Powder Balancing
06-20-2005, 23:47
Powder Balancing
it has a small gaurd/shield to keep the powder in when you release air from the
stem,it keeps the powder from clogging the core..randydupree93wb ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 20, 2005 11:05 PM Subject: [WanderlodgeForum] Re: Powder Balancing I did not know that there was anything different about the valve core . I thought they just put the colored bands on them to show to the next tire mechanic that the tires infact had equal in them. What would be the difference in the valve core ??? Bob 93pt illinois ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-20-2005, 23:51
Powder Balancing
I understand that has been a problem but I believe that Equal now
supplies a special valve core with a filter that takes care of this. I have used Equal for seven or eight years in my Bird and before that with my SOB. The dealer I have done business with for twenty years recommends it and I have been happy with the product. Michelin does not endorse the use of Equal or comparable products. --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Does anyone have experience with the power clogging up the tire > stem/valves?? > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > wrote: > > Hi Jon, > > > > There are at least two different "powder" materials that are used > for > > balancing of tires. The one I am familiar with is "Equal". I > have > > used it on two coaches so far and I believe it is superior to the > > Centromatics balancers that I used to have. What they do is put > a > > measured amount in your tire in a package. The package > disintegrates > > in a couple of hundred miles and then you have complete usage. As > the > > tire turns, the powder redistributes itself so as to keep the > > tire/wheel in balance. I have bee told that is also tends to keep > the > > tread flatter against the road surface giving you better traction. > > > > To my knowledge, Equal is only available for the larger truck/bus > > tires. I have been told that they are working on a formula that > will > > work on the smaller (more turns per mile) tires for cars. The > other > > brand, which I cannot remember the name of right now, claims that > > theirs will work in any size tire. It sure is nice not having to > > rebalance every so often... > > > > BTW, I have Equal in all eight tires. > > > > George Lowry > > '95 WBDA 4203 & GM 4106 (for sale) > > Spearfish, SD > > > > Jon wrote: > > > > > What does this mean? Jon > > > Jon Lechich > > > jipjob@Y... > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > |
06-21-2005, 00:00
Powder Balancing
tom.the tire guy i use has a clear glass jar with a bag of equal in it along
with a cup of water.its been sitting on his counter for years.there is no clumping in this jar..is there different types of equal? smooth or clumpy? also,i understand that the beads will rust and stick together if your coach sits for a while.is that true?damn,i guess the golf balls were the right thing to use after all. any insight on this matter ? randydupree93wb ----- Original Message ----- From: jon lechich To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 21, 2005 12:34 AM Subject: Re: [WanderlodgeForum] Re: Powder Balancing Is this rebounding characteristic that noticeable when you do not have this material in your tires? Does it make for a smoother ride? Jon Jon Lechich Bremerton Washington Tom Warner The valve core has a filter in it so that the powder cannot get into the valve stem and cause it to stick. Make sure if you do get equal that you get these valve stems installed. Actually I would not install equal in a RV tire unless you are going to put a lot of miles on the tires. If it sits for any length of time and there is even the slightest amount of water vapor in the tire the equal may clump. Truckers use it and do not have these problems because the tires are constantly moving. On the other hand I have about 40# of Counteract balancing beads a compound which I believe is better for RV use. I am not a dealer and do not intend to sell it although I have the equipment and the product to both inject the beads thru the vavle stem on a installed tire and the bags that are thrown into the casing on new tires. http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20be\ ads' Counteract balancing beads differ from equal in that the composition of the beads and the fact that water moisture does not effect it. In addition counteract balancing beads come in two different compositions one for cars and one for trucks or RVs. The two different beads are engineered for the different tire rebounding characteristics between cars and trucks. I now have it in my steer tires and when I install the new tires will install it in both the steers and the rear duals. tom 1982 FC35 Vernon Center,NY bAt 03:05 AM 6/21/2005 +0000, you wrote: > I did not know that there was anything different about the valve >core . I thought they just put the colored bands on them to show to the >next tire mechanic that the tires infact had equal in them. What would >be the difference in the valve core ??? Bob 93pt illinois > > > > > >Yahoo! Groups Links > > > > Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-21-2005, 01:02
Powder Balancing
jax when you post a response like this no one knows what you are responding
to. Leave the original message and then respond to it at the top. tom 1982 FC35 Vernon Center,NY At 02:38 AM 6/21/2005 -0400, you wrote: > yes,,, i had it happen on the two new front tires i just had >installed,, day,, jax fla 83 pt-40 > > >[Non-text portions of this message have been removed] > > > > > > >Yahoo! Groups Links > > > > |
06-21-2005, 03:20
Powder Balancing
Yep, Randy, (dozen balls here)(Tiger Woods Specials)
![]() We have six gulf balls in each steer tire, Found them when we had a leaky valve stem replaced. The previous owner had a tire guy, that believed, this was the best way to balance. Our coach handles fine, goes straight and does not vibrate. Some have said that golf balls could damage the inside of the tire, but they do not clog the valves. I am happy for now, but am confused about the best method for balancing. We will purchase tires latter this year. (need to make a decision) Bill 88 FC Who never did like to golf, just really terrible --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > tom.the tire guy i use has a clear glass jar with a bag of equal in it along with a cup of water.its been sitting on his counter for years.there is no clumping in this jar..is there different types of equal? smooth or clumpy? also,i understand that the beads will rust and stick together if your coach sits for a while.is that true? damn,i guess the golf balls were the right thing to use after all. any insight on this matter ? randydupree93wb > ----- Original Message ----- > From: jon lechich > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 21, 2005 12:34 AM > Subject: Re: [WanderlodgeForum] Re: Powder Balancing > > > Is this rebounding characteristic that noticeable when you do not have this material in your tires? Does it make for a smoother ride? Jon > Jon Lechich > Bremerton Washington > > Tom Warner > The valve core has a filter in it so that the powder cannot get into the > valve stem and cause it to stick. Make sure if you do get equal that you > get these valve stems installed. > > Actually I would not install equal in a RV tire unless you are going to put > a lot of miles on the tires. If it sits for any length of time and there is > even the slightest amount of water vapor in the tire the equal may clump. > Truckers use it and do not have these problems because the tires are > constantly moving. > > On the other hand I have about 40# of Counteract balancing beads a compound > which I believe is better for RV use. I am not a dealer and do not intend > to sell it although I have the equipment and the product to both inject the > beads thru the vavle stem on a installed tire and the bags that are thrown > into the casing on new tires. > http://www.wheelweights.com/cbb-brochure.pdf#search='counteract% 20balancing%20beads' > > Counteract balancing beads differ from equal in that the composition of the > beads and the fact that water moisture does not effect it. In addition > counteract balancing beads come in two different compositions one for cars > and one for trucks or RVs. The two different beads are engineered for the > different tire rebounding characteristics between cars and trucks. > > I now have it in my steer tires and when I install the new tires will > install it in both the steers and the rear duals. > > tom > 1982 FC35 > Vernon Center,NY > > > > > bAt 03:05 AM 6/21/2005 +0000, you wrote: > > I did not know that there was anything different about the valve > >core . I thought they just put the colored bands on them to show to the > >next tire mechanic that the tires infact had equal in them. What would > >be the difference in the valve core ??? Bob 93pt illinois > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > One of my favorite sayings goes! "You never own anything, everything owns you!" > > > > > > --------------------------------- > Yahoo! Sports > Rekindle the Rivalries. Sign up for Fantasy Football > > [Non-text portions of this message have been removed] > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-21-2005, 04:15
Powder Balancing
just the facts please! from what i can see equal don't clump,but,on another site
they claimed the balls would rust together,then someone else used BB's,and a lot of truckers use golf balls. i have a full set of centramatics,and equal in the front tires along with the centramatics. i guess that the only way to know is try them all..randydupree93wb ----- Original Message ----- From: Mark Garber To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 21, 2005 10:15 AM Subject: Re: [WanderlodgeForum] Re: Powder Balancing Tom, don't mind him. I know you've heard the saying "a few marbles loose". Well in randys case, all the golf balls feel out when the doc turned him up to smack him on his arse. ![]() Mark, 80FC35 just about to leave PA randydupree tom.the tire guy i use has a clear glass jar with a bag of equal in it along with a cup of water.its been sitting on his counter for years.there is no clumping in this jar..is there different types of equal? smooth or clumpy? also,i understand that the beads will rust and stick together if your coach sits for a while.is that true?damn,i guess the golf balls were the right thing to use after all. any insight on this matter ? randydupree93wb __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-21-2005, 04:21
Powder Balancing
the truckers love golf..balls! they only roll around in the tire until you get
up to speed,so they say,so what damage could they do? randydupree93wb ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 21, 2005 11:20 AM Subject: [WanderlodgeForum] Re: Powder Balancing Yep, Randy, (dozen balls here)(Tiger Woods Specials) ![]() We have six gulf balls in each steer tire, Found them when we had a leaky valve stem replaced. The previous owner had a tire guy, that believed, this was the best way to balance. Our coach handles fine, goes straight and does not vibrate. Some have said that golf balls could damage the inside of the tire, but they do not clog the valves. I am happy for now, but am confused about the best method for balancing. We will purchase tires latter this year. (need to make a decision) Bill 88 FC Who never did like to golf, just really terrible --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > tom.the tire guy i use has a clear glass jar with a bag of equal in it along with a cup of water.its been sitting on his counter for years.there is no clumping in this jar..is there different types of equal? smooth or clumpy? also,i understand that the beads will rust and stick together if your coach sits for a while.is that true? damn,i guess the golf balls were the right thing to use after all. any insight on this matter ? randydupree93wb > ----- Original Message ----- > From: jon lechich > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 21, 2005 12:34 AM > Subject: Re: [WanderlodgeForum] Re: Powder Balancing > > > Is this rebounding characteristic that noticeable when you do not have this material in your tires? Does it make for a smoother ride? Jon > Jon Lechich > Bremerton Washington > > Tom Warner > The valve core has a filter in it so that the powder cannot get into the > valve stem and cause it to stick. Make sure if you do get equal that you > get these valve stems installed. > > Actually I would not install equal in a RV tire unless you are going to put > a lot of miles on the tires. If it sits for any length of time and there is > even the slightest amount of water vapor in the tire the equal may clump. > Truckers use it and do not have these problems because the tires are > constantly moving. > > On the other hand I have about 40# of Counteract balancing beads a compound > which I believe is better for RV use. I am not a dealer and do not intend > to sell it although I have the equipment and the product to both inject the > beads thru the vavle stem on a installed tire and the bags that are thrown > into the casing on new tires. > http://www.wheelweights.com/cbb-brochure.pdf#search='counteract% 20balancing%20beads' > > Counteract balancing beads differ from equal in that the composition of the > beads and the fact that water moisture does not effect it. In addition > counteract balancing beads come in two different compositions one for cars > and one for trucks or RVs. The two different beads are engineered for the > different tire rebounding characteristics between cars and trucks. > > I now have it in my steer tires and when I install the new tires will > install it in both the steers and the rear duals. > > tom > 1982 FC35 > Vernon Center,NY > > > > > bAt 03:05 AM 6/21/2005 +0000, you wrote: > > I did not know that there was anything different about the valve > >core . I thought they just put the colored bands on them to show to the > >next tire mechanic that the tires infact had equal in them. What would > >be the difference in the valve core ??? Bob 93pt illinois > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > One of my favorite sayings goes! "You never own anything, everything owns you!" > > > > > > --------------------------------- > Yahoo! Sports > Rekindle the Rivalries. Sign up for Fantasy Football > > [Non-text portions of this message have been removed] > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
