foggy humid wet windows
02-06-2010, 00:48
Check the defrost vents and fan air flow for blockage.
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > When our coach gets saturated with humidity we hook up to 50 amps and run the air conditioners and the heat together for however long it takes, a couple hours at least, better yet on and off for a day or two. The excess coach humidity runs out the AC condensation drains and you are done with if for a while. > > A leaking heater core usually makes itself known because the coach starts to smell like a radiator. > > Bob Griesel '84 FC31 WLII WA > > --- In WanderlodgeForum@yahoogroups.com, Patty Austin > > > > It is not just the windshield it is the entire coach, all windows become so wet they soak the frames at the bottoms. Does this still sound like a heater core leak? How can i tell the difference? Is the fresh air the vents? > > Thanks > > > > Patty Austin > > 88 BB Wanderlodge WBPT40 > > Tampa Fl > > > > --- On Fri, 2/5/10, Chuck Wheeler > > > > > > From: Chuck Wheeler > > Subject: RE: [WanderlodgeForum] foggy humid wet windows > > To: WanderlodgeForum@yahoogroups.com > > Date: Friday, February 5, 2010, 11:59 AM > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I have found that when we are in really humid weather I have to open the fresh air to the heater to help the defrosters prevent fogging. There is also a possibility that you have a leak in the heater core. This will cause severe fogging. > > > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of patty_austin > > Sent: Friday, February 05, 2010 10:41 AM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] foggy humid wet windows > > > > > > > > > > > > Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming. > > > > Thanks in advance for anything that could help us out, > > Patty Austin > > 88 wanderlodge PT40 > > Tampa FL > > > |
