Starting Batteries
12-02-2005, 03:17
Post: #21
Starting Batteries
Hi All,
I haven't been able to be on the site much lately, but am also at the point of replacing batteries. I have six Continentals that are about three years old (group 27). They seem to have needed and excessive amount of water and I have used distilled. My charger is a Xamtrex. The setup is horrible. There are four on the bottom and a tray with the top two a couple of inches above the four. To get to the lower batteries the top tray has to be removed and all the bateries just about have to come out to get to them, plus the terminals and battery tops are usually filthy (lots of acid buildup on negative posts). It takes me a good half day to take them all out and clean and water. Should I got to Trojans, something maintanence free or what? Also, my battery up front, I thought was for the generator, is not. It is just an auxilary battery. You can completely disconnect it and start the generator. However, you can tell it kicks in when you push the aux switch. So, I guess I have several concerns. Thanks for any help. Dave in Tulsa (84PT40) --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Thanks Hank, This is my first encounter with Continental batteries. The owner > of the battery shop says he can't keep enough of them on hand. Ernie- 83pt40 > in Texas > > > [Non-text portions of this message have been removed] > |
12-02-2005, 04:31
Post: #22
Starting Batteries
Steve,
If you used filtered well water would that be ok, or as safe as distilled water. Thanks, Howard Truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: patticake592000 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 01, 2005 11:23 AM Subject: [WanderlodgeForum] Re: Starting Batteries When adding water remember to use disstilled water, not tap. Will help them last. Speaking from the school of hard knocks, with a masters degree. Steve Gureasko 90wl40wb Ponchatoula, La. presently in Boerne waiting for the rally to start!!! ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
12-02-2005, 04:47
Post: #23
Starting Batteries
The Trojan maintenance guide says "Use only distilled or deionized water".
Dick Hayden '87PT38 - Lk Stevens, WA ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 02, 2005 8:31 AM Subject: Re: [WanderlodgeForum] Re: Starting Batteries Steve, If you used filtered well water would that be ok, or as safe as distilled water. Thanks, Howard Truitt Camilla, Ga. 86 8V92 PT40 ----- Original Message ----- From: patticake592000 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, December 01, 2005 11:23 AM Subject: [WanderlodgeForum] Re: Starting Batteries When adding water remember to use disstilled water, not tap. Will help them last. Speaking from the school of hard knocks, with a masters degree. Steve Gureasko 90wl40wb Ponchatoula, La. presently in Boerne waiting for the rally to start!!! ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
12-02-2005, 15:34
Post: #24
Starting Batteries
At times during my years with Bell South I maintained strings of wet
cell batterys. The training we received advised not to use tap water because the stuff that was in the water would settle in the bottom of the case and would evenually cause it to short out. But hey these cells were designed to last 50 years. Johnny M Slone Pikeville, Ky (Stompin ground of the Hatfield and McCoys) 84 PT35 - -- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > The Trojan maintenance guide says "Use only distilled or deionized water". > > Dick Hayden '87PT38 - Lk Stevens, WA > ----- Original Message ----- > From: Howard O. Truitt > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, December 02, 2005 8:31 AM > Subject: Re: [WanderlodgeForum] Re: Starting Batteries > > > Steve, > > If you used filtered well water would that be ok, or as safe as distilled water. > Thanks, > > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > ----- Original Message ----- > From: patticake592000 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, December 01, 2005 11:23 AM > Subject: [WanderlodgeForum] Re: Starting Batteries > > > When adding water remember to use disstilled water, not tap. Will > help them last. Speaking from the school of hard knocks, with a > masters degree. > Steve Gureasko > 90wl40wb > Ponchatoula, La. presently in Boerne waiting for the rally to > start!!! > > > > > > ------------------------------------------------------------------ ------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------ ------------ > > > > [Non-text portions of this message have been removed] > > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum >" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum- unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
12-03-2005, 14:04
Post: #25
Starting Batteries
> Should I go to Trojans... my battery up front, I thought was for the
generator, is not. It is just an auxilary battery. You can completely disconnect it and start the generator. Dave in Tulsa (84PT40) I recently installed 6 Trojan T105's in the rear of my '86 PT38. There is plenty of room. Mine are all on one level though. My genset can also be started with the front battery disconnected. I added a battery disconnect near the main battery bank, so when dry camping I can disconnect the front battery to prevent it from running down. I also flip it when I disconnect the main battery bank when I put the rig in storage, to prevent it from running down. I can send you some pictures for ideas..... Steve Harrie '86 PT38 St. George, UT |
12-10-2005, 09:01
Post: #26
Starting Batteries
Steve,
Thanks for the info. Sorry to be so long in getting back. If it is not too much trouble some pictures might help. I don't think therte is any way I could get six Trogan batteries in. Dave in Tulsa (84PT40) --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" < nicodemus815@c...> wrote: > > > Should I go to Trojans... my battery up front, I thought was for the > generator, is not. It is just an auxilary battery. You can completely > disconnect it and start the generator. Dave in Tulsa (84PT40) > > I recently installed 6 Trojan T105's in the rear of my '86 PT38. There > is plenty of room. Mine are all on one level though. > > My genset can also be started with the front battery disconnected. I > added a battery disconnect near the main battery bank, so when dry > camping I can disconnect the front battery to prevent it from running > down. I also flip it when I disconnect the main battery bank when I > put the rig in storage, to prevent it from running down. > > I can send you some pictures for ideas..... > > Steve Harrie > '86 PT38 > St. George, UT > |
12-10-2005, 10:08
Post: #27
Starting Batteries
>If it is not too much trouble some pictures might help. Dave in Tulsa
(84PT40) No trouble Dave. Yahoo cut your email off at the "@". Email me at nicodemus815 at cs dot com and I'll send you some picts. Steve Harrie St. George '86 PT38 |
12-11-2005, 14:59
Post: #28
Starting Batteries
Stephen,
I could not get your e-mail to send. Please give me the info again or different e-mail. --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" < nicodemus815@c...> wrote: > > >If it is not too much trouble some pictures might help. Dave in Tulsa > (84PT40) > > No trouble Dave. Yahoo cut your email off at the "@". Email me at > nicodemus815 at cs dot com and I'll send you some picts. > > Steve Harrie > St. George > '86 PT38 > |
12-12-2005, 00:09
Post: #29
Starting Batteries
or different e-mail. nicodemus815@... Steve |
