Dometci 7030 help
06-18-2005, 09:07
Dometci 7030 help
lucky for me,i have not had any leaks (that i know of!) and i'm hoping that the
amana last forever! i'm guessing when it goes bad it comes out through the windsheild,on its back...i can't believe that they would put a gas refer in the side aisle coach,what were they thinking? george,i can't help you on your leak! randydupree93wb ----- Original Message ----- From: George Lowry To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 12:40 PM Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help Ok Randy, I also have the Amana side by side, 19 cu. ft. refer. We have a leak in the water system, i.e. the feed for the ice maker and ice water. When we had the refer out for other repairs last winter, we thought we had found the problem to be the hose washer that was hard. However, a new washer didn't seem to do it. Problem that we are trying to overcome is, how do you trouble shoot it? It only leaks when pressure is on and it is very slow. (yet enough to soak the carpet) To get at the line. etc., you have to pull the refer out. To get the refer our, you have to remove the doors which necessitates breaking the water line that goes up the door. I have not been able to determine if it is the tubing from the angle stop under the lavatory or the tubing in the refer itself. Have you had any experience with this that you can pass on? Thanks, George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD randydupree wrote: > i agree that there has to be an access panal.gas refers need > service yearly.i hav a side aisle coach but mine has a house side x > side amana refer unit.my refer backs up to the shower,whats behind > yours? randydupree93wb ---- > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-18-2005, 09:51
Dometci 7030 help
Thanks Randy,
And BTW, from what I can find, nobody makes a refer that will fit in that hole. I did some serious looking when we first got our coach and the refer quit. Finally found a repairman in quartzsite who was able to fix it. been working well for 1 1/3 years now. Except for the water leak... George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD randydupree wrote: > lucky for me,i have not had any leaks (that i know of!) and i'm > hoping that the amana last forever! i'm guessing when it goes bad > it comes out through the windsheild,on its back...i can't believe > that they would put a gas refer in the side aisle coach,what were > they thinking? george,i can't help you on your leak! > randydupree93wb ----- Original Message ----- From: George Lowry To: > WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 > 12:40 PM Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help > > > Ok Randy, > > I also have the Amana side by side, 19 cu. ft. refer. We have a > leak in the water system, i.e. the feed for the ice maker and ice > water. When we had the refer out for other repairs last winter, we > thought we had found the problem to be the hose washer that was > hard. However, a new washer didn't seem to do it. > > Problem that we are trying to overcome is, how do you trouble shoot > it? It only leaks when pressure is on and it is very slow. (yet > enough to soak the carpet) To get at the line. etc., you have to > pull the refer out. To get the refer our, you have to remove the > doors which necessitates breaking the water line that goes up the > door. I have not been able to determine if it is the tubing from > the angle stop under the lavatory or the tubing in the refer > itself. Have you had any experience with this that you can pass > on? > > Thanks, > > George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD > > randydupree wrote: > >> i agree that there has to be an access panal.gas refers need >> service yearly.i hav a side aisle coach but mine has a house side >> x side amana refer unit.my refer backs up to the shower,whats >> behind yours? randydupree93wb ---- >> >> > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > > |
06-18-2005, 10:17
Dometci 7030 help
thats what i figured,i hope there is something smaller! slightly! randy
----- Original Message ----- From: George Lowry To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 5:51 PM Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help Thanks Randy, And BTW, from what I can find, nobody makes a refer that will fit in that hole. I did some serious looking when we first got our coach and the refer quit. Finally found a repairman in quartzsite who was able to fix it. been working well for 1 1/3 years now. Except for the water leak... George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD randydupree wrote: > lucky for me,i have not had any leaks (that i know of!) and i'm > hoping that the amana last forever! i'm guessing when it goes bad > it comes out through the windsheild,on its back...i can't believe > that they would put a gas refer in the side aisle coach,what were > they thinking? george,i can't help you on your leak! > randydupree93wb ----- Original Message ----- From: George Lowry To: > WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 > 12:40 PM Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help > > > Ok Randy, > > I also have the Amana side by side, 19 cu. ft. refer. We have a > leak in the water system, i.e. the feed for the ice maker and ice > water. When we had the refer out for other repairs last winter, we > thought we had found the problem to be the hose washer that was > hard. However, a new washer didn't seem to do it. > > Problem that we are trying to overcome is, how do you trouble shoot > it? It only leaks when pressure is on and it is very slow. (yet > enough to soak the carpet) To get at the line. etc., you have to > pull the refer out. To get the refer our, you have to remove the > doors which necessitates breaking the water line that goes up the > door. I have not been able to determine if it is the tubing from > the angle stop under the lavatory or the tubing in the refer > itself. Have you had any experience with this that you can pass > on? > > Thanks, > > George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD > > randydupree wrote: > >> i agree that there has to be an access panal.gas refers need >> service yearly.i hav a side aisle coach but mine has a house side >> x side amana refer unit.my refer backs up to the shower,whats >> behind yours? randydupree93wb ---- >> >> > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > > ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-18-2005, 17:04
Dometci 7030 help
Actually its better that the hole from the old refrigerator is a little
bigger then anything new available. I completely rebuilt the reefer hole in my 1982 FC35 including a new floor(BB just drained the tube onto the floor and rotted it out). Also completely rebuilt the inside and reinsulated it, and rebuilt the back wall so that I could get a nice flow of cool air thru to the ceiling vent. I built a beautiful new surround out of Cherry and the new refrigerator now looks like it has been always installed that way. Biggest thing is to make sure the hole is completely sealed so nothing can escape from the hole tothe inside of the coach Bottom line is there is always a way to install a new refrigerator, IF the aisle is wide enough so that some dimension of the refrigerator will fit in it and can be moved to the door. In the case of the PTs I would think the passenger seat comes out and you can take the refeer out that way. I dont think I would have a problem installing a new one. tom 1982 Fc35 Vernon Center,NY At 06:17 PM 6/18/2005 -0400, you wrote: >thats what i figured,i hope there is something smaller! slightly! randy > ----- Original Message ----- > From: George Lowry > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, June 18, 2005 5:51 PM > Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help > > > Thanks Randy, > > And BTW, from what I can find, nobody makes a refer that will fit in > that hole. I did some serious looking when we first got our coach and > the refer quit. Finally found a repairman in quartzsite who was able > to fix it. been working well for 1 1/3 years now. Except for the > water leak... > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > randydupree wrote: > > > lucky for me,i have not had any leaks (that i know of!) and i'm > > hoping that the amana last forever! i'm guessing when it goes bad > > it comes out through the windsheild,on its back...i can't believe > > that they would put a gas refer in the side aisle coach,what were > > they thinking? george,i can't help you on your leak! > > randydupree93wb ----- Original Message ----- From: George Lowry To: > > WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 > > 12:40 PM Subject: Re: [WanderlodgeForum] Re: Dometci 7030 help > > > > > > Ok Randy, > > > > I also have the Amana side by side, 19 cu. ft. refer. We have a > > leak in the water system, i.e. the feed for the ice maker and ice > > water. When we had the refer out for other repairs last winter, we > > thought we had found the problem to be the hose washer that was > > hard. However, a new washer didn't seem to do it. > > > > Problem that we are trying to overcome is, how do you trouble shoot > > it? It only leaks when pressure is on and it is very slow. (yet > > enough to soak the carpet) To get at the line. etc., you have to > > pull the refer out. To get the refer our, you have to remove the > > doors which necessitates breaking the water line that goes up the > > door. I have not been able to determine if it is the tubing from > > the angle stop under the lavatory or the tubing in the refer > > itself. Have you had any experience with this that you can pass > > on? > > > > Thanks, > > > > George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD > > > > randydupree wrote: > > > >> i agree that there has to be an access panal.gas refers need > >> service yearly.i hav a side aisle coach but mine has a house side > >> x side amana refer unit.my refer backs up to the shower,whats > >> behind yours? randydupree93wb ---- > >> > >> > > > > > > > ------------------------------------------------------------------------------ > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > >------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > |
