Television Upgrade In My LXi
10-10-2019, 18:08
Post: #21
RE: Television Upgrade In My LXi
Hi,
Maybe consider starting over. Do you use the FM? Its a 450 but same audio ideas I pulled out the Harmon Kardon amp . Put in a Visio sound bar, attached the DVD to that, Sat , cable and over the air to the TV. The Sub Bass is wireless so I put it where the amp was and attached the existing wires to the surround speakers . (I replaced them but Bose are fine there.) It's a Sony 43 inch so true Android for streaming. The Sony is thin around the outer 1 inch so it can overlap a little. The sound bar is bluetooth so streaming music is great. https://photos.app.goo.gl/q3eTJpDLh3W6K1aG8 Ross Ross MacKillop Wiarton Ontario 2006 450 Lxi |
1 user Likes dentmac's post |
10-12-2019, 14:48
Post: #22
Hi Ross
Sounds like you fixed your problem. Not sure where you are located. Any idea of where to look for someone to do the install? If I had a simple wiring diagram I could probably do it. Will appreciate any help. Thanks Urnie Urnie & Medie Krueger Yorkville, IL 2001 LXi One Slide 1983 FC35 sold |
10-14-2019, 22:27
Post: #23
Hi,
The wiring is quite easy. Label the rear speaker wires. Fishing a few HDMI cables. A guy at Best Buy could lay that out for you. Cutting out for the larger TV (Sony 43) and mounting it and the soundbar (Visio) took some fiddling. BTW I'm in this town: https://www.google.com/maps/place/Wiarto...81.1408344 Ross MacKillop Wiarton Ontario 2006 450 Lxi |
