88 pt 40 how many alternators?
12-10-2007, 09:37
Post: #21
Thanks Rob, will do. I will check them out.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Rob Robinson assume you are aware of the compressor coolant lines issue and the need to check them for aging. Some of them have literally fallen apart when subjected to relatively gentle tugs. Do a search on both Wanderlodge sites for previous posts and fixes. On 10/12/2007, Leroy Eckert > > If that was for me I haven't messed with my air compressor. If it is in > the rear area of the engine then I presume so. The access hole allows me to > access the generator, exhaust pipe, belts and other things on the top rear > of the engine. > Is there something I should be doing to the air compressor. I haven't had > any problems, yet...??? > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > ciao70@... > does the, under the bed access door for the > alternator, also give you access to the air compressor? Jim Barone > 1991WLWB > > **************************************Check out AOL's list of 2007's > hottest > products. > (http://money.aol.com/special/hot-product...0000000001) > > [Non-text portions of this message have been removed] > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] |
12-10-2007, 09:44
Post: #22
In my coach you can't get to the alternator thru the bedroom. There is room to
climb in from the curbside however. Also in my coach the is no switch for alt 1 and 2. Jim Leroy Eckert Thanks Rob, will do. I will check them out. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Rob Robinson compressor coolant lines issue and the need to check them for aging. Some of them have literally fallen apart when subjected to relatively gentle tugs. Do a search on both Wanderlodge sites for previous posts and fixes. On 10/12/2007, Leroy Eckert > > If that was for me I haven't messed with my air compressor. If it is in > the rear area of the engine then I presume so. The access hole allows me to > access the generator, exhaust pipe, belts and other things on the top rear > of the engine. > Is there something I should be doing to the air compressor. I haven't had > any problems, yet...??? > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > ciao70@... > does the, under the bed access door for the > alternator, also give you access to the air compressor? Jim Barone > 1991WLWB > > **************************************Check out AOL's list of 2007's > hottest > products. > (http://money.aol.com/special/hot-product...0000000001) > > [Non-text portions of this message have been removed] > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
