Neutral safty switch
11-07-2011, 09:42
Post: #21
I can't find the key that turns the back switch. I this k the front key is the one bit don't want to brake the key off in the switch. Do you think I could spay WD40 inside and not hurt it.
Connected by DROID on Verizon Wireless -----Original message-----
11-07-2011, 11:25
Post: #22
On my 1985 PT40 the remote start used a different key than the front ignition.
Wayne kotila
96PT42
From: "wlb52@..." To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 7, 2011 3:42 PM Subject: Re: [WanderlodgeForum] Re: Neutral safty switch I can't find the key that turns the back switch. I this k the front key is the one bit don't want to brake the key off in the switch. Do you think I could spay WD40 inside and not hurt it.
11-08-2011, 00:39
Post: #23
Like Ralph said- change out the toggle switch in the engine compartment. Be sure
to use a 30 AMP DPDT switch, not the usual 20-AMP junk that you commonly find at Wal-Mart. Also, if there are any splices in the small box, open the splice connections and check for corrosion. Mine would not start at AZ earlier this fall and it was a corroded switch along with a corroded splice. Try and use the adhesive-lined heat shrink butt connectors and ring terminals when you rewire the switch. That should keep the moisture out! You might also coat the new switch terminals with a nice helping of di-electric grease to postpone corrosion on the screw connectors. Since replacing the switch, my coach starter "hits" within a millisecond of turning the key. There used to be a delay of a few seconds or so. The neutral safety switches rarely fail in the Morse shifter. If they get weak, you can clean the little ball and spring assembly to assure better contact. Shane Fedeli 1985PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "artw" > > I have had the same continueing problem with my PT36 (still having it). > If the batteries are not fully charged it will not start from the drivers position. I am able to start from the rear. I leave the drivers key in the 'on' position, start the coach from thr rear, move to toggle to'front' and turn rear key to 'off'. > > I had my son stand at the rear to listen for a solenoid click. He heard nothing when I turned the the in front. > > I have been trouble-shooting the problem for two years. I'm thinking that I have a corroded pin in one of the cannon plugs. Thought I found it once but oh no, the symtom reappearred. > > Always starts fine when Batts. are fully charged. > > > Art Weatherly > Riverside Ca > '85 PT36 > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > Nope the one on the right down under by the right knee is the 12vdc master. Am not talking about that. The AT is centered on the lower upper dash, sort of hidden by the steer wheel > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "wlb52@" > > Sender: > |
11-08-2011, 04:02
Post: #24
I know this sounds simple but I fought this problem on one of my PTs for a
while. Check the positive connection on the starter for cleanliness and tightness. Also clean the large battery cable connection where it attaches to the starter and check the tightness of the crimp on the cable. Oil can get on the connection and these engines vibrate and things can get loose. Worked for me. Mike McMahan 96 42' Wanderlodge --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Like Ralph said- change out the toggle switch in the engine compartment. Be sure to use a 30 AMP DPDT switch, not the usual 20-AMP junk that you commonly find at Wal-Mart. Also, if there are any splices in the small box, open the splice connections and check for corrosion. Mine would not start at AZ earlier this fall and it was a corroded switch along with a corroded splice. Try and use the adhesive-lined heat shrink butt connectors and ring terminals when you rewire the switch. That should keep the moisture out! You might also coat the new switch terminals with a nice helping of di-electric grease to postpone corrosion on the screw connectors. Since replacing the switch, my coach starter "hits" within a millisecond of turning the key. There used to be a delay of a few seconds or so. The neutral safety switches rarely fail in the Morse shifter. If they get weak, you can clean the little ball and spring assembly to assure better contact. > > Shane Fedeli > 1985PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "artw" > > > > I have had the same continueing problem with my PT36 (still having it). > > If the batteries are not fully charged it will not start from the drivers position. I am able to start from the rear. I leave the drivers key in the 'on' position, start the coach from thr rear, move to toggle to'front' and turn rear key to 'off'. > > > > I had my son stand at the rear to listen for a solenoid click. He heard nothing when I turned the the in front. > > > > I have been trouble-shooting the problem for two years. I'm thinking that I have a corroded pin in one of the cannon plugs. Thought I found it once but oh no, the symtom reappearred. > > > > Always starts fine when Batts. are fully charged. > > > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > > > Nope the one on the right down under by the right knee is the 12vdc master. Am not talking about that. The AT is centered on the lower upper dash, sort of hidden by the steer wheel > > > Safe travels, Ralph & Charolette Fullenwider > > > '84 FC35 "Ruff Diamond" > > > Duncan, Oklahoma > > > Sent via BlackBerry by AT&T > > > > > > -----Original Message----- > > > From: "wlb52@" > > > Sender: > > > |
11-09-2011, 11:37
Post: #25
I just ran into this problem today. I went to start the engine and the key did
nothing. My heart stopped for a minute then I remembered reading this string. I went to the back of the bus inserted the key toggled the switch from front" to "rear" turn the key and it started right up. I ran it for about 5 minute and shut it down. toggled the switch back to "front". I then inserted the key up front and it started. Not sure what the issue was, maybe just being temperamental today. Jerry Kocher 1987 PT38 San Francisco, CA --- In WanderlodgeForum@yahoogroups.com, "artw" > > I have had the same continueing problem with my PT36 (still having it). > If the batteries are not fully charged it will not start from the drivers position. I am able to start from the rear. I leave the drivers key in the 'on' position, start the coach from thr rear, move to toggle to'front' and turn rear key to 'off'. > > I had my son stand at the rear to listen for a solenoid click. He heard nothing when I turned the the in front. > > I have been trouble-shooting the problem for two years. I'm thinking that I have a corroded pin in one of the cannon plugs. Thought I found it once but oh no, the symtom reappearred. > > Always starts fine when Batts. are fully charged. > > > Art Weatherly > Riverside Ca > '85 PT36 > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > Nope the one on the right down under by the right knee is the 12vdc master. Am not talking about that. The AT is centered on the lower upper dash, sort of hidden by the steer wheel > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "wlb52@" > > Sender: > |
11-09-2011, 11:55
Post: #26
Dose your bird use the same key up front as in the back switch
11-09-2011, 13:19
Post: #27
Yes, it uses the same key.
Jerry Kocher 1987 PT38 San Francisco, CA --- In WanderlodgeForum@yahoogroups.com, "wlb52@..." > > Dose your bird use the same key up front as in the back switch > > Connected by DROID on Verizon Wireless > > -----Original message----- > From: jerry_94110 > To: WanderlodgeForum@yahoogroups.com > Sent: Wed, Nov 9, 2011 23:37:05 GMT+00:00 > Subject: [WanderlodgeForum] Re: Neutral safty switch > > > > > I just ran into this problem today. I went to start the engine and the key > did nothing. My heart stopped for a minute then I remembered reading this > string. I went to the back of the bus inserted the key toggled the switch > from front" to "rear" turn the key and it started right up. I ran it for > about 5 minute and shut it down. toggled the switch back to "front". I then > inserted the key up front and it started. Not sure what the issue was, maybe > just being temperamental today. > > Jerry Kocher > 1987 PT38 > San Francisco, CA > > --- In WanderlodgeForum@yahoogroups.com, "artw" > > > > I have had the same continueing problem with my PT36 (still having it). > > If the batteries are not fully charged it will not start from the drivers > position. I am able to start from the rear. I leave the drivers key in the > 'on' position, start the coach from thr rear, move to toggle to'front' and > turn rear key to 'off'. > > > > I had my son stand at the rear to listen for a solenoid click. He heard > nothing when I turned the the in front. > > > > I have been trouble-shooting the problem for two years. I'm thinking that > I have a corroded pin in one of the cannon plugs. Thought I found it once > but oh no, the symtom reappearred. > > > > Always starts fine when Batts. are fully charged. > > > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > > > Nope the one on the right down under by the right knee is the 12vdc > master. Am not talking about that. The AT is centered on the lower upper > dash, sort of hidden by the steer wheel > > > Safe travels, Ralph & > Charolette Fullenwider > > > '84 FC35 "Ruff Diamond" > > > Duncan, Oklahoma > > > Sent via BlackBerry by AT&T > > > > > > -----Original Message----- > > > From: "wlb52@" > > > Sender: > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
11-10-2011, 02:37
Post: #28
I know Shane had the same problem and he replaced the switch at the rear of the coach.Â
On 9 November 2011 17:19, jerry_94110 <"gerard@kocher.com"> wrote:
11-12-2011, 07:59
Post: #29
It was the AT switch it got flipped to the right. I looked for it and didn't see it till now flipped it to the left and it turned o er and started right up. Dam now I have to put it all back together. Thanks everyone for there help. BILL
11-12-2011, 08:04
Post: #30
That A/T switch is a sneaky lil devil!
Fred & Jeanne Hulse Morristown,Arizona 97 WLWB41 |
