Dash AC / Sight glass
05-29-2005, 23:50
Post: #21
Hi Jay,
Yes, I replaced the rooftop condenser with a new one from Acme
radiator and A/C. Ran around $350. Is larger and does a great job.
Flushed and pulled the whole system down to a full zero. Since I can
recover, filter and reuse, I'll probably replace the dryer and old
compressor after the summer. The R-134A is much harder on rubber in
the system. There is talk of something better than R-134A coming
down the pike, but don't know what it is yet. It is supposed to be
more compatible and work at lower pressures than the R-134A.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
> Shane,
> When I switched the dash a/c over to 134, only "hardware" update
was
> a new expansion valve.
> Pulled a vacuum on it for a while, then filled system with 38oz of
> R134. Works like a champ!
> 5 pounds is a lot more than what I used. Did you repace the roof
top
> condenser with something larger?
> Jay Darst
> 85PT40
> SpringfieldIL
05-29-2005, 23:53
Post: #22
Hi Curt,
The oil w/dye gets metered in automatically by the machine that I
used. Probably went through around 10 oz. Used between a 4 and 5 lbs.
of R-134A. Prior to charging, the system was pulled down to zero
atmospheres, so there was absolutely nothing in there to start with.
Shane Fedeli
85PT40
Hershey, PA
> Shane,
> How much 134-a and how much oil?
> Curt Sprenger `87PT38, Anaheim, Calif.
05-30-2005, 00:05
Post: #23
http://www.duracool.com
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@c...>
> Hi Jay,
can
in
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Shane,
> was
of
> top
> > Jay Darst
> > 85PT40
> > SpringfieldIL
05-30-2005, 03:55
Post: #24
Has anyone had experience with the DuraCool product?
From the website that Stephen Birtles listed in this thread, it
appears to be a working solution to the R134 refrigerant.
If anyone has experience or first hand information about this
product, I would greatly appreciate hearing about it.
I have heard and read about the corrosive properties of R134. Too
much stuff at risk if there is an alternative!
Thanks!
Jay Darst
85PT40
SpringfieldIL
> Stephen 77fc35
<sfedeli3@c...>
> > Hi Jay,
Acme
job.
> can
old
> in
be
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> > wrote:
> > > Shane,
update
> > was
38oz
> of
roof
> > top
> > > Jay Darst
> > > 85PT40
> > > SpringfieldIL
05-30-2005, 04:18
Post: #25
I think the best bet is to give them acal and ask for some references
I plan on using duracool in my system but right now working on bigger
things before resurrecting the air
Stephen 77fc35
> Thanks!
> Jay Darst
> 85PT40
> SpringfieldIL
> > Stephen 77fc35
> <sfedeli3@c...>
> > wrote:
> > > Hi Jay,
> Acme
> job.
> > can
> old
> > in
> be
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
> > > wrote:
> > > > Shane,
> update
> > > was
> 38oz
> > of
> roof
> > > top
> > > > Jay Darst
> > > > 85PT40
> > > > SpringfieldIL
