Aux Batt solenoid on PT
05-27-2007, 11:33
Post: #21
Battery with no charge to it for about 20 minutes, approx 12.6 volts is
good. Battery receiving a charge, 13.4+ volts...unless you have the smart chargers that are in the sleep mode. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > And what voltage should it show when charging? > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > > > > > TO be assured that the gen battery is charging under all > conditions, > > check with the shore power, then generator running , then the > engine > > alternator running and charging. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > > wrote: > > > > > > Isn't it all one circuit? > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Agree. Good. > > > > > > > > Do the same test using shore power. > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > OK, the voltage went up with the gen running. So I guess the > > > circuit > > > > > works. > > > > > > > > > > Scott > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > Have you used your multimeter and checked the voltage at > the > > > gen. > > > > > > battery? First before you start the gen. Than again after > the > > > gen. > > > > > is > > > > > > running. The increase in voltage when the gen. is running > > tells > > > > > you > > > > > > that the charge circuit is working. No change in voltage, or > > > > > lower, > > > > > > you know the charge is not working. > > > > > > > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > question.... > > > > > > > > > > > > > > Really I don't have a problem right now. I am just trying > > to > > > learn > > > > > > > my new coach. I knew my old FC inside and out, and that > > gave > > > me > > > > > some > > > > > > > confidence that if I ever had a problem on the road, > maybe > > I > > > could > > > > > > > diagnose it & fix it. I want to feel that way about my > PT, > > > too. I > > > > > > > also want to make sure that the charging circuit is > > charging > > > the > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > Howard Truitt > > > > > > > > Camilla, Ga. > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid on > PT > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's one > on > > the > > > > > front > > > > > > > > > wall of the batter charger compartment. There are two > > > others > > > > > on > > > > > > > the > > > > > > > > > metal panel that folds down to give access to the > > charger > > > > > > > > > compartment. And there are three of them behind the > > step > > > well, > > > > > > > > > although it looks like two of them are for the > leveling > > > pump. > > > > > > > None > > > > > > > > > of these make the audible "click" when I hit the Aux > > Batt > > > > > > > switch. > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as comprehensive > as > > > they > > > > > were > > > > > > > in > > > > > > > > > my FC, so I am having trouble figuring all this out. > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > On my 86 PT40 mine is in the compartment with the > > > chargers. > > > > > But > > > > > > > > > knowing BB and your coach being a 38 footer it may be > > > > > different. > > > > > > > > > > Howard Truitt > > > > > > > > > > Camilla, Ga. > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid on > PT > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 12:07
Post: #22
In my opinion you are making the issue of whether the generator
battery is being charged or not, overly complicated. If you check the generator battery terminal with a voltmeter while the engine is turned off and the charger is turned off and note the voltage and then turn the charger on and you see a voltage increase at the generator battery terminals then the generator charging circuit is working. All charging sources are tied together at the positive battery stud , in back of the battery box on the FC models and above the engine on the PTs. If you want to discuss if the generator battery is being fully charged then that is a different issue entirely and more complicated. Therefore I believe Mr Forman is correct there is only one circuit when it comes to charging the generator battery. If you want to talk about what level the generator battery is being charged to that is a different issue. tom warner vernon center,ny 1985 PT 40 , .At 07:29 PM 5/27/2007, you wrote: >Absolutely correct Bill. > >Curt Sprenger >1987 PT38 8V92 "MacAttack Racing" >Anaheim Hills, Calif. > > > >pattypape wrote: > > > > > > > TO be assured that the gen battery is charging under all conditions, > > check with the shore power, then generator running , then the engine > > alternator running and charging. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > Isn't it all one circuit? > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > Agree. Good. > > > > > > > > Do the same test using shore power. > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > OK, the voltage went up with the gen running. So I guess the > > > circuit > > > > > works. > > > > > > > > > > Scott > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > Have you used your multimeter and checked the voltage at the > > > gen. > > > > > > battery? First before you start the gen. Than again after the > > > gen. > > > > > is > > > > > > running. The increase in voltage when the gen. is running > > tells > > > > > you > > > > > > that the charge circuit is working. No change in voltage, or > > > > > lower, > > > > > > you know the charge is not working. > > > > > > > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > question.... > > > > > > > > > > > > > > Really I don't have a problem right now. I am just trying > > to > > > learn > > > > > > > my new coach. I knew my old FC inside and out, and that > > gave > > > me > > > > > some > > > > > > > confidence that if I ever had a problem on the road, maybe > > I > > > could > > > > > > > diagnose it & fix it. I want to feel that way about my PT, > > > too. I > > > > > > > also want to make sure that the charging circuit is > > charging > > > the > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > Howard Truitt > > > > > > > > Camilla, Ga. > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid on PT > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's one on > > the > > > > > front > > > > > > > > > wall of the batter charger compartment. There are two > > > others > > > > > on > > > > > > > the > > > > > > > > > metal panel that folds down to give access to the > > charger > > > > > > > > > compartment. And there are three of them behind the > > step > > > well, > > > > > > > > > although it looks like two of them are for the leveling > > > pump. > > > > > > > None > > > > > > > > > of these make the audible "click" when I hit the Aux > > Batt > > > > > > > switch. > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as comprehensive as > > > they > > > > > were > > > > > > > in > > > > > > > > > my FC, so I am having trouble figuring all this out. > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > On my 86 PT40 mine is in the compartment with the > > > chargers. > > > > > But > > > > > > > > > knowing BB and your coach being a 38 footer it may be > > > > > different. > > > > > > > > > > Howard Truitt > > > > > > > > > > Camilla, Ga. > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > |
05-27-2007, 12:59
Post: #23
the gen batt read 12.1 before I started it, 12.4 after it was
running. I know that by the book 12.1v is a half-dead battery, but it cranks awfully strong to be half dead. And the 12.4 isn't as high as it should be, but since it is higher there is obviously some charge getting to it...ideas? Another note...my multimeter has two "modes" that I don't really understand. When I turn the dial to one setting, it read 12.4 with generator running, on the other setting it read 26.5. Any idea what this other mode is showing me? Much confusions over here Scott --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Battery with no charge to it for about 20 minutes, approx 12.6 volts is > good. Battery receiving a charge, 13.4+ volts...unless you have the > smart chargers that are in the sleep mode. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Scott Forman wrote: > > > And what voltage should it show when charging? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > conditions, > > > check with the shore power, then generator running , then the > > engine > > > alternator running and charging. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com > > <sforman@> > > > wrote: > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > OK, the voltage went up with the gen running. So I guess the > > > > circuit > > > > > > works. > > > > > > > > > > > > Scott > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > Have you used your multimeter and checked the voltage at > > the > > > > gen. > > > > > > > battery? First before you start the gen. Than again after > > the > > > > gen. > > > > > > is > > > > > > > running. The increase in voltage when the gen. is running > > > tells > > > > > > you > > > > > > > that the charge circuit is working. No change in voltage, or > > > > > > lower, > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > Curt Sprenger > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > > question.... > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just trying > > > to > > > > learn > > > > > > > > my new coach. I knew my old FC inside and out, and that > > > gave > > > > me > > > > > > some > > > > > > > > confidence that if I ever had a problem on the road, > > maybe > > > I > > > > could > > > > > > > > diagnose it & fix it. I want to feel that way about my > > PT, > > > > too. I > > > > > > > > also want to make sure that the charging circuit is > > > charging > > > > the > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > Howard Truitt > > > > > > > > > Camilla, Ga. > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid on > > PT > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's one > > on > > > the > > > > > > front > > > > > > > > > > wall of the batter charger compartment. There are two > > > > others > > > > > > on > > > > > > > > the > > > > > > > > > > metal panel that folds down to give access to the > > > charger > > > > > > > > > > compartment. And there are three of them behind the > > > step > > > > well, > > > > > > > > > > although it looks like two of them are for the > > leveling > > > > pump. > > > > > > > > None > > > > > > > > > > of these make the audible "click" when I hit the Aux > > > Batt > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as comprehensive > > as > > > > they > > > > > > were > > > > > > > > in > > > > > > > > > > my FC, so I am having trouble figuring all this out. > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > On my 86 PT40 mine is in the compartment with the > > > > chargers. > > > > > > But > > > > > > > > > > knowing BB and your coach being a 38 footer it may be > > > > > > different. > > > > > > > > > > > Howard Truitt > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid on > > PT > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:21
Post: #24
Scott,
A bad battery could cause the 12.4 reading. Remove the battery, take it to an auto parts store, have them load test it. Could be a bad cell in the battery. I've experience battereis with a bad cell start engines, and then just die on the spot. What are the "modes" on your multimeter that you are using? We are here to help. Just keep the communication coming. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > the gen batt read 12.1 before I started it, 12.4 after it was > running. I know that by the book 12.1v is a half-dead battery, but > it cranks awfully strong to be half dead. And the 12.4 isn't as high > as it should be, but since it is higher there is obviously some > charge getting to it...ideas? > > Another note...my multimeter has two "modes" that I don't really > understand. When I turn the dial to one setting, it read 12.4 with > generator running, on the other setting it read 26.5. Any idea what > this other mode is showing me? > > Much confusions over here > > Scott > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > volts is > > good. Battery receiving a charge, 13.4+ volts...unless you have the > > smart chargers that are in the sleep mode. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Scott Forman wrote: > > > > > And what voltage should it show when charging? > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > wrote: > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > conditions, > > > > check with the shore power, then generator running , then the > > > engine > > > > alternator running and charging. > > > > > > > > Bill 88 FC Michigan > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > <sforman@> > > > > wrote: > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I guess > the > > > > > circuit > > > > > > > works. > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > Have you used your multimeter and checked the voltage at > > > the > > > > > gen. > > > > > > > > battery? First before you start the gen. Than again > after > > > the > > > > > gen. > > > > > > > is > > > > > > > > running. The increase in voltage when the gen. is > running > > > > tells > > > > > > > you > > > > > > > > that the charge circuit is working. No change in > voltage, or > > > > > > > lower, > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > > > question.... > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > trying > > > > to > > > > > learn > > > > > > > > > my new coach. I knew my old FC inside and out, and > that > > > > gave > > > > > me > > > > > > > some > > > > > > > > > confidence that if I ever had a problem on the road, > > > maybe > > > > I > > > > > could > > > > > > > > > diagnose it & fix it. I want to feel that way about my > > > PT, > > > > > too. I > > > > > > > > > also want to make sure that the charging circuit is > > > > charging > > > > > the > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > Howard Truitt > > > > > > > > > > Camilla, Ga. > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid > on > > > PT > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's > one > > > on > > > > the > > > > > > > front > > > > > > > > > > > wall of the batter charger compartment. There are > two > > > > > others > > > > > > > on > > > > > > > > > the > > > > > > > > > > > metal panel that folds down to give access to the > > > > charger > > > > > > > > > > > compartment. And there are three of them behind > the > > > > step > > > > > well, > > > > > > > > > > > although it looks like two of them are for the > > > leveling > > > > > pump. > > > > > > > > > None > > > > > > > > > > > of these make the audible "click" when I hit the > Aux > > > > Batt > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > comprehensive > > > as > > > > > they > > > > > > > were > > > > > > > > > in > > > > > > > > > > > my FC, so I am having trouble figuring all this > out. > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > On my 86 PT40 mine is in the compartment with > the > > > > > chargers. > > > > > > > But > > > > > > > > > > > knowing BB and your coach being a 38 footer it > may be > > > > > > > different. > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid > on > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:35
Post: #25
The modes are marked by a V followd by 3 dots in one mode and a V
with a wavy line for the other. Doesn't help much, huh? --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Scott, > > A bad battery could cause the 12.4 reading. Remove the battery, take it > to an auto parts store, have them load test it. Could be a bad cell in > the battery. I've experience battereis with a bad cell start engines, > and then just die on the spot. > > What are the "modes" on your multimeter that you are using? > > We are here to help. Just keep the communication coming. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Scott Forman wrote: > > > the gen batt read 12.1 before I started it, 12.4 after it was > > running. I know that by the book 12.1v is a half-dead battery, but > > it cranks awfully strong to be half dead. And the 12.4 isn't as high > > as it should be, but since it is higher there is obviously some > > charge getting to it...ideas? > > > > Another note...my multimeter has two "modes" that I don't really > > understand. When I turn the dial to one setting, it read 12.4 with > > generator running, on the other setting it read 26.5. Any idea what > > this other mode is showing me? > > > > Much confusions over here > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > > volts is > > > good. Battery receiving a charge, 13.4+ volts...unless you have the > > > smart chargers that are in the sleep mode. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Scott Forman wrote: > > > > > > > And what voltage should it show when charging? > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > conditions, > > > > > check with the shore power, then generator running , then the > > > > engine > > > > > alternator running and charging. > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > <sforman@> > > > > > wrote: > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > Curt Sprenger > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I guess > > the > > > > > > circuit > > > > > > > > works. > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > Sprenger > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > Have you used your multimeter and checked the voltage at > > > > the > > > > > > gen. > > > > > > > > > battery? First before you start the gen. Than again > > after > > > > the > > > > > > gen. > > > > > > > > is > > > > > > > > > running. The increase in voltage when the gen. is > > running > > > > > tells > > > > > > > > you > > > > > > > > > that the charge circuit is working. No change in > > voltage, or > > > > > > > > lower, > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > > trying > > > > > to > > > > > > learn > > > > > > > > > > my new coach. I knew my old FC inside and out, and > > that > > > > > gave > > > > > > me > > > > > > > > some > > > > > > > > > > confidence that if I ever had a problem on the road, > > > > maybe > > > > > I > > > > > > could > > > > > > > > > > diagnose it & fix it. I want to feel that way about my > > > > PT, > > > > > > too. I > > > > > > > > > > also want to make sure that the charging circuit is > > > > > charging > > > > > > the > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > > Howard Truitt > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid > > on > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's > > one > > > > on > > > > > the > > > > > > > > front > > > > > > > > > > > > wall of the batter charger compartment. There are > > two > > > > > > others > > > > > > > > on > > > > > > > > > > the > > > > > > > > > > > > metal panel that folds down to give access to the > > > > > charger > > > > > > > > > > > > compartment. And there are three of them behind > > the > > > > > step > > > > > > well, > > > > > > > > > > > > although it looks like two of them are for the > > > > leveling > > > > > > pump. > > > > > > > > > > None > > > > > > > > > > > > of these make the audible "click" when I hit the > > Aux > > > > > Batt > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > comprehensive > > > > as > > > > > > they > > > > > > > > were > > > > > > > > > > in > > > > > > > > > > > > my FC, so I am having trouble figuring all this > > out. > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment with > > the > > > > > > chargers. > > > > > > > > But > > > > > > > > > > > > knowing BB and your coach being a 38 footer it > > may be > > > > > > > > different. > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid > > on > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:37
Post: #26
Dots + DC Volts. Wavy line + AC Volts.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > The modes are marked by a V followd by 3 dots in one mode and a V > with a wavy line for the other. Doesn't help much, huh? > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Scott, > > > > A bad battery could cause the 12.4 reading. Remove the battery, > take it > > to an auto parts store, have them load test it. Could be a bad cell > in > > the battery. I've experience battereis with a bad cell start > engines, > > and then just die on the spot. > > > > What are the "modes" on your multimeter that you are using? > > > > We are here to help. Just keep the communication coming. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Scott Forman wrote: > > > > > the gen batt read 12.1 before I started it, 12.4 after it was > > > running. I know that by the book 12.1v is a half-dead battery, but > > > it cranks awfully strong to be half dead. And the 12.4 isn't as > high > > > as it should be, but since it is higher there is obviously some > > > charge getting to it...ideas? > > > > > > Another note...my multimeter has two "modes" that I don't really > > > understand. When I turn the dial to one setting, it read 12.4 with > > > generator running, on the other setting it read 26.5. Any idea > what > > > this other mode is showing me? > > > > > > Much confusions over here > > > > > > Scott > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > > > volts is > > > > good. Battery receiving a charge, 13.4+ volts...unless you have > the > > > > smart chargers that are in the sleep mode. > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > And what voltage should it show when charging? > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > > conditions, > > > > > > check with the shore power, then generator running , then > the > > > > > engine > > > > > > alternator running and charging. > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > <sforman@> > > > > > > wrote: > > > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I > guess > > > the > > > > > > > circuit > > > > > > > > > works. > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > Sprenger > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > Have you used your multimeter and checked the > voltage at > > > > > the > > > > > > > gen. > > > > > > > > > > battery? First before you start the gen. Than again > > > after > > > > > the > > > > > > > gen. > > > > > > > > > is > > > > > > > > > > running. The increase in voltage when the gen. is > > > running > > > > > > tells > > > > > > > > > you > > > > > > > > > > that the charge circuit is working. No change in > > > voltage, or > > > > > > > > > lower, > > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide > ranging > > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > > > trying > > > > > > to > > > > > > > learn > > > > > > > > > > > my new coach. I knew my old FC inside and out, and > > > that > > > > > > gave > > > > > > > me > > > > > > > > > some > > > > > > > > > > > confidence that if I ever had a problem on the > road, > > > > > maybe > > > > > > I > > > > > > > could > > > > > > > > > > > diagnose it & fix it. I want to feel that way > about my > > > > > PT, > > > > > > > too. I > > > > > > > > > > > also want to make sure that the charging circuit > is > > > > > > charging > > > > > > > the > > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt > solenoid > > > on > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. > There's > > > one > > > > > on > > > > > > the > > > > > > > > > front > > > > > > > > > > > > > wall of the batter charger compartment. There > are > > > two > > > > > > > others > > > > > > > > > on > > > > > > > > > > > the > > > > > > > > > > > > > metal panel that folds down to give access to > the > > > > > > charger > > > > > > > > > > > > > compartment. And there are three of them > behind > > > the > > > > > > step > > > > > > > well, > > > > > > > > > > > > > although it looks like two of them are for the > > > > > leveling > > > > > > > pump. > > > > > > > > > > > None > > > > > > > > > > > > > of these make the audible "click" when I hit > the > > > Aux > > > > > > Batt > > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > > comprehensive > > > > > as > > > > > > > they > > > > > > > > > were > > > > > > > > > > > in > > > > > > > > > > > > > my FC, so I am having trouble figuring all > this > > > out. > > > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment > with > > > the > > > > > > > chargers. > > > > > > > > > But > > > > > > > > > > > > > knowing BB and your coach being a 38 footer it > > > may be > > > > > > > > > different. > > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt > solenoid > > > on > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid > on a > > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:38
Post: #27
Sorry. Change the + to =.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Curt Sprenger wrote: > Dots + DC Volts. Wavy line + AC Volts. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Scott Forman wrote: > > > The modes are marked by a V followd by 3 dots in one mode and a V > > with a wavy line for the other. Doesn't help much, huh? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Scott, > > > > > > A bad battery could cause the 12.4 reading. Remove the battery, > > take it > > > to an auto parts store, have them load test it. Could be a bad cell > > in > > > the battery. I've experience battereis with a bad cell start > > engines, > > > and then just die on the spot. > > > > > > What are the "modes" on your multimeter that you are using? > > > > > > We are here to help. Just keep the communication coming. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Scott Forman wrote: > > > > > > > the gen batt read 12.1 before I started it, 12.4 after it was > > > > running. I know that by the book 12.1v is a half-dead battery, but > > > > it cranks awfully strong to be half dead. And the 12.4 isn't as > > high > > > > as it should be, but since it is higher there is obviously some > > > > charge getting to it...ideas? > > > > > > > > Another note...my multimeter has two "modes" that I don't really > > > > understand. When I turn the dial to one setting, it read 12.4 with > > > > generator running, on the other setting it read 26.5. Any idea > > what > > > > this other mode is showing me? > > > > > > > > Much confusions over here > > > > > > > > Scott > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > > > > volts is > > > > > good. Battery receiving a charge, 13.4+ volts...unless you have > > the > > > > > smart chargers that are in the sleep mode. > > > > > > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > And what voltage should it show when charging? > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > > > conditions, > > > > > > > check with the shore power, then generator running , then > > the > > > > > > engine > > > > > > > alternator running and charging. > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > <sforman@> > > > > > > > wrote: > > > > > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I > > guess > > > > the > > > > > > > > circuit > > > > > > > > > > works. > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > Sprenger > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > Have you used your multimeter and checked the > > voltage at > > > > > > the > > > > > > > > gen. > > > > > > > > > > > battery? First before you start the gen. Than again > > > > after > > > > > > the > > > > > > > > gen. > > > > > > > > > > is > > > > > > > > > > > running. The increase in voltage when the gen. is > > > > running > > > > > > > tells > > > > > > > > > > you > > > > > > > > > > > that the charge circuit is working. No change in > > > > voltage, or > > > > > > > > > > lower, > > > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide > > ranging > > > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > > > > trying > > > > > > > to > > > > > > > > learn > > > > > > > > > > > > my new coach. I knew my old FC inside and out, and > > > > that > > > > > > > gave > > > > > > > > me > > > > > > > > > > some > > > > > > > > > > > > confidence that if I ever had a problem on the > > road, > > > > > > maybe > > > > > > > I > > > > > > > > could > > > > > > > > > > > > diagnose it & fix it. I want to feel that way > > about my > > > > > > PT, > > > > > > > > too. I > > > > > > > > > > > > also want to make sure that the charging circuit > > is > > > > > > > charging > > > > > > > > the > > > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt > > solenoid > > > > on > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. > > There's > > > > one > > > > > > on > > > > > > > the > > > > > > > > > > front > > > > > > > > > > > > > > wall of the batter charger compartment. There > > are > > > > two > > > > > > > > others > > > > > > > > > > on > > > > > > > > > > > > the > > > > > > > > > > > > > > metal panel that folds down to give access to > > the > > > > > > > charger > > > > > > > > > > > > > > compartment. And there are three of them > > behind > > > > the > > > > > > > step > > > > > > > > well, > > > > > > > > > > > > > > although it looks like two of them are for the > > > > > > leveling > > > > > > > > pump. > > > > > > > > > > > > None > > > > > > > > > > > > > > of these make the audible "click" when I hit > > the > > > > Aux > > > > > > > Batt > > > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > > > comprehensive > > > > > > as > > > > > > > > they > > > > > > > > > > were > > > > > > > > > > > > in > > > > > > > > > > > > > > my FC, so I am having trouble figuring all > > this > > > > out. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment > > with > > > > the > > > > > > > > chargers. > > > > > > > > > > But > > > > > > > > > > > > > > knowing BB and your coach being a 38 footer it > > > > may be > > > > > > > > > > different. > > > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt > > solenoid > > > > on > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid > > on a > > > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:42
Post: #28
OK...why does a 12v DC battery show AC voltage?
I used to think I understood vehicle electrical systems.... --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Dots + DC Volts. Wavy line + AC Volts. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Scott Forman wrote: > > > The modes are marked by a V followd by 3 dots in one mode and a V > > with a wavy line for the other. Doesn't help much, huh? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Scott, > > > > > > A bad battery could cause the 12.4 reading. Remove the battery, > > take it > > > to an auto parts store, have them load test it. Could be a bad cell > > in > > > the battery. I've experience battereis with a bad cell start > > engines, > > > and then just die on the spot. > > > > > > What are the "modes" on your multimeter that you are using? > > > > > > We are here to help. Just keep the communication coming. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Scott Forman wrote: > > > > > > > the gen batt read 12.1 before I started it, 12.4 after it was > > > > running. I know that by the book 12.1v is a half-dead battery, but > > > > it cranks awfully strong to be half dead. And the 12.4 isn't as > > high > > > > as it should be, but since it is higher there is obviously some > > > > charge getting to it...ideas? > > > > > > > > Another note...my multimeter has two "modes" that I don't really > > > > understand. When I turn the dial to one setting, it read 12.4 with > > > > generator running, on the other setting it read 26.5. Any idea > > what > > > > this other mode is showing me? > > > > > > > > Much confusions over here > > > > > > > > Scott > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > > > > volts is > > > > > good. Battery receiving a charge, 13.4+ volts...unless you have > > the > > > > > smart chargers that are in the sleep mode. > > > > > > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > And what voltage should it show when charging? > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > > > conditions, > > > > > > > check with the shore power, then generator running , then > > the > > > > > > engine > > > > > > > alternator running and charging. > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Forman" > > > > <sforman@> > > > > > > > wrote: > > > > > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I > > guess > > > > the > > > > > > > > circuit > > > > > > > > > > works. > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > Sprenger > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > Have you used your multimeter and checked the > > voltage at > > > > > > the > > > > > > > > gen. > > > > > > > > > > > battery? First before you start the gen. Than again > > > > after > > > > > > the > > > > > > > > gen. > > > > > > > > > > is > > > > > > > > > > > running. The increase in voltage when the gen. is > > > > running > > > > > > > tells > > > > > > > > > > you > > > > > > > > > > > that the charge circuit is working. No change in > > > > voltage, or > > > > > > > > > > lower, > > > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide > > ranging > > > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > > > > trying > > > > > > > to > > > > > > > > learn > > > > > > > > > > > > my new coach. I knew my old FC inside and out, and > > > > that > > > > > > > gave > > > > > > > > me > > > > > > > > > > some > > > > > > > > > > > > confidence that if I ever had a problem on the > > road, > > > > > > maybe > > > > > > > I > > > > > > > > could > > > > > > > > > > > > diagnose it & fix it. I want to feel that way > > about my > > > > > > PT, > > > > > > > > too. I > > > > > > > > > > > > also want to make sure that the charging circuit > > is > > > > > > > charging > > > > > > > > the > > > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt > > solenoid > > > > on > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. > > There's > > > > one > > > > > > on > > > > > > > the > > > > > > > > > > front > > > > > > > > > > > > > > wall of the batter charger compartment. There > > are > > > > two > > > > > > > > others > > > > > > > > > > on > > > > > > > > > > > > the > > > > > > > > > > > > > > metal panel that folds down to give access to > > the > > > > > > > charger > > > > > > > > > > > > > > compartment. And there are three of them > > behind > > > > the > > > > > > > step > > > > > > > > well, > > > > > > > > > > > > > > although it looks like two of them are for the > > > > > > leveling > > > > > > > > pump. > > > > > > > > > > > > None > > > > > > > > > > > > > > of these make the audible "click" when I hit > > the > > > > Aux > > > > > > > Batt > > > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > > > comprehensive > > > > > > as > > > > > > > > they > > > > > > > > > > were > > > > > > > > > > > > in > > > > > > > > > > > > > > my FC, so I am having trouble figuring all > > this > > > > out. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment > > with > > > > the > > > > > > > > chargers. > > > > > > > > > > But > > > > > > > > > > > > > > knowing BB and your coach being a 38 footer it > > > > may be > > > > > > > > > > different. > > > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt > > solenoid > > > > on > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid > > on a > > > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-27-2007, 14:57
Post: #29
The V with a wavy line on a multimeter is for Alternating voltage,
and the V with 3 dots (actually 3 dashes with a bar over the top) is for Direct Current voltage. The 12.1VDC (50% battery charged) or 12.4VDC(70% battery charged) read across the battery terminals could just be that the battery is discharged or partially discharged and/or has not been charging. Its a lot of work to remove 4-6 or more 60# batteries and cart them to an auto store to test when you can do it in a few minutes without taking them out of the coach. But that is each persons choice of course. I would suggest those interested read the general battery maintenance information from Trojan Batteries although it pertains to all batteries. http://www.trojan-battery.com/Tech-Suppo...sting.aspx Pay particular attention to the process of testing for specific gravity (you need a hydrometer and I would advise everyone interested in doing at least some of the maintenance on their coaches to buy one). And if you really want to understand your charging system including your alternator, chargers and batteries you really should understand what the charging curves look like for voltage and current. Just my opinion but Phfred has lots of really good information on these subjects for RVers. Oh and a Fluke multimeter is an excellent investment and will save you a lot of headaches. Tom Warner vernon center,ny 1985 PT 40 At 10:21 PM 5/27/2007, you wrote: >Scott, > >A bad battery could cause the 12.4 reading. Remove the battery, take it >to an auto parts store, have them load test it. Could be a bad cell in >the battery. I've experience battereis with a bad cell start engines, >and then just die on the spot. > >What are the "modes" on your multimeter that you are using? > >We are here to help. Just keep the communication coming. > >Curt Sprenger >1987 PT38 8V92 "MacAttack Racing" >Anaheim Hills, Calif. > > > >Scott Forman wrote: > > > the gen batt read 12.1 before I started it, 12.4 after it was > > running. I know that by the book 12.1v is a half-dead battery, but > > it cranks awfully strong to be half dead. And the 12.4 isn't as high > > as it should be, but since it is higher there is obviously some > > charge getting to it...ideas? > > > > Another note...my multimeter has two "modes" that I don't really > > understand. When I turn the dial to one setting, it read 12.4 with > > generator running, on the other setting it read 26.5. Any idea what > > this other mode is showing me? > > > > Much confusions over here > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx 12.6 > > volts is > > > good. Battery receiving a charge, 13.4+ volts...unless you have the > > > smart chargers that are in the sleep mode. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Scott Forman wrote: > > > > > > > And what voltage should it show when charging? > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > conditions, > > > > > check with the shore power, then generator running , then the > > > > engine > > > > > alternator running and charging. > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > <sforman@> > > > > > wrote: > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > Curt Sprenger > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I guess > > the > > > > > > circuit > > > > > > > > works. > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > Have you used your multimeter and checked the voltage at > > > > the > > > > > > gen. > > > > > > > > > battery? First before you start the gen. Than again > > after > > > > the > > > > > > gen. > > > > > > > > is > > > > > > > > > running. The increase in voltage when the gen. is > > running > > > > > tells > > > > > > > > you > > > > > > > > > that the charge circuit is working. No change in > > voltage, or > > > > > > > > lower, > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide ranging > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am just > > trying > > > > > to > > > > > > learn > > > > > > > > > > my new coach. I knew my old FC inside and out, and > > that > > > > > gave > > > > > > me > > > > > > > > some > > > > > > > > > > confidence that if I ever had a problem on the road, > > > > maybe > > > > > I > > > > > > could > > > > > > > > > > diagnose it & fix it. I want to feel that way about my > > > > PT, > > > > > > too. I > > > > > > > > > > also want to make sure that the charging circuit is > > > > > charging > > > > > > the > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > May I be so bold as to ask what is your problem? > > > > > > > > > > > Howard Truitt > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt solenoid > > on > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. There's > > one > > > > on > > > > > the > > > > > > > > front > > > > > > > > > > > > wall of the batter charger compartment. There are > > two > > > > > > others > > > > > > > > on > > > > > > > > > > the > > > > > > > > > > > > metal panel that folds down to give access to the > > > > > charger > > > > > > > > > > > > compartment. And there are three of them behind > > the > > > > > step > > > > > > well, > > > > > > > > > > > > although it looks like two of them are for the > > > > leveling > > > > > > pump. > > > > > > > > > > None > > > > > > > > > > > > of these make the audible "click" when I hit the > > Aux > > > > > Batt > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > comprehensive > > > > as > > > > > > they > > > > > > > > were > > > > > > > > > > in > > > > > > > > > > > > my FC, so I am having trouble figuring all this > > out. > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment with > > the > > > > > > chargers. > > > > > > > > But > > > > > > > > > > > > knowing BB and your coach being a 38 footer it > > may be > > > > > > > > different. > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt solenoid > > on > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery solenoid on a > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > |
05-27-2007, 15:11
Post: #30
I wish I could give you a clear technical answer. I've experienced the
same as you have. I've learned to set the multimeter to either DC or AC depending on the need. Others on the forum will chime in and give a good explanation. We, us on this forum, are learning together. I'm not an expert, but don't mind sharing what I have used or done working with DC, or AC as well. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > OK...why does a 12v DC battery show AC voltage? > > I used to think I understood vehicle electrical systems.... > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Dots + DC Volts. Wavy line + AC Volts. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Scott Forman wrote: > > > > > The modes are marked by a V followd by 3 dots in one mode and a V > > > with a wavy line for the other. Doesn't help much, huh? > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > Scott, > > > > > > > > A bad battery could cause the 12.4 reading. Remove the battery, > > > take it > > > > to an auto parts store, have them load test it. Could be a bad > cell > > > in > > > > the battery. I've experience battereis with a bad cell start > > > engines, > > > > and then just die on the spot. > > > > > > > > What are the "modes" on your multimeter that you are using? > > > > > > > > We are here to help. Just keep the communication coming. > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > the gen batt read 12.1 before I started it, 12.4 after it was > > > > > running. I know that by the book 12.1v is a half-dead > battery, but > > > > > it cranks awfully strong to be half dead. And the 12.4 isn't > as > > > high > > > > > as it should be, but since it is higher there is obviously > some > > > > > charge getting to it...ideas? > > > > > > > > > > Another note...my multimeter has two "modes" that I don't > really > > > > > understand. When I turn the dial to one setting, it read 12.4 > with > > > > > generator running, on the other setting it read 26.5. Any idea > > > what > > > > > this other mode is showing me? > > > > > > > > > > Much confusions over here > > > > > > > > > > Scott > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > Battery with no charge to it for about 20 minutes, approx > 12.6 > > > > > volts is > > > > > > good. Battery receiving a charge, 13.4+ volts...unless you > have > > > the > > > > > > smart chargers that are in the sleep mode. > > > > > > > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > And what voltage should it show when charging? > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > TO be assured that the gen battery is charging under all > > > > > > > conditions, > > > > > > > > check with the shore power, then generator running , > then > > > the > > > > > > > engine > > > > > > > > alternator running and charging. > > > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > Forman" > > > > > <sforman@> > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > Isn't it all one circuit? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Agree. Good. > > > > > > > > > > > > > > > > > > > > Do the same test using shore power. > > > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > > > OK, the voltage went up with the gen running. So I > > > guess > > > > > the > > > > > > > > > circuit > > > > > > > > > > > works. > > > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Sprenger > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > Have you used your multimeter and checked the > > > voltage at > > > > > > > the > > > > > > > > > gen. > > > > > > > > > > > > battery? First before you start the gen. Than > again > > > > > after > > > > > > > the > > > > > > > > > gen. > > > > > > > > > > > is > > > > > > > > > > > > running. The increase in voltage when the gen. > is > > > > > running > > > > > > > > tells > > > > > > > > > > > you > > > > > > > > > > > > that the charge circuit is working. No change in > > > > > voltage, or > > > > > > > > > > > lower, > > > > > > > > > > > > you know the charge is not working. > > > > > > > > > > > > > > > > > > > > > > > > Curt Sprenger > > > > > > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman wrote: > > > > > > > > > > > > > > > > > > > > > > > > > Hmmm..."what is your problem"...there's a wide > > > ranging > > > > > > > > > > > question.... > > > > > > > > > > > > > > > > > > > > > > > > > > Really I don't have a problem right now. I am > just > > > > > trying > > > > > > > > to > > > > > > > > > learn > > > > > > > > > > > > > my new coach. I knew my old FC inside and > out, and > > > > > that > > > > > > > > gave > > > > > > > > > me > > > > > > > > > > > some > > > > > > > > > > > > > confidence that if I ever had a problem on the > > > road, > > > > > > > maybe > > > > > > > > I > > > > > > > > > could > > > > > > > > > > > > > diagnose it & fix it. I want to feel that way > > > about my > > > > > > > PT, > > > > > > > > > too. I > > > > > > > > > > > > > also want to make sure that the charging > circuit > > > is > > > > > > > > charging > > > > > > > > > the > > > > > > > > > > > > > generator battery as it is supposed to. > > > > > > > > > > > > > > > > > > > > > > > > > > Scott > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > > May I be so bold as to ask what is your > problem? > > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 08:17:02 EDT > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Re: Aux Batt > > > solenoid > > > > > on > > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > OK...a little help... > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > There are solenoids all over the place. > > > There's > > > > > one > > > > > > > on > > > > > > > > the > > > > > > > > > > > front > > > > > > > > > > > > > > > wall of the batter charger compartment. > There > > > are > > > > > two > > > > > > > > > others > > > > > > > > > > > on > > > > > > > > > > > > > the > > > > > > > > > > > > > > > metal panel that folds down to give > access to > > > the > > > > > > > > charger > > > > > > > > > > > > > > > compartment. And there are three of them > > > behind > > > > > the > > > > > > > > step > > > > > > > > > well, > > > > > > > > > > > > > > > although it looks like two of them are > for the > > > > > > > leveling > > > > > > > > > pump. > > > > > > > > > > > > > None > > > > > > > > > > > > > > > of these make the audible "click" when I > hit > > > the > > > > > Aux > > > > > > > > Batt > > > > > > > > > > > > > switch. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > The drawings in my Blue Box aren't as > > > > > comprehensive > > > > > > > as > > > > > > > > > they > > > > > > > > > > > were > > > > > > > > > > > > > in > > > > > > > > > > > > > > > my FC, so I am having trouble figuring all > > > this > > > > > out. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Help! > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > > > > > > > On my 86 PT40 mine is in the compartment > > > with > > > > > the > > > > > > > > > chargers. > > > > > > > > > > > But > > > > > > > > > > > > > > > knowing BB and your coach being a 38 > footer it > > > > > may be > > > > > > > > > > > different. > > > > > > > > > > > > > > > > Howard Truitt > > > > > > > > > > > > > > > > Camilla, Ga. > > > > > > > > > > > > > > > > 86 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > From: "Scott Forman" <sforman@> > > > > > > > > > > > > > > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Subject: [WanderlodgeForum] Aux Batt > > > solenoid > > > > > on > > > > > > > PT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Where is the auxillary battery > solenoid > > > on a > > > > > PT? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Scott Forman > > > > > > > > > > > > > > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
