Kohler generator smokes alot!
06-29-2005, 14:40
Ernie, in my situation, I had a 1" exhaust from the genny muffler to
the outside of the coach..the exhaust would soot quite a spot if left run for several hrs. Eric the genny guy explained to me to increase the size of the exhaust pipe 1/2 in would increase flow exponentially. I am sure there are some folks better qualified than I to explain this about flow. I only increased mine to 1.75 I will go to 2" next time..exhaust still "pops" a little bit while running and does still soot a bit but much less than before..also going to pull injectors off and have them checked out.. Scott 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Scott- you mentioned that you knew a fella that was extremely knowledgeable > about exhausts. can you share with us what he told you about your generator > exhaust. I have seen quite a few exhausts that were extremely small, thus in my > thinking would be restrictive in the performance of that engine. thanks, > ernie-83pt40 in montana > > > [Non-text portions of this message have been removed] |
06-29-2005, 22:21
The proper starting procedure is to hold the "off" button down
for 30 seconds in warm weather and a minute in cold before cranking. That heats things up prior to cranking. Mine belches a decent cloud of black smoke when first started, then a fair amount of smoke during the first minute. After it's warmed up, I get a very slight, continuous visible smoke from the 2 inch exhaust. It's just enough smoke to tell it's running, but the smoke has disappeared after it's moved about 3 feet. It works fine, all maintenance is up to date and it doesn't use any oil. I guess that's one standard you can compare yours to, if this helps. Mine has an oil bath air cleaner that is now sparkling clean. If that gets plugged, it can cause a lot of smoke and some oil consumption. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "tracyt3" > I have the 12.5 Kohler generator in an 85 PT40 it smokes quite alot, > is there anything I can do in minor maintanence? When I start it up it > smokes alot then it progressively get less smoke but not all goes > away. Oil and filter changed not long ago. > > John Mann > 85 pt40 > Granbury Tx. |
