batteries
11-12-2009, 08:05
Post: #51
batteries
Most systems (including Blue Birds) are set up with negative ground, so if you remove the negative cable, then the batteries are guaranteed to be isolated.
Presumably, if you disconnect the positive cable, you get the same result, but if the disconnection (by a switch, for example) isn't complete -- if something is 'tapped' before the switch -- then the disconnection is only partial. If there is a short from a positive wire to the frame, with the negative disconnected, then there is no fire. So the negative is the 'safer' wire to disconnect. (Of course, if there's a short, you'll find it rather quickly after hooking the battery up, again.) This is all reversed in a system with a positive ground. Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Nov 11, 2009, at 10:43 PM, gregory O wrote:
11-12-2009, 08:13
Post: #52
batteries
Pete, It may have something to do with the flow of electrons. Contrary to popular belief, electrons flow from negative to positive.
Dan Williams,88WB38, Jackson,MS
11-12-2009, 08:31
Post: #53
batteries
11-19-2011, 01:53
Post: #54
batteries
Has anybody heard anything good or bad about Crown 6 volt golf cart batteries.
Th place where I bought my Trojan's 12 years now sell only the crown. Don Spithaler 89 SP 36' Butler, PA |
11-19-2011, 02:02
Post: #55
batteries
11-19-2011, 02:05
Post: #56
batteries
I believe you will findÃÂ CrownÃÂ about the same as theÃÂ Trojan, and their pricing is about $5.00/battery less comparing the T-105 to the Crown 225. http://www.solar-electric.com/cr225am6vode.html
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" One of the "Birds of a Feather" (BoF) Organizers On Sat, Nov 19, 2011 at 6:02 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
11-19-2011, 10:30
Post: #57
batteries
Thanks Ernie & Curt    I got 4 Crown 225's. I'll give them a tryÂ
On Sat, Nov 19, 2011 at 9:05 AM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
