Need Help With 12 Volt Water System...
05-12-2006, 11:12
James,
You don't have any switches or Sporlan valves on your water system. David Hollis Springfield,IL James has my old bus |
05-12-2006, 13:45
Sounds your fill valve, sporland valve, is defective and need of repair. Or, as
I found with the same symptoms after fixing the sporland valve, the hot water dump valve was defective. Either one can cause the same symptom. That was on our '81 FC. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: orbitalsolutions To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 12, 2006 2:26 PM Subject: [WanderlodgeForum] Need Help With 12 Volt Water System... My water pump runs and pumps water, but very slowly. I could not find any leaks or lose connections. It seems like the pump does not prime it's self for some reason. The pump will run constantly. I'm digging into it now. Does anyone have any advice to offer? Thanks in advance. James 78FC33SB Kingman AZ (But not for long) ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-12-2006, 14:43
Thanks to everyone who responded to my cry for help. Your immediate
and insightful responses are greatfully appreciated. The problem was a pressure relief valve that was mounted to the hot water heater directly above the hot water drain pipe. I removed the valve and droped the drain tube, went to a local hardware store and found a valve with the same specs as the one I removed. I was told that it is a very common valve. It fit into the hot water heater and and with an adapter, fitted it to the drain pipe. Total cost -- $37.42US, not counting the teflon tape I had in the toad. A special thanks to my main man, fire-fighter Dave Hollis. Well, enough of this for now. It's time to take a nice shower. James 78FC33SB Kingman AZ (But headed east, slowly and very surely ;-) --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Sounds your fill valve, sporland valve, is defective and need of repair. Or, as I found with the same symptoms after fixing the sporland valve, the hot water dump valve was defective. Either one can cause the same symptom. That was on our '81 FC. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: orbitalsolutions > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 12, 2006 2:26 PM > Subject: [WanderlodgeForum] Need Help With 12 Volt Water System... > > > My water pump runs and pumps water, but very slowly. I could not find > any leaks or lose connections. It seems like the pump does not prime > it's self for some reason. The pump will run constantly. > > I'm digging into it now. Does anyone have any advice to offer? > > Thanks in advance. > > > James > 78FC33SB > Kingman AZ (But not for long) > > > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForu m>" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum- unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
05-12-2006, 15:02
James,
That is what this site is all about. Glad everything work out ok. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. orbitalsolutions wrote: > Thanks to everyone who responded to my cry for help. Your immediate > and insightful responses are greatfully appreciated. > > The problem was a pressure relief valve that was mounted to the hot > water heater directly above the hot water drain pipe. > > I removed the valve and droped the drain tube, went to a local > hardware store and found a valve with the same specs as the one I > removed. I was told that it is a very common valve. It fit into > the hot water heater and and with an adapter, fitted it to the drain > pipe. > > Total cost -- $37.42US, not counting the teflon tape I had in the > toad. > > A special thanks to my main man, fire-fighter Dave Hollis. > > Well, enough of this for now. It's time to take a nice shower. > > > James > 78FC33SB > Kingman AZ (But headed east, slowly and very surely ;-) > > > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > > > > Sounds your fill valve, sporland valve, is defective and need of > repair. Or, as I found with the same symptoms after fixing the > sporland valve, the hot water dump valve was defective. Either one > can cause the same symptom. That was on our '81 FC. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > > From: orbitalsolutions > > To: > WanderlodgeForum@yahoogroups.com > > Sent: Friday, May 12, 2006 2:26 PM > > Subject: [WanderlodgeForum] Need Help With 12 Volt Water > System... > > > > > > My water pump runs and pumps water, but very slowly. I could > not find > > any leaks or lose connections. It seems like the pump does not > prime > > it's self for some reason. The pump will run constantly. > > > > I'm digging into it now. Does anyone have any advice to offer? > > > > Thanks in advance. > > > > > > James > > 78FC33SB > > Kingman AZ (But not for long) > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > ----------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your > group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForu > m>" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum- > unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service<http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------- > ----------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
