3208 thermostat housing removal, How do you get the dang thing off.
05-29-2006, 14:29
I just rebuilt my fan assy.,and the water pump belt idler so I figured
I would change the thermostats while I was in the front. I took out the
3 bolts but there are 2 studs w/nuts that won't come out. The stud
turns with the nut but doesn't back out. I have the Cat shop manual and
it shows a different water neck. Is the 180 degree neck a Blue bird
Item?
Are the studs really bolts put in from the backside of the thermostat
housing before it is installed? I don't want to damage the casting and
I don't know if I need to split the nuts on the studs or what. Also if
anyone wants to rebuild their idler assy. I can give you the Cat part#s
for the parts you need. About $40.00 worth of parts instead of $375.00
for a new idler assy.Thanks Jim Matus 1984FC35SB Rescue CA
05-29-2006, 15:29
I seem to remember that stud goes all the way through and there is a nut on the
other side. You can reach it with an open end wrench.
Dan
81FCRB
Jackson, MS
Sent: Monday, May 29, 2006 9:29 PM
Subject: [WanderlodgeForum] 3208 thermostat housing removal, How do you get
the dang thing off.
Item?
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-31-2006, 16:08
THANKS Dan I never thought they would have used such long thru
bolts.---
a nut on the other side. You can reach it with an open end wrench.
> Dan
> 81FCRB
> Jackson, MS
> From: jim matus
figured
out the
stud
manual and
bird
> Item?
thermostat
casting and
Also if
part#s
$375.00
financing Recreational vehicle repair
Recreational vehicle rate
> YAHOO! GROUPS LINKS
of Service.
