Paint used for the Wanderlodges of 1995 vintage.
10-27-2010, 08:52
10-28-2010, 00:18
ROB. basf codes as follows. 79619 ford warm white 79861 ford light saddle met.
79857 ford med gold met 79885 ford wine met 79727 ford med green met. these are base coat clear coar colors imron will not match. I would have these colors mixed by a BASF jobber that will be your best match. Lee Condosta 85 PT 40 Wilmington NC --- In WanderlodgeForum@yahoogroups.com, Rob Robinson > > Ron I have no idea what manufacturer made my original paint and I have since > thrown out the touch up stuff that Randy's buddy made for me. It went bad. > Probably froze at one time. I can't remember the touch up brand name but if > it's real important I'll get in touch with Randy and see what I can find > out. > > On 24 October 2010 09:01, Ron Thompson > > > > > > > Rob, > > I painted my maroon color on a white sheet of paper and will try and find > > an Imron Paint dealer here in Houston and see if they can identify or match > > the color and the shiny particles in the paint. also want to get the proper > > clear coat. > > > > Thanks for replying. Rob, you don't happen to know who was the > > manufacturer of your 1994 paint, do you? Was it Imron? I know that Dupont > > Imron is used throughout the auto painting industry. > > > > > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > > > --- On *Sat, 10/23/10, Rob Robinson > > > > > > From: Rob Robinson > > Subject: Re: [WanderlodgeForum] Paint used for the Wanderlodges of 1995 > > vintage. > > To: WanderlodgeForum@yahoogroups.com > > Date: Saturday, October 23, 2010, 5:37 PM > > > > > > > > Ron several years ago I was in the same situation as you. Only one of my > > codes for my 94 was correct (white) and no one could match the rest with > > anything on the market. Randy Dupree called a friend of his and he brought > > out a kind of camera that analysis paint and gives you a match. > > > > > > On 23 October 2010 13:42, Ron Thompson > > > wrote: > > > >> > >> > >> I want to get some touch up paint for my 1995 Wide Body, 42'. Trouble is > >> I can't seem to find how to relate to the paint codes which were posted > >> above my dash approximately middle of the over head. Had to lay down on my > >> back to get the codes. > >> > >> It appears that the codes might be a Bluebird part # that you would have > >> to cross reference to whomever they got their paint from. > >> > >> Here are the codes that I found in the RV. > >> > >> paint colors 112297 > >> Base 79619 Assume this to be base primer > >> Light 79861 Assume this is the off white > >> Stripe 79857 Assume this is the gold colored stripe > >> Dark 79885 This could mean the Green or the Maroon > >> Other 79727 There were two gold colors. this could > >> be the > >> other one. > >> > >> You can see that it would be a mistake to assume what I have assumed. I > >> am trying to find out what kind of paint it is and what the codes mean as > >> far as identifying what color the number represents and what other > >> information that the code represents. > >> > >> I know that many of the coaches were painted with Imron paint but I found > >> one message on the forum that said it was a paint made by a German company > >> for the model year 1995. > >> > >> Is there anyone in our forum that knows what paint was used and who made > >> it for the Wanderlodges of 1995 model year. > >> > >> Thanks for any help. > >> > >> > >> Ron Thompson -Waller, Tx. > >> 1995 WLWB 42' > >> (cockyfox@... <http://mc/compose?to=cockyfox@...>) > >> > >> > > > > > > -- > > Rob, Sue and Joey Robinson > > > > > > > > > > -- > Rob, Sue and Joey Robinson > |
10-28-2010, 00:38
Thank you Lee. That info will prove valuable to anyone with a mid nineties coach. I have a 99 now. I'll get my numbers and post them. Who knows they may be BASF as well. I'll run them by my local paint shop
On 28 October 2010 05:18, lcondosta <"lcondosta@hotmail.com"> wrote:
-- Rob, Sue and Joey Robinson |
10-28-2010, 00:57
when i wanted to touch up places on my BIRD i took the bus to an auto paint
supplier. He came out with some kind of gadget that read each paint color on the coach, he then made up the paints for me, Ted --- In WanderlodgeForum@yahoogroups.com, "lcondosta" > > ROB. basf codes as follows. 79619 ford warm white 79861 ford light saddle met. 79857 ford med gold met 79885 ford wine met 79727 ford med green met. these are base coat clear coar colors imron will not match. I would have these colors mixed by a BASF jobber that will be your best match. Lee Condosta 85 PT 40 Wilmington NC > > --- In WanderlodgeForum@yahoogroups.com, Rob Robinson > > > > Ron I have no idea what manufacturer made my original paint and I have since > > thrown out the touch up stuff that Randy's buddy made for me. It went bad. > > Probably froze at one time. I can't remember the touch up brand name but if > > it's real important I'll get in touch with Randy and see what I can find > > out. > > > > On 24 October 2010 09:01, Ron Thompson > > > > > > > > > > > Rob, > > > I painted my maroon color on a white sheet of paper and will try and find > > > an Imron Paint dealer here in Houston and see if they can identify or match > > > the color and the shiny particles in the paint. also want to get the proper > > > clear coat. > > > > > > Thanks for replying. Rob, you don't happen to know who was the > > > manufacturer of your 1994 paint, do you? Was it Imron? I know that Dupont > > > Imron is used throughout the auto painting industry. > > > > > > > > > Ron Thompson -Waller, Tx. > > > 1995 WLWB 42' > > > (cockyfox@) > > > > > > --- On *Sat, 10/23/10, Rob Robinson > > > > > > > > > From: Rob Robinson > > > Subject: Re: [WanderlodgeForum] Paint used for the Wanderlodges of 1995 > > > vintage. > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Saturday, October 23, 2010, 5:37 PM > > > > > > > > > > > > Ron several years ago I was in the same situation as you. Only one of my > > > codes for my 94 was correct (white) and no one could match the rest with > > > anything on the market. Randy Dupree called a friend of his and he brought > > > out a kind of camera that analysis paint and gives you a match. > > > > > > > > > On 23 October 2010 13:42, Ron Thompson > > > > wrote: > > > > > >> > > >> > > >> I want to get some touch up paint for my 1995 Wide Body, 42'. Trouble is > > >> I can't seem to find how to relate to the paint codes which were posted > > >> above my dash approximately middle of the over head. Had to lay down on my > > >> back to get the codes. > > >> > > >> It appears that the codes might be a Bluebird part # that you would have > > >> to cross reference to whomever they got their paint from. > > >> > > >> Here are the codes that I found in the RV. > > >> > > >> paint colors 112297 > > >> Base 79619 Assume this to be base primer > > >> Light 79861 Assume this is the off white > > >> Stripe 79857 Assume this is the gold colored stripe > > >> Dark 79885 This could mean the Green or the Maroon > > >> Other 79727 There were two gold colors. this could > > >> be the > > >> other one. > > >> > > >> You can see that it would be a mistake to assume what I have assumed. I > > >> am trying to find out what kind of paint it is and what the codes mean as > > >> far as identifying what color the number represents and what other > > >> information that the code represents. > > >> > > >> I know that many of the coaches were painted with Imron paint but I found > > >> one message on the forum that said it was a paint made by a German company > > >> for the model year 1995. > > >> > > >> Is there anyone in our forum that knows what paint was used and who made > > >> it for the Wanderlodges of 1995 model year. > > >> > > >> Thanks for any help. > > >> > > >> > > >> Ron Thompson -Waller, Tx. > > >> 1995 WLWB 42' > > >> (cockyfox@ <http://mc/compose?to=cockyfox@>) > > >> > > >> > > > > > > > > > -- > > > Rob, Sue and Joey Robinson > > > > > > > > > > > > > > > > > -- > > Rob, Sue and Joey Robinson > > > |
