Locking Tag Axle Tire
06-09-2005, 14:08
Post: #21
it must! sure cleans it all up,as far as stuff being in the way! but,i guess
there is a few problems with some of that stuff,even though the DD's have had a common rail for 50 years,,randydupree93wb ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 9:51 PM Subject: [WanderlodgeForum] Re: Locking Tag Axle Tire Yeah port-effect on the 3208 sure leads to equal-length fuel lines. Do you think that common-rail injection makes it a bit simpler? - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree > its all about timing jeff! uneven length hoses can cause a brake to pull. hydraulic brakes can have unequal length lines with no problem..but have you ever noticed on a 3208 diesel engine the injector lines are all bent and twisted and seem too long? they are realy equal length,all 8 lines the same,thats so the timing is right on all cyl's..but,you know all that stuff already! randydupree93wb ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 14:10
Post: #22
well,they were a customer of mine,before they went by-by! it pays to know a
little about the coach.hell,i've forgotten most of it by now,they closed up 10 years ago...randydupree93wb ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 9:54 PM Subject: [WanderlodgeForum] Re: Locking Tag Axle Tire Telling the Eagle 10 from the Eagle 15 made easy eh Randy? The bogie wheels in front of the drive look so , ... different? I was always amused by the 96" front cap on the 102" wide Eagle 10 also. Still, a really nice-riding bus, if you can find one that isn't rusty and source the parts (after Eagle went "out of business" twice, ...). - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > and another bit of trivia for you.a extra axle behind the drive axle is a tag axle,when the extra axle is in front of the drive axle its called a boogie axle.only the very newest eagles have a tag axle,and i think they went to air ride also,at the very end of production..randydupree93wb > ----- Original Message ----- > From: Jeff Miller > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 09, 2005 9:16 PM > Subject: [WanderlodgeForum] Re: Locking Tag Axle Tire > > > Although a thoughtful response, apples to oranges. Eagles don't have > airbag suspension, they are torsion bar, therefore asymmetrical tag- > axle pressures are more likely to cause this problem. > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Sevey & Carolyn > Sevey" > > -Hi All > > Just a thought, on Eagle buses if the suspension system is loading > > the tag axle too lightly the light wheel will lock up all the time. > > Could your leveling valve be loading that wheel too lightly? > > Dick & Carolyn Sevey 83fc 33 Pahrump, Nv. > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 15:06
Post: #23
The "port effect" in diesel injection (ex: 3208) is due to the metal
lines stretching and contracting delaying the injection pulse (like water in a hose in an old Bugs Bunny cartoon), where in air brake lines the delay is due to the compressed air pulse traveling along the lines and the inertia of the air. You are correct Day that eventually the pressure will be the same at all points in the line, but line lengths and diameters will affect the time that this pressure takes to reach the brake chamber at the end of the line. Twice the line length will take roughly twice as long, just like sound waves. This was one of the factors I had to take into consideration when designing an air-brake system for the Futurliner thanks largely to a generous donation from Bendix Brake. Since the air leaves the relay valve and is split at the valve into the two lines, the air pressure will also take the path of least resistance (lower pressure) which can also cause one brake to get a larger force momentarily due to a restriction, once the wheel stops then inertia and the difference between dynamic friction and static friction can retain the locked condition. Have to consider all possibilities when asessing a problem, I'm still thinking it's a mechanical problem though and hope he posts the solution/findings. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > THE LENGTH ON THE INJECTOR LINES ARE PRECISE DUE TO THE TIMING FOR THE > FUEL TO BE INJECTED INTO THE CYLINDER AT A PRECISE TIME. (WHICH OF COURSE YOU > KNEW) > THE LENGTH OF THE AIR LINES ARE NOT PRECISE FOR "TIMING" BECAUSE AIR > PRESSURE SHOULD BE EQUAL THROUGHOUT THE LENGTH OF THE LINES. ALL BRAKES ARE > SUPPOSED TO APPLY AT THE SAME TIME. THE LEFT SIDE DOES NOT APPLY BEFORE THE > RIGHT SIDE. THE AIR PRESSURE WILL BE THE SAME AT ALL POINTS THROUGHOUT THE LINE. > IF A DIFFERENCE DOES OCCUR, IT WILL BE DUE TO OBSTRUCTIONS, RESTRICTIONS, OR > SOME OTHER PROBLEM. DAY JAX FLA 83 PT-40. > > > [Non-text portions of this message have been removed] |
06-09-2005, 15:39
Post: #24
At 6/10/2005 08:54 AM, Jeff Miller wrote:
>Telling the Eagle 10 from the Eagle 15 made easy eh Randy? The bogie >wheels in front of the drive look so , ... different? I was always >amused by the 96" front cap on the 102" wide Eagle 10 also. > >--- In WanderlodgeForum@yahoogroups.com, randydupree >wrote: > > and another bit of trivia for you.a extra axle behind the drive >axle is a tag axle,when the extra axle is in front of the drive axle >its called a boogie axle.only the very newest eagles have a tag >axle,and i think they went to air ride also,at the very end of >production..randydupree93wb The Model 01 Eagles had the tag axle trailing. The Model 05, introduced mid- to late-60s, swapped the axles around. As far as I was aware, all 3-axle Eagles from the Model 05 through the 20 had the same axle order. Was the reversion to the trailing tag axle a part of the production by the re-incarnated company? Also, I think the only common 102" wide Eagle was the Model 15. -- Dennis Nichols, been there, driven that '88 WB40 XXV "Priscilla" -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.323 / Virus Database: 267.6.6 - Release Date: 6/8/2005 |
06-09-2005, 23:17
Post: #25
ohh boy! depends on wether it had round tail lights,or square,then you need to
know if it was built before 1970,or after.all of this depends on if its really an eagle,or a converted coach,those converters can make $300,000 look just like an eagle. its hard to tell just what year it is,,randydupree93wb ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 10:48 PM Subject: Re: [WanderlodgeForum] Re: Locking Tag Axle Tire on our way to the rally here in sanger, we saw an eagle with the tag in front of the drivers. what age would this coach be? ernie-83pt40 in texas [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 23:21
Post: #26
very good post ,jeff ,thanks for explaining so that we could understand
it!.which futureliner did you work on? cool old bus! randydupree93wb ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 11:06 PM Subject: [WanderlodgeForum] Re: Locking Tag Axle Tire The "port effect" in diesel injection (ex: 3208) is due to the metal lines stretching and contracting delaying the injection pulse (like water in a hose in an old Bugs Bunny cartoon), where in air brake lines the delay is due to the compressed air pulse traveling along the lines and the inertia of the air. You are correct Day that eventually the pressure will be the same at all points in the line, but line lengths and diameters will affect the time that this pressure takes to reach the brake chamber at the end of the line. Twice the line length will take roughly twice as long, just like sound waves. This was one of the factors I had to take into consideration when designing an air-brake system for the Futurliner thanks largely to a generous donation from Bendix Brake. Since the air leaves the relay valve and is split at the valve into the two lines, the air pressure will also take the path of least resistance (lower pressure) which can also cause one brake to get a larger force momentarily due to a restriction, once the wheel stops then inertia and the difference between dynamic friction and static friction can retain the locked condition. Have to consider all possibilities when asessing a problem, I'm still thinking it's a mechanical problem though and hope he posts the solution/findings. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > THE LENGTH ON THE INJECTOR LINES ARE PRECISE DUE TO THE TIMING FOR THE > FUEL TO BE INJECTED INTO THE CYLINDER AT A PRECISE TIME. (WHICH OF COURSE YOU > KNEW) > THE LENGTH OF THE AIR LINES ARE NOT PRECISE FOR "TIMING" BECAUSE AIR > PRESSURE SHOULD BE EQUAL THROUGHOUT THE LENGTH OF THE LINES. ALL BRAKES ARE > SUPPOSED TO APPLY AT THE SAME TIME. THE LEFT SIDE DOES NOT APPLY BEFORE THE > RIGHT SIDE. THE AIR PRESSURE WILL BE THE SAME AT ALL POINTS THROUGHOUT THE LINE. > IF A DIFFERENCE DOES OCCUR, IT WILL BE DUE TO OBSTRUCTIONS, RESTRICTIONS, OR > SOME OTHER PROBLEM. DAY JAX FLA 83 PT-40. > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 23:28
Post: #27
dennis,the very newest eagles had a tag axle,i don't know how many were
built,but at least one was completed.i saw it at a bus show (not a motorhome show) somewhere.i think eagle was trying to get into the conversion shell market,with a pupose built shell. randydupree93wb ----- Original Message ----- From: Dennis Nichols To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 11:39 PM Subject: Re: [WanderlodgeForum] Re: Locking Tag Axle Tire At 6/10/2005 08:54 AM, Jeff Miller wrote: >Telling the Eagle 10 from the Eagle 15 made easy eh Randy? The bogie >wheels in front of the drive look so , ... different? I was always >amused by the 96" front cap on the 102" wide Eagle 10 also. > >--- In WanderlodgeForum@yahoogroups.com, randydupree >wrote: > > and another bit of trivia for you.a extra axle behind the drive >axle is a tag axle,when the extra axle is in front of the drive axle >its called a boogie axle.only the very newest eagles have a tag >axle,and i think they went to air ride also,at the very end of >production..randydupree93wb The Model 01 Eagles had the tag axle trailing. The Model 05, introduced mid- to late-60s, swapped the axles around. As far as I was aware, all 3-axle Eagles from the Model 05 through the 20 had the same axle order. Was the reversion to the trailing tag axle a part of the production by the re-incarnated company? Also, I think the only common 102" wide Eagle was the Model 15. -- Dennis Nichols, been there, driven that '88 WB40 XXV "Priscilla" -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.323 / Virus Database: 267.6.6 - Release Date: 6/8/2005 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-10-2005, 01:07
Post: #28
It might be prudent to get the brake schematic from your bluebox and
have a look or better still take an air brake course to understand the inner workings or air brakes Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > Say guys,,, would this be ok for you?? I can see the letters, and > still use lower case for you !! > One question,, where does the brake "air pulse" start? at the brake > pedal? Or does that control another brake control system that sends out the > compressed air? Seems the rear brakes get their air from the rear air tanks, and the > front from the front ones. Does it go all the way to the front pedal, and > then back to the rear wheels?? > I have never thought about how that works. Might be something good to > know,,, DAY JAX FLA 83 PT-40 > > > [Non-text portions of this message have been removed] |
06-10-2005, 01:08
Post: #29
To reduce the lag-time (delay) from pedal (treadle) to brake there is
a relay valve near the center of each braked axle. Usually centered to maintain equal-length brake lines, this relay valve takes a small control pressure from the treadle valve (pedal) and opens the relay valve proportionally to let a large amount of air through from the local tanks and large supply lines. So the simple version is that the actual braking air pressure needs only to travel from the local air tank through the relay valve to the brake chambers, ... not the length of the coach. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > Say guys,,, would this be ok for you?? I can see the letters, and > still use lower case for you !! > One question,, where does the brake "air pulse" start? at the brake > pedal? Or does that control another brake control system that sends out the > compressed air? Seems the rear brakes get their air from the rear air tanks, and the > front from the front ones. Does it go all the way to the front pedal, and > then back to the rear wheels?? > I have never thought about how that works. Might be something good to > know,,, DAY JAX FLA 83 PT-40 > > > [Non-text portions of this message have been removed] |
06-10-2005, 12:41
Post: #30
Thanks,,, I have been wondering how that system worked. It didn't
seem logical that the air was coming to the front and then to the back. Thanks ,, DAY JAX, FLA 83 PT-40 [Non-text portions of this message have been removed] |
