Pyrometer troubleshooting
04-11-2006, 23:52
Troy, I wonder if you have a bad wire connecting to your sender?
Ernie-83pt40 in Louisiana
04-12-2006, 02:59
Any suggestions on where to start troubleshooting a non-working
pyrometer? The guage needle does not move. The guage is a ISSPRO
model with both turbo boost and pyrometer in a single 3" guage. The
turbo boost works. The motor is a DD8V92 1984 vintage with easy access
to the sender. The sender is clean and looks good.
Thanks
Troy Tikalsky
Waconia, MN
1986 Newell 40'
04-12-2006, 12:36
Change the probe.
MH
Sent: Wednesday, April 12, 2006 9:59 AM
Subject: [WanderlodgeForum] Pyrometer troubleshooting
Thanks
Troy Tikalsky
Waconia, MN
1986 Newell 40'
radiators
YAHOO! GROUPS LINKS
06-06-2006, 07:11
Before ordering the part I checked the sender for voltage, two wires 1
yellow no voltage and 1 red no voltage. Shouldn't there be 12 volts
to the sender when the ignition is on (motor not running)?
Troy
<MHOHNSTEIN@...> wrote:
> Change the probe.
> MH
> From: ttikalsky
> Thanks
> Troy Tikalsky
> Waconia, MN
> 1986 Newell 40'
maintenance
Automotive radiators
> YAHOO! GROUPS LINKS
Service.
