderlodgeForum] Broken Microphor toilet >To: WanderlodgeForum@yahoogroups.com >Date: Wednesday, March 25, 2009, 8:28 PM > > > > > > > > > > > The name is "Thetford". If you google thetford you will find that they >have a web site. > > >Wallace Craig >95 WLWB 42 >Azle, Texas > >--- On Wed, 3/25/09, nelson slinkman > > >From: nelson slinkman >Subject: Re: [WanderlodgeForum] Broken Microphor toilet >To: WanderlodgeForum@ yahoogroups. com >Date: Wednesday, March 25, 2009, 5:50 PM > > > > > > > >Thanks for the information. Do you know the brand name of the ones in the >older buses. >Thanks >Nelson > >--- On Wed, 3/25/09, Wallace Craig > > >From: Wallace Craig >Subject: Re: [WanderlodgeForum] Broken Microphor toilet >To: WanderlodgeForum@ yahoogroups. com >Date: Wednesday, March 25, 2009, 6:37 PM > > > > > > > > >If I were ever to replace my toilet I would see if one of the Manuel >toilets would work; the kind that was in the 1980+ models. It idiot proof >and requires no maintenance. I have never been able to see the advantage >of the Microphor. > > >Wallace Craig >95 WLWB 42 >Azle, Texas > >--- On Wed, 3/25/09, nslinkman > > >From: nslinkman >Subject: [WanderlodgeForum] Broken Microphor toilet >To: WanderlodgeForum@ yahoogroups. com >Date: Wednesday, March 25, 2009, 4:56 PM > > >I need to replace my Microphor toilet. Has anyone else replaced one with a >different type? They wanted over $1400.00 from a distributor to purchase a >new one. There must be a better option somewhere. >Thanks >Nelson Slinkman 1994 40' > > > > >------------ --------- --------- ------ > >Yahoo! Groups Links |
03-27-2009, 02:29
Nelson,
The reason that we are considering replacing our 12V electric toilet is because of the constant FAILURE of the electric components. Jack is tired of replacing those. AND they are expensive, also. No more electric toilets for us. > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > D'Hanis, TX > Buena Vista, CO --- In WanderlodgeForum@yahoogroups.com, nelson slinkman > > Just taled to Thetford. They said the direct replacement for the Microphor LF-220 is the TECMA-EASY FIT. They sell for around $750.00. > |
