Water Leaks!
03-05-2006, 14:58
Post: #21
Water Leaks!
Thanks Greg. I saw those and the write up said they had been tested carefully
under all conditions. But when I first looked at them they didn't look as
substantial as the compression fittings and this is a job I only want to do
once!
Bruce Morris (919)872-7635 Raleigh, NC
Webmaster - Wanderlodge Owners Online
1983 WL FC35RB
FMCA: 7142s Ham Radio: KI4ME
Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv
Sent: Sunday, March 05, 2006 9:08 PM
Subject: [WanderlodgeForum] Re: Water Leaks!
Pex makes a connector that works like copper tubing connector. No
ferrel needed. The pex connectors come in all configurations. elbows,
unions. I have used them for years. Cut tubing slide nut over tubing
push fitting into tubing screw nut till it is tight. Just to make
sure this would work, i heated water in tubing to 175 degrees and 100
psi no leaks and no failures. Did this right the water heater outlet
line. 6 years later no problems, and they work in cramped spaces, no
need for the long handle crimpers. Also much less costly.
Greg
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
03-05-2006, 15:40
Post: #22
Water Leaks!
Pex tubing works nicely IF you get the correct product , have the
correct tools to cut (has to be clean and perfectly square to prevent
leaks) and install it. There are two different general kinds of Pex
tubing that which is coated and does not pass oxygen and that
without coating which does. In addition not all Pex tubing can be
used for potable water purposes unless it is marked with a laboratory
seal and/or words to the effect that it is safe to use for potable
water purposes. For your purposes I would think the straight lengths
would be best and easiest to use.
tom warner
1982 FC35
Vernon Center,NY
>Greg
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\
ObWmSYTw>Recreational
>vehicles
><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\
nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\
anderlodge
><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\
icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\
=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\
4cC1O9CxA>Automotive
>maintenance
><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\
l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\
YHfELr6o72IW1A>Recreational
>vehicle dealer
><http://groups.yahoo.com/gads?t=ms&k=Used...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\
-kXbDI4ZSadEw>Used
><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
03-05-2006, 16:49
Post: #23
Water Leaks!
Mine has two of them. One under the kitchen sink, and one under the bed, on
top of the rear furnace.- Of course neither did a bit of good when the
previous owners didn't keep the coach plugged in--- not to mention properly
drained, and maintained. However, I did set the thermostats on them to
around 38 Just for kicks.(not like its going to get there here in Florida
very often, but just in case)
Stephen
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of mbulriss
Sent: Sunday, March 05, 2006 1:03 PM
Bruce -
The freeze heaters on my 83 had an adjustable thermostat on each of
them. Mine were set to kick on at about 35 degrees or so. Maybe
someone turned yours up higher if they are running at temps well above
freezing.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Bruce Morris" <bamnc@...> wrote:
> Yes Tom. I know about the freeze heaters and they are still there.
However I doubt that they are working as they were designed. They
seemed to run a whole lot more than they should when the ambient
temperature was well above freezing. Like many things in a 20+ year
old Bird they just need attention and since I was incapacitated for
most of the last 4 or 5 years I am playing catch up.
> I am familiar with the tape that has the thermostat in the end and I
haven't pulled one of the blue wires yet to check it, but am under the
impression that there was no mechanism at the end of the wire. I'll
learn more when I can see one that is intact.
> From: Tom Warner
> Sent: Sunday, March 05, 2006 10:26 AM
> Subject: Re: [WanderlodgeForum] Water Leaks!
> Bruce if you have the coach as it was originally built you should
> have a freeze protector (electric heater with blower) installed near
> the water tank and another in the area of the kitchen sink. These are
> thermostatically controlled and will keep the pipes from freezing.
> The blue heat tape is further protection and is a resistance tape
> that is controlled by a thermostat molded in at the end of the tape.
> tom warner
> 1982 FC35
> Vernon Center,NY
> At 09:34 AM 3/5/2006, you wrote:
> >Well Tom, as I said earlier I don't winterize my Bird but I do keep
> >it connected to electricity and keep heat in it when it gets too
> >cold. Maybe it's just a "Bruce" thing.
> >I know that my Bird came from New Hampshire where it probably got
> >cold enough to be a problem. All of the problems I have encountered
> >did not occur on my watch, but I have to deal with them. I suspect
> >the same thing is true of Bruce in Florida too since I believe he
> >just bought the coach from someplace up north.
> >So I guess you are right neither one of us followed the procedures
> >as outlined in the Blue Box.
> >1983 WL FC35RB
> > From: Tom Warner
> > Sent: Saturday, March 04, 2006 11:57 PM
> > The fact that you both have frozen pipes begs the question of
whether
> > either of you properly followed the procedures for winterizing
your
> > fresh, grey and black water systems that is outlined in your
> > owners manuals?
> > tom warner
> > 1982 FC35
> > Vernon center,NY
> > At 09:52 PM 3/4/2006, you wrote:
> > >Stephen, that is exactly what I am doing with my Bird now.
It looks
> > >like I am going to have to remove most of the pipes and replace
> > >them. The ones that had not burst were expanded so that none
of the
> > >standard fittings will work. So, to do it right I have
decided to
> > >replace the copper with PEX which is supposed to be resistant to
> > >bursting if frozen and it supposed to be much easier to work
with in
> > >tight areas.
> > >I have some pictures on the WOO site where I have taken mine
apart,
> > >but I still have to put the new in yet. I will be doing it
in the
> > >next few days . . . one way or the other.
> > >1983 WL FC35RB
> > > From: Stephen
> > > Sent: Saturday, March 04, 2006 9:35 PM
> > > Subject: [WanderlodgeForum] Water Leaks!
> > > Anyone else out there had to deal with what Im going
through? I have
> > > Niagra Falls running through my bus... Almost ALL of the
copper water
> > > pipes are busted...(I guess thats what I get for buying a
unit from up
> > > north) I got 3 repaired today --after removing the water
tank- and now
> > > there are more behind the stove-ice maker area!! I dont
know how im
> > > going to get those out from behind there, and the shower
area(SB).....
> > > Any ideas????? HELP!!!
> > > Stephen
> > > 81 FC-33SB
> > > Plant City, FL
> > > maintenance
> > > vehicles Automotive radiators
> > > YAHOO! GROUPS LINKS
Terms
> > > of Service.
> > >SPONSORED LINKS
><<http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
kCKkU7Dzhn_ObWmSYTw>
&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti
ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&
w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>http://groups.
yahoo.com/gads?t=ms
> > >vehicles
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP
j9U0JvqYQ>
&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten
ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot
ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>http://groups.yahoo.com/
gads?t=ms
j9U0JvqYQ>
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
4u_5wI8Pmy34cC1O9CxA>
&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot
ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles
&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>http://groups
> > >maintenance
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s
ig=z6_XahaeYHfELr6o72IW1A>
&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au
tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh
icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>http://g
> > >vehicle dealer
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si
g=UGEY5km4L-kXbDI4ZSadEw>
&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut
omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi
cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>http://gr
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA>
&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv
e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w
6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>http://groups.y
ahoo.com/gads?t=ms
MmISsCWgTnMq_4GlXA>
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr
> > on the web.
Wan
<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> > Terms of Service.
> > maintenance
> > YAHOO! GROUPS LINKS
> > of Service.
> >SPONSORED LINKS
w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational
> >vehicles
j9U0JvqYQ>
ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge
&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive
> >maintenance
icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati
onal
> >vehicle dealer
cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used
MmISsCWgTnMq_4GlXA>
6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
the web.
Wan
> YAHOO! GROUPS LINKS
Service.
SPONSORED LINKS
Recreational
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
j9U0JvqYQ>
Automotive
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
03-05-2006, 16:56
Post: #24
Water Leaks!
Yes Greg-
That is what I am replacing them all with. Makes for a neat and clean
connection. Everything at my local Home Depot.
No tools needed here. Just a PVC pipe cutter, and an open end wrench!!!
Stephen
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of pbe43
Sent: Sunday, March 05, 2006 9:09 PM
Greg
SPONSORED LINKS
Recreational
Wanderlodge
j9U0JvqYQ>
Automotive
Recreational
Used
Automotive
_____
YAHOO! GROUPS LINKS
_____
