Neutral safty switch
11-12-2011, 08:24
Post: #31
Glad you found the easy fix. If you helps, don't think you are the only one
that has had this happen. I would guess it has happened to close to all BB
owners - some of us more than once! 8-(
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "wlb52@..." wrote:
> It was the AT switch it got flipped to the right. I looked for it and didn't
see it till now flipped it to the left and it turned o er and started right up.
Dam now I have to put it all back together. Thanks everyone for there help.
BILL
> Connected by DROID on Verizon Wireless
> -----Original message-----
> From: Don Bradner
> Sent: Mon, Nov 7, 2011 01:00:55 GMT+00:00
> Subject: Re: [WanderlodgeForum] Neutral safty switch
> AT is anti-theft. Simple way to make sure the coach can't be started, but a
b**** when you don't know it got switched!
> On 11/6/2011 at 7:52 PM wlb52@... wrote:
> >What is the at switch. I will go out and see if I can find it
> Connected
> From: Ralph
> To: Wanderlodge Forum
> Sent: Mon, Nov 7, 2011 00:13:24
> >GMT+00:00
> Rarely.
> >Ahh let's try one more thing quickly. Sit in the drivers seat. On the
> >lower up dash, find a switch labeled AT. Be sure it is switched to the
> >left. If right then switch it and start
> Safe travels,
> > Ralph & Charolette Fullenwider
> '84 FC35
> >"Ruff Diamond"
> Duncan, Oklahoma
> Sent via BlackBerry by AT&T
> -----Original
> >Message-----
> From: "wlb52@..."
> Sender:
> Date: Sun, 6 Nov 2011 19:01:59
> To:
> Reply-To:
> >safty switch
> I try flipping the toggle switch from front to back four or
> >five times and it didn't start. I'm trying to find the key for the back
> >start spot. Do you think it could be the front key switch
> Connected by
> From: Wayne Kotila
> To: "WanderlodgeForum@yahoogroups.com"
> Sent: Sun, Nov 6, 2011 23:41:31
> >GMT+00:00
> On my
> >former coach (1985 PT40) I had your same symptoms a few times caused by
> >two different things. The switch for remote start back in the engine
> >compartment apparently had bad contact points, it would act
> >up��occasionaly and If I flipped it from front to rear and back
a��few
> >times the coach would��then start. I replaced the switch after this
> >happened a couple of times and that eliminated that problem. Another time
> >I had the exact same symptoms, hit the key,��it did not crank the engine
> >over and the starter made no noise. That time it turned out to be a jammed
> >(stuck starter), the starter was pulled and the drive gear on the starter
> >was easily freed up and the starter put back on, it never got stuck
> >again.
> Good Luck
> Wayne
> >Kotila
> 96PT42����
> ________________________________
> From:
> >"wlb52@..."
> To:
> Sent: Saturday, November 5, 2011 7:06
> >PM
> Got to the
> >neutral salty switch cut the two wires put them together and no start.
> >Anyone no of anything it could be short of the starter. It dose not make a
> >sound so I think its not the starter.�� Thanks.���� Bill
> Connected by
> From: Ralph
> >Sent: Fri, Nov 4, 2011 20:18:46
> >GMT+00:00
> >switch
> >Attached the bottom of the shifter mechanism
> >Safe travels,
> >Ralph Charolette Fullenwider
> >'84 FC35 "Ruff Diamond"
> >Duncan,
> >Oklahoma
> >-----Original Message-----
> >From:
> >"William B"
> >Sender: WanderlodgeForum@yahoogroups.com
> >Date: Fri, 04 Nov
> >2011 19:30:51
> >To:
> >Reply-To: WanderlodgeForum@yahoogroups.com
> >Subject:
> >I have a 1985 pt 40 that
> >started one day and the next day I get no sound out of the starter. I
> >think it may be the neutral safty switch but I can not find it. I looked
> >on the trans and I didn't see dose anyone know where it would be
> >located
> >Yahoo! Groups
> >Links
> >Yahoo! Groups
> >Links
> >*> To visit your group on the web, go
> >to:
> >http://groups.yahoo.com/group/WanderlodgeForum/
> >*> Your email
> >settings:
> >Individual Email | Traditional
> >*> To change settings online
> >go to:
> >http://groups.yahoo.com/group/WanderlodgeForum/join
> >(Yahoo! ID
> >required)
> >*> To change settings via
> >email:
> >WanderlodgeForum-digest@yahoogroups.com
> >WanderlodgeForum-fullfeatured@yahoogroups.com
> >*> To unsubscribe from
> >this group, send an email
> >to:
> >WanderlodgeForum-unsubscribe@yahoogroups.com
> >*> Your use of Yahoo!
> >Groups is subject to:
> >http://docs.yahoo.com/info/terms/
> Yahoo! Groups Links
11-12-2011, 08:27
Post: #32
Uh, that should be "if it helps" - if I could type! LOL
> Mike Bulriss
> San Antonio, TX
BILL
> > From: Don Bradner
> > Connected
> > From: Ralph
> > >GMT+00:00
> > Rarely.
> > Safe travels,
> > '84 FC35
> > >"Ruff Diamond"
> > Duncan, Oklahoma
> > -----Original
> > >Message-----
> > From: "wlb52@"
> > Sender:
> > To:
> > Reply-To:
> > >safty switch
> > Connected by
> > From: Wayne Kotila
> > >GMT+00:00
> > On my
a��few
engine
> > >again.
> > Good Luck
> > Wayne
> > >Kotila
> > 96PT42����
> > From:
> > >"wlb52@"
> > To:
> > >PM
> > Got to the
> > Connected by
> > From: Ralph
> > >GMT+00:00
> > >switch
> > >Safe travels,
> > >Duncan,
> > >Oklahoma
> > >From:
> > >"William B"
> > >Date: Fri, 04 Nov
> > >2011 19:30:51
> > >To:
> > >Subject:
> > >located
> > >Yahoo! Groups
> > >Links
> > >Yahoo! Groups
> > >Links
> > >to:
> > >*> Your email
> > >settings:
> > >go to:
> > >(Yahoo! ID
> > >required)
> > >email:
> > >to:
> > Yahoo! Groups Links
11-12-2011, 08:40
Post: #33
I can't believe I didn't see it.
To:
Sent:
Sat, Nov 12, 2011 20:04:08 GMT+00:00
Subject:
That A/T switch is a sneaky lil devil!
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
