Kool o matic fan thermostat
05-20-2010, 09:32
White is the supply voltage, in this case used for both heating and cooling
(fan), so jumpered to Rh and Rc on a standard thermostat. Brown is heat, W on a standard thermostat. Green is Fan, G on a standard thermostat. I used the Hunter 42999B, which is around $20 from Wal-Mart. See http://www.hunterfan.com/product_detail.aspx?id=7414 This is a universal thermostat that doesn't care about voltages on Rh or Rc. Millivolts or 24-volts, it doesn't care. Uses a battery to control the display. On 5/20/2010 at 6:31 PM Stephen wrote: >I think I might have found the wires cut off behind a soffet panel. I >have a green wire and white and a brown, but I don't have the schematic >for the circuit in my books. Can anyone provide me with it? > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> Yes. The black thing is the electric/propane switch I mentioned. >> >> On 5/20/2010 at 1:28 PM Stephen wrote: >> >> >So I assume the one on the right is the one I am looking for? What is >> >that black thing beneath it? >> > >> >Thanks again for all your help. >> > >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >> >wrote: >> >> >> >> This picture: >> >http://www.arcatapet.net/travel/images/9...ostats.jpg shows the >> >original thermostat(s). Under the paper towels is the AC thermostat, and >> >recessed in the partition is the heat/fan t-stat with a switch below it >> >for electric/propane. >> >> >> >> I've moved the new digital to the other side of that partition, since >we >> >typically have toaster and coffee maker under the original location. >> >> >> >> The dash switches do have to be on for the various toe heaters to >work. >> >> >> >> Don Bradner >> >> 90 PT40 "Blue Thunder" >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 >> >> >> >> On 5/19/2010 at 6:12 PM Stephen wrote: >> >> >> >> >Don, >> >> >I think maybe mine is missing one. There is only one mid-coach >> >thermostat >> >> >and it is only for the Air Conditioner. The other switch I refered to >> >has >> >> >now heat and cool switch. it is simply a reostatic type switch. This >> >coach >> >> >has been remodeled and I think they may have left it out, because the >> >> >front toe kick heater doesn't come on either and I can't find a >control. >> >> >Where exactly is the t-stat located on your model? >> >> > >> >> >thanks for all the replies >> >> >Stephen >> >> > >> >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >> >> >wrote: >> >> >> >> >> >> On my 90wb there are two mid-coach thermostats. One is the center >air >> >> >conditioner, and the other controls electric heat, propane heat, and >the >> >> >Kool o Matic. Should just be a matter of changing from heat to cool. >I >> >> >swapped that thermostat out for a digital some time ago, but it still >> >> >works the same way. >> >> >> >> >> >> Don Bradner >> >> >> 90 PT40 "Blue Thunder" >> >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 >> >> >> >> >> >> On 5/18/2010 at 5:01 PM Stephen wrote: >> >> >> >> >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The >owners >> >> >> >manual says it is controlled by a thermostat in the kitchen but >the >> >only >> >> >> >one near there is on the opposite side wall between the couch and >the >> >> >> >table. >> >> >> > >> >> >> >There is what looks like a ceiling fan switch under the cabinets >but >> >it >> >> >> >doesn't turn anything on. Is that it and if so is could I get a >> >wiring >> >> >> >schematic so I could test it? >> >> >> >> >> > >> >> > >> >> > >> >> > >> >> >------------------------------------ >> >> > >> >> >Yahoo! Groups Links >> >> > >> >> > >> >> > >> >> >> > >> > >> > >> > >> >------------------------------------ >> > >> >Yahoo! Groups Links >> > >> > >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
05-25-2010, 09:23
That fixed it. I had to get the thermostat a lowes but installed it, and both
the Fan and the Toe kick heater in the front works now. Thanks for everything. --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > White is the supply voltage, in this case used for both heating and cooling (fan), so jumpered to Rh and Rc on a standard thermostat. > > Brown is heat, W on a standard thermostat. > > Green is Fan, G on a standard thermostat. > > I used the Hunter 42999B, which is around $20 from Wal-Mart. See http://www.hunterfan.com/product_detail.aspx?id=7414 This is a universal thermostat that doesn't care about voltages on Rh or Rc. Millivolts or 24-volts, it doesn't care. Uses a battery to control the display. > > On 5/20/2010 at 6:31 PM Stephen wrote: > > >I think I might have found the wires cut off behind a soffet panel. I > >have a green wire and white and a brown, but I don't have the schematic > >for the circuit in my books. Can anyone provide me with it? > > > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >wrote: > >> > >> Yes. The black thing is the electric/propane switch I mentioned. > >> > >> On 5/20/2010 at 1:28 PM Stephen wrote: > >> > >> >So I assume the one on the right is the one I am looking for? What is > >> >that black thing beneath it? > >> > > >> >Thanks again for all your help. > >> > > >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >wrote: > >> >> > >> >> This picture: > >> >http://www.arcatapet.net/travel/images/9...ostats.jpg shows the > >> >original thermostat(s). Under the paper towels is the AC thermostat, and > >> >recessed in the partition is the heat/fan t-stat with a switch below it > >> >for electric/propane. > >> >> > >> >> I've moved the new digital to the other side of that partition, since > >we > >> >typically have toaster and coffee maker under the original location. > >> >> > >> >> The dash switches do have to be on for the various toe heaters to > >work. > >> >> > >> >> Don Bradner > >> >> 90 PT40 "Blue Thunder" > >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> >> > >> >> On 5/19/2010 at 6:12 PM Stephen wrote: > >> >> > >> >> >Don, > >> >> >I think maybe mine is missing one. There is only one mid-coach > >> >thermostat > >> >> >and it is only for the Air Conditioner. The other switch I refered to > >> >has > >> >> >now heat and cool switch. it is simply a reostatic type switch. This > >> >coach > >> >> >has been remodeled and I think they may have left it out, because the > >> >> >front toe kick heater doesn't come on either and I can't find a > >control. > >> >> >Where exactly is the t-stat located on your model? > >> >> > > >> >> >thanks for all the replies > >> >> >Stephen > >> >> > > >> >> >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> >wrote: > >> >> >> > >> >> >> On my 90wb there are two mid-coach thermostats. One is the center > >air > >> >> >conditioner, and the other controls electric heat, propane heat, and > >the > >> >> >Kool o Matic. Should just be a matter of changing from heat to cool. > >I > >> >> >swapped that thermostat out for a digital some time ago, but it still > >> >> >works the same way. > >> >> >> > >> >> >> Don Bradner > >> >> >> 90 PT40 "Blue Thunder" > >> >> >> My location: http://www.bbirdmaps.com/user2.cfm?user=1 > >> >> >> > >> >> >> On 5/18/2010 at 5:01 PM Stephen wrote: > >> >> >> > >> >> >> >I have a 90wb that has a Kool o Matic fan in the galley. The > >owners > >> >> >> >manual says it is controlled by a thermostat in the kitchen but > >the > >> >only > >> >> >> >one near there is on the opposite side wall between the couch and > >the > >> >> >> >table. > >> >> >> > > >> >> >> >There is what looks like a ceiling fan switch under the cabinets > >but > >> >it > >> >> >> >doesn't turn anything on. Is that it and if so is could I get a > >> >wiring > >> >> >> >schematic so I could test it? > >> >> >> > >> >> > > >> >> > > >> >> > > >> >> > > >> >> >------------------------------------ > >> >> > > >> >> >Yahoo! Groups Links > >> >> > > >> >> > > >> >> > > >> >> > >> > > >> > > >> > > >> > > >> >------------------------------------ > >> > > >> >Yahoo! Groups Links > >> > > >> > > >> > > >> > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
